Bagged on 20s - Page 13 - S-10 Forum
Bagged on 20s
Old 03-21-2014, 07:51 PM   #601
littledevil4802's Avatar
Re: Bagged on 20s
turned out.
Old 03-21-2014, 08:13 PM   #602
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
specs? you mean?
Old 03-25-2014, 10:53 AM   #603
dnyce's Avatar
Re: Bagged on 20s
So, I wrote down the sizes I bought for the brakes but can't find the paper. What I do remember is the front brake port on the master cyl was 1/2", and the rear brakes were 9/16 I believe. Can't remember the thread count but it was a standard size. I think 1/2-20 and 9/16-18 sounds right. I believe the ports coming out of the abs unit are 1/2, 7/16. You can need a wildwood adj prop or similar for the rear.
It was a bit of a hassle. I'm going stainless, looks better, easier to do.
Old 03-29-2014, 04:03 AM   #604
Re: Bagged on 20s
A little paint and that bitch will be clean
Old 03-29-2014, 05:12 AM   #605
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
Soon. Thinking of channeling the body. I miss sitting on rockers.
Old 03-29-2014, 09:52 PM   #606
Re: Bagged on 20s
I almost forgot about that truck! Keep up the good work, Ed!
Old 03-29-2014, 10:50 PM   #607
i don't like people
Retro Ten's Avatar
Re: Bagged on 20s
i still feel like that truck is familiar to me.
Old 03-30-2014, 09:59 AM   #608
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
Its originally from down here in South Cackiliacki. The original builder did good welding , bt the air set up and electrical work was quite bad.
working on my suicide hood at the moment.
Old 03-30-2014, 11:08 AM   #609
Re: Bagged on 20s
Is that a kit or or you fitting it off something? Going to be sweet either way, just curious.
Old 03-30-2014, 02:33 PM   #610
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
1998 Buick LeSaber Hood hinge that I am modifying.
This is the last one I did.
Old 03-30-2014, 10:07 PM   #611
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
hood back on truck. Haven't closed it yet. Was extremely tired after my wife helped me put it back on.
oh ya, AaronK, the hinge came off a 1988 LeSabre, not a 1998. The hinges come on 1984-1988 Buick LeSabres.
Old 03-30-2014, 10:36 PM   #612
layed_sdime
95v8sdime's Avatar
Re: Bagged on 20s
Looks awesome big e
Old 03-31-2014, 01:28 AM   #613
Re: Bagged on 20s
I really like that. If there isn't a write up on it you should do one
Old 03-31-2014, 05:07 AM   #614
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
There are a few.
Here is the first one I found here on this forum.
http://www.s10forum.com/forum/f199/1...w-pics-145615/
and this one.
http://www.s10forum.com/forum/f72/2n...how-to-222793/
I originaly read about it back in 2007 on the Blazinlow forum.
The first suicide hood I did, I made the hinge from 2 pieces of 1" by 1/8" thick flat stock metal,2 pieces of
angle steel that I cut in half, to make 4 pieces of short angle steel, 2 springs, and a few nuts and bolts I
bought at home depot. And fabbed up this creation.
I really should have put a cross brace on this hinge. Opening and closing the hodd would have been easier.
Old 03-31-2014, 05:10 AM   #615
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
tanx, 95v8sdime. that's a new nickname. Big E. That's a name of a big curcus back up north. I'll just add this one to Dr. E, and Mr. Ed, a couple other nicknames I have had. ha ha ha ha.
Old 03-31-2014, 10:01 PM   #616
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
well got the ABS delete done and thee hood on. Still have a few adjustments to do on the hood, bleed the brakes and maybe.... if I'm lucky she will role out of te shop under her own power for the first time in over a year.
here is a transmission cross member ready to be cut and welded so the truck will lay flat.
Old 04-01-2014, 07:55 PM   #617
i don't like people
Retro Ten's Avatar
Re: Bagged on 20s
nice ed you gata be itching to drive this thing soooo bad.
Old 04-01-2014, 09:17 PM   #618
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
oh ya. Gotta clean out the brake fluid reservoir, fill if, bleed the brakes, check the lines and fittings. There is a small possibility I may try to get her out of the shop this weekend.
Old 04-03-2014, 11:00 AM   #619
ELTC
Gimp's Avatar
Re: Bagged on 20s
Ur cowl hood must be steel right Ed? I wanted to that to mine but its fiberglass and i dont know that i want to use fiberglass to secure the hinges ya know. I still might do it with my Hombre hood tho
Truck is really coming along now man. Keep at it!
Old 04-03-2014, 06:00 PM   #620
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
the picture of the blue s10 blazer I did a few years ago. I did the suicide hood on a fiberglass hood. I cut 2 small rectangular holes in the bottom f the hood and slid in 1 1/4" piece of flat stock steel in on each side. Each plate had two threaded holes cut in them for the hood bolts to tread to. The plates were about 9-12" longs.
Sorry I don't have any photos of the fabrication.
Old 04-04-2014, 12:35 PM   #621
Re: Bagged on 20s
That is awesome looking. Great job on the fiberglass one, too
Old 04-04-2014, 08:39 PM   #622
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
the great thing about the 'glas hood is it weighed nothing
Old 04-09-2014, 06:14 AM   #623
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
well. did nothing on the sled this past week end. Slowly finishing up the suicide hood set up, and building a sweet brake bleeding set up.
Old 04-09-2014, 08:31 PM   #624
i don't like people
Retro Ten's Avatar
Re: Bagged on 20s
no offense but the harbor freight vacuum bleeder i bought cost less then that pump sprayer. harbor freight shit ain't bad if you don't use it professionally.
Old 04-10-2014, 05:12 AM   #625
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
true. I had one of those HF bleeders. My stepfather broke it and never replaced it. I have pretty much all the parts to make this bleeder in my shop. My wife and I o to HF a couple times a month.
Old 04-10-2014, 07:43 PM   #626
i don't like people
Retro Ten's Avatar
Re: Bagged on 20s
their stuff is great if you use it once and a while you go buy another $6 one.
Old 04-11-2014, 12:23 AM   #627
Ice_Auto's Avatar
Re: Bagged on 20s
Got any pics of ur abs delete set up, and what did you do with your blower motor?
Old 04-11-2014, 05:04 AM   #628
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
I'll snap a couple pics this week end. Are you asking about the HVAC blower motor? Its gone. the fire wall hole for it is filled and I have a Hot Rod Air HVAC unit under the dash.
Retro, the only tools I have from HF are a couple of cut off/grinders. I get my cutting and grinding wheels there and small stuff like wire loom and welding wire.
Old 04-11-2014, 04:59 PM   #629
i don't like people
Retro Ten's Avatar
Re: Bagged on 20s
i never buy any thing with a battery or a cord on it from them but all there hand tools are worth it for occasional use.
Old 04-11-2014, 07:42 PM   #630
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
I've had my cut off/grinders for 6-7 years. they still work great
Old 04-23-2014, 06:13 AM   #631
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
little more work. Have been remodeling the kitchen so the truck has been dormant.
Hydroboost...
hope to get her moving before the end of the month.
Old 05-04-2014, 08:59 AM   #632
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
Well..................... More tearing up and such, I moved the air valves off the air tank and onto the frame. Fabbed up a few mounting brackets and reran the wiring and plumbing.
Back together.
Next modifying the transmission cross member so she will lay out flat. Have one on the bench all marked up to be cut and welded.
Just have to clean the master cylinder brake reservoir, Bleed the brakes, and wait in the PTC fittings from Thorbros. to connect the air tank to the system.
Old 05-04-2014, 11:45 AM   #633
Re: Bagged on 20s
Man it's getting so warm outside! Time for a cruise!
Old 05-04-2014, 04:36 PM   #634
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
some day soon. Had me thinking I was still riding one of my Harleys.
Old 05-10-2014, 06:32 PM   #635
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
well just have to bleed my brakes and wait on my PTC air fittings from Thorbros, and I can try to drive my sled.
Old 05-10-2014, 10:21 PM   #636
alway's changing somethin
S10dude's Avatar
Re: Bagged on 20s
woot !
Old 05-11-2014, 06:13 AM   #637
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
ya I am very antsi. I was going to bleeed the brakes this weekend, but I am finishing up putting big spa tub in the master bath and fabricating a custom counter for the kitchen island and kitchen bar top counter. plus tidying up the ceramic backsplash my wife pt up in the kitchen.
Old 05-25-2014, 05:23 PM   #638
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
well, got a little work done this weekend. Modified the transmission cross member, modified the battery box hanger, and started the truck for the 2nd time in over two years.
Old 05-26-2014, 04:52 PM   #639
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
Fixed my third door latch. Just had to disassemble it, clean up the parts, reinstall, and adjust.
Old 06-30-2014, 08:29 PM   #640
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
it was originally built by a friend of mine Matt aka Ice. His shop usd to be named House of Hack. It is now McLary's Metal works.
Old 06-30-2014, 08:31 PM   #641
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
well.. got a little electrical work done. Deleted the auto headlights and daytime running lights successfully.
Old 07-03-2014, 01:25 AM   #642
Re: Bagged on 20s
nice work man Ive followed this one for a while
Old 07-03-2014, 05:33 AM   #643
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
thanks. unfortunately its taking me a while. Ive owned it for almost 2 years and have never driven it. But still plugging away at her. Future plans are, hopefly get her down to my friends shop to have the body channeled over the frame. Then a V8 swap after I get her back.
Old 07-15-2014, 05:34 PM   #644
Re: Bagged on 20s
trying to get the parts to get the front of my 99 this weekend. i haven't decide the ditch the abs or just move it. suggestions? as for the inner fenders and blower box im going to run trailer/ custom inner fenders and going to build a new blower box that will keep the fan under the hood. if i ditch the abs should i go ahead and get a new break booster and master cylinder combo from an older s10 or blazer? or should i just keep the stock parts install a prop off one? i know this is a lot but i want to try and get this part done so we can finish the rear of the truck
Old 07-15-2014, 06:26 PM   #645
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
I kept my master original cylinder and replaced the booster with a Hydrooost brake set up from a Astro Safari van.
Old 07-21-2014, 08:16 PM   #646
MANIC MECHANIC
Ednigma's Avatar
Re: Bagged on 20s
Full air lift.
If you do not want to register, fill this field only and the name will be used as user name for your post.
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
