I have completed the full bag set-up and am waiting for the 4-link to show up so I can finish the set-up and throw on my rims. I keep looking at my truck and I am noticing that the body line doesn't match up right from cab to bed. What do I do?
Is this common? Is there any combo of shims, washers, etc. that will correct it? I am looking around and it seems that stock trucks have the same misalignment problem, but I want the body line straight. Any help would be great, and I will post pics as soon as I get the rims on, stockers are cramping my style..... RikuY |
Got Boost?
you are suppose to shim it.. if its off, add another one or fid 1 shim to fit your needs.
i think its very common, the bed on my 02 S10 is crooked, i didn't care at the time because the truck was the only one i could find with the options i wanted (which were no options at all). I never really noticed it as much until i bagged the front, damn its bad and it looks shifted to one side
.....anyway, i don't see why washers wouldn't work but i think shims would be easier since the bolts do not have to come completely out. Just measure how much its off and throw a washer (hopefully u don't need a stack) in and tighten er up.-Kevin |
right on.....
I kinda figured, thanks for the responses..... RikuY |
Laid.
mine was crooked when I bought mine, left rear....PITA ;-)
what'd ya know mine was to very front left mount. shimmed her up alittle bit and looks purdy. looks like this [u] (the shim)
Re: Bed crooked?
My bed has the same problem mine is the front left side of the bed, it seems off when my truck is sitting on jack stands. I am in the process of repainting it right now and I pulled the bed off off the frame and found two shims on the front left. I have air ride so I wonder if that has anything to do with it? does anyone think this is common?
Re: Bed crooked?
I think my whole bed is just warped. The right side is perfect and left side looks like bed is 1/4 inch too far left
