anybody else have these leaks?
Old 09-02-2008, 07:45 PM   #1
.Life in the Slow Lane.
rosswhenifloss's Avatar
rosswhenifloss is on a distinguished road
I woke up this morning and had barely any air in my tank. So I got my trusty bottle of soap water and started squirting. Only spot i found was where air was backfeeding into the compressor and coming out of the filter... I've had this 380 on my truck for about 3 months too. Anybody else's viairs leak?
Old 09-02-2008, 07:48 PM   #2
Burnt Blazer
black_ice_02's Avatar
black_ice_02 is on a distinguished road
Re: anybody else have these leaks?
checkvalve
Old 09-02-2008, 07:49 PM   #3
Local Tech
lt1s10onair's Avatar
lt1s10onair is on a distinguished road
ummmmmmmmmmmmmmmmmm...... do you have a check valve? if you do, that shouldnt happen.... besides, its bad for the compressor to fight the tank pressure.... hence, why u should have one.... if you have a check valve, get a new one
Old 09-02-2008, 07:54 PM   #4
dont the leader hoses contain a check valve?
Old 09-02-2008, 07:54 PM   #5
***JACOBY***
AVS_JEFF's Avatar
AVS_JEFF is on a distinguished road
Where did you purchase it from? You have a 1-year warranty against that defect. Contact your supplier, because if you remove the leader hose yourself, Viair will more than likely void your warranty.
Old 09-02-2008, 08:25 PM   #6
Burnt Blazer
yeah but checkvalves can stick. try takin it out the takin and spray it internally with lube
Old 09-02-2008, 08:38 PM   #7
I run a square D so that voids it and I have already had to replace the leader hose once.
Old 09-02-2008, 08:47 PM   #8
guess ima get a new leader hose and try that too..
Old 09-02-2008, 08:49 PM   #9
Local Tech
sorry... dont have a viar, so my comp. is setup differently
Page generated in 0.09997 seconds with 11 queries
