Bag on bar placement? - S-10 Forum
Old 04-07-2012, 05:17 PM   #1
JESUS FREAK
goldenrider18's Avatar
Whats up s10forum fam I have a question on my 4 link i have a fbi universal 4 link i want to mount my bags on my lower bars Does anyone know if this link is gona be strong enough or do i need to add a bar gusset. also im gona have to offset the bag alittle is this gona be a problem oh an this is on my new hardbody project
and how i wanna mount the bag
Old 04-07-2012, 05:27 PM   #2
Negative 10
illest G's Avatar
Re: Bag on bar placement?
weld a plate to the lower bar that the bag can mount to and then gusset the plate to the bar and it will be fine
Old 04-07-2012, 05:36 PM   #3
JESUS FREAK
Thank you sir just needed some one to say itll work lol good day to you
Old 04-07-2012, 05:53 PM   #4
Registered Asshole
rstadelmaier's Avatar
wouldnt hurt to add a gusset under the bar. better to overdo it than not enough right?
Old 04-08-2012, 01:09 AM   #5
tohoopty's Avatar
if you mount the bag offset on the bar its gonna make the bar twist and its gonna eat up bushings
Old 04-09-2012, 10:50 AM   #6
JESUS FREAK
I also know this I'm going to get it as centered as possible but will still have to offset it alittle so I can bolt it to the bag mount on the bar. Trying to do this on a small price margin all my moneys going torge my wedding right now.
Old 04-09-2012, 11:13 AM   #7
Burnt Blazer
black_ice_02's Avatar
your bag doesn't have 3 bolt holes on lower plate? that sucks... are you using the lower bag cup as well or just plate to bar?
Old 04-09-2012, 01:16 PM   #8
Disturbed Image Trucks
lowdime96's Avatar
Turn the bags 90 degrees and weld a circle plate on the top of the bar. The bags can now be centered and have 2 lower mounting points.
Old 04-09-2012, 01:19 PM   #9
Proud Canadian
Lutz's Avatar
I'd almost say that bar is too thin.
Old 04-09-2012, 09:15 PM   #10
JESUS FREAK
I'm doing circle brackets on the bars an I'm running slam re6s my problem is the lower bars are so close to the frame I'm going to get the bag as close to the frame as possible but it still want be centered
Old 04-09-2012, 09:21 PM   #11
Registered Asshole
notch the frame
Old 04-09-2012, 09:37 PM   #12
JESUS FREAK
To be honest I didn't even think about that
Old 04-09-2012, 09:51 PM   #13
Air ride & Audio
s10gmconversion's Avatar
Is there a reason you are mounting your bags that close to the axle. It defeats the purpose of having BOB unless it's just where you want it due to limited room or something?
Old 04-09-2012, 09:54 PM   #14
Registered Asshole
Old 04-09-2012, 09:56 PM   #15
JESUS FREAK
Very limited room its ether there or like right infront of the mounting point at the frame
Old 04-09-2012, 10:08 PM   #16
JESUS FREAK
Scratch that that's the only place I can mount them to the bar at
Old 04-09-2012, 10:20 PM   #17
Registered Asshole
not completely. a third of the way instead of half rides amazing. takes less pressure, and nobody needs all the lift that middle bar placement offers.
Old 04-09-2012, 10:24 PM   #18
Air ride & Audio
No.... All you have to do is think of a see saw. It's only effective 50% and greater past the fulcrum point
Old 04-09-2012, 10:33 PM   #19
JESUS FREAK
I just want bag on bar I dnt care much for a lot of lift bc I have no use for it as long as it rides good and I have a triangle notch so I didn't wanna do bag over axle like the prevous owner
Old 04-09-2012, 10:39 PM   #20
giggity
Extd_on_20s's Avatar
Is there any way to mount them on the upper bars?? Just wondering...
Old 04-09-2012, 10:45 PM   #21
JESUS FREAK
If they were mounted the oppeset way yes
Old 04-09-2012, 11:06 PM   #22
lowdime96's Avatar
I notched the frame for bag clearance a few times. Just took a massive piece of tubing and cut it in half
Old 04-09-2012, 11:45 PM   #23
JESUS FREAK
I work at a steel mill an there are many massive pieces of tubing in are scrap yard lol
