Anyone have a pic of the super lift super pivot 4-link sd?
Anyone have a pic of the super lift super pivot 4-link sd? And is there a better way to go for bag placement other than a bridge kit for hitting sides? thanks Greg
Re: Anyone have a pic of the super lift super pivot 4-link sd?
A super pivot superlift kit is for putting the bags on the bars, not with a bridge kit. if youre going to do a bridge then get the 3link and youll be set. if you want to do big sides then youd want the bags on the bars.
well i bought the universal triangulated super pivot 4 link kit from sd and the bridge kit and was going to do it that way but u really dont get a tone of lift and i though about putting the bags on the bars with the super lift center mount bracket kit from sd but still use the bridge kit but not the bag brackets. would this be best? Also anyone with pics of this done? thanks Greg or something close?
you wont need to run a bridge kit if your going bag on bar....
Hoods are overrated
but a "bridge" bar welded between the frame notches helps to keep anything from getting out of square when you're hittin them monster sides
Do you have pictures of your setup ? Cause I get pretty damn good lift BOA on a Mono leaf (temp setup that turned permatemp , due to lay off)
I farted...
Life Begins @ Zero PSI
WTF is the point unless you ditch the front sway bar. Ditching the front sway will give you huge body roll. I love my 4 valves front up/down rear up/down. But if you must have sides go for it.... I'm telling you if you like the road, you might throw that front sway back on. |
Ok , since ur trying to call someone out .. Not like I have to prove anything to you , but here.. buddy truck that BOB , limited by shocks 18's http://i22.photobucket.com/albums/b3...Picture010.jpg my truck on a mono BOA , limited by shocks 20's (mind you my truck is setup for 17s not 20s... ) http://i22.photobucket.com/albums/b3...Picture040.jpg side by side my truck gets MAYBE 2" less lift. |
I like to hit sides man when I am all said and done. That's just me as for the sway bar it will be gone unless I really need it I will only drive this truck around town and shows it's not my daily driver. And also tryin to keep it strong as I can running 200psi 4 viair 380s and 1/2 smc valves dual port bags. I like if I can and I hope it will hop it 1 to 2 "
wow , that WAY over kill to hop 1-2" ..
Id do like 2 480s on 8 galons with 1/2 everything , an it should be able to hop 1-2" @ 200psi. |
SoloKustoms
hey man im lookin to do the same thing....i bought the gen 3 bridge ki then decided i wanted bag on bar for the lift, and to hit sides, if u get it done soon throw some pics up id love to see it...mine wont be dont till close to christmas....
I farted...
Guess that is what I get for assuming... But none the less the mono isnt bad IMO , would I rather have a 4 link YES .. do I plan on doing a 4 link YES , it was suppose to have been done along time ago but getting laid off put a twist in that plan. |
Fat man on a little dirt bike..
to do sides you have to get rid of the front sway bar? i wouldnt be able to keep it? what about the rear sway bar?
This is doo doo baby!
you can keep it, but you're sides are going to be weak
I'm puttting my swaybar back on soon, the whole hitting sides thing got old after a while and I like being able to drive it |
can you get some vids of ur truck before sway and with sway. I'm wondering the diff is with them on and off. Sorry for thread jack
