Bag Taking Longer To Fill
Old 11-05-2009, 10:03 PM   #1
knight456's Avatar
I have noticed in the past few days that my passenger rear bag doesnt fill as fast as the other rear bag. If I hold the switch for the rear open I can watch the pasenger rear bag SLOWLY level out to the same height as the other bag. I have 8 valves but only have front back hooked up right now. I cleaned the fill the other day but it didnt change anything. Any ideas as to what could be causing this?
Old 11-05-2009, 11:11 PM   #2
Sgt. G's Avatar
Re: Bag Taking Longer To Fill
if ur running a front back im assuming ur runign a tee to split ur line scheck the line that runs to the slow bag a pinch in the line would slow air flow
Old 11-05-2009, 11:27 PM   #3
knight456's Avatar
No I am not running a T each bag has its own fill and dump.
Old 11-05-2009, 11:59 PM   #4
SK wi member
1low91s10's Avatar
if its an smc valve there will be an arrow on them pointing in direction of flow, if you put a valve in backwards it will still work but it will use only 50% of its capacity(just a thought i have seen it before)
Old 11-06-2009, 12:00 AM   #5
BAD HABITS LAS VEGAS
dirtsindicate's Avatar
Is the line to the slow bag longer than the line to the fast bag or are they the both the same length , also how old is your set up are you running a water trap if your not you could have a chunk of rust in the line from the tank
Old 11-06-2009, 03:30 PM   #6
Patawick's Avatar
I dont think you'll have a "chunk of rust".
Old 11-06-2009, 07:04 PM   #7
knight456's Avatar
I know the valve is installed correctly cause it worked fine a few days ago and then started acting up. I can take the line off and see if there is anything in it but I doubt it.
Old 11-06-2009, 08:30 PM   #8
knight456's Avatar
Ok there is nothing clogging my line up. I guess I am gonna try to clean the valve again. Any more ideas?
Old 11-07-2009, 08:02 AM   #9
Bmanxer's Avatar
How old are your valves bro?
Old 11-07-2009, 03:40 PM   #10
knight456's Avatar
Roughly about 2 years old I am guessing. I have had them on my truck for little over a year now. I bought them off a buddy who had them on a truck for about a year.
Old 11-09-2009, 12:15 PM   #11
fitbmx180's Avatar
clean them out? or buy new ones
Old 11-09-2009, 12:23 PM   #12
Low Class
JohnnyDigits's Avatar
Process of elimination...
1. swap the p/s air line to the d/s. does it happen on p/s still?
2. swap the line at the valve side from p/s to d/s valve. does it still happen on p/s
3. switch valves on tank ports or switch the wiring temporarily. Did the result change?
I'd start there and keep moving along until I found the culprit. Good luck. Sounds like a valve issue to me though.
Page generated in 0.56889 seconds with 31 queries
[Output: 76.19 Kb. compressed to 71.00 Kb. by saving 5.20 Kb. (6.82%)]
