air shocks - S-10 Forum
post #1 of 30 Old 10-15-2001, 03:21 PM Thread Starter
Sportin' the Black and Red
User is: Meanextreme is offline
air shocks
What do you all think of air shocks in the rear? I lowered my extreme in the back 2 inches and so the back is lower than the front about 3/4 of an inch. I dont want to touch the front end for now so would air shocks even out the height if I put a certain amount of air in the shocks?
Meanextreme
post #2 of 30 Old 10-15-2001, 08:50 PM
not low enough
"best unfinished"
User is: lowblazer is offline
Post
I got airshocks in the rear of my blazer. it's got a 5/6 drop. I got the onboard compressor to and It gives me about 2" of adjustment it takes about 2 minutes to get there but you need it if you going to haul stuff. if you used blocks you might just get that 3/4 lift needed, but if you used springs you would be able to get it.
post #3 of 30 Old 10-15-2001, 08:52 PM
User is: S 10 MTRSPTZ is offline
It will work if you want to raise it up .
I have air shocks on my 96 ext. cab 3/4 drop the ride is ok .
Go to Advance auto - $50 bucks for the set with everything you need to install.
I'm going to rerun my lines and have the air valve in the gas tank filler door.
Good luck
Bob
post #4 of 30 Old 10-26-2001, 02:18 AM
hittin switches
User is: hydroblazer is offline
i have them on my nissan. let me know if you have any ?'s.
heres a pic
87 S-10 Blazer with hydros
post #5 of 30 Old 10-26-2001, 02:19 AM
hittin switches
heres a pic aired up
post #6 of 30 Old 10-26-2001, 02:41 AM
Guest
98 SS ON NOS's Avatar
User is: 98 SS ON NOS is offline
Send a message via AIM to 98 SS ON NOS
why not get the chevy roll pan?
what id do is just shave the block a little
tony
post #7 of 30 Old 02-17-2004, 03:00 PM
Bad Mother F***ER!
dymetyme95's Avatar
User is: dymetyme95 is offline
Send a message via AIM to dymetyme95
Re: air shocks
airshocks leak , GET BAGS!!!!!!!!!!!!!!!!!!!!
95 Dime. 350 V8, Blower pushin 8lbs, th350 tranny, 32" Lokar shifter, shaved and laid out. 3 link, 7 gallons of air, 2 viair 380's, 8 valves. 3 " body drop. cali combo rear, full custom sheetmetal firewall and floor. plus alot of other shit
www.myspace.com/jbanas05
post #8 of 30 Old 02-17-2004, 03:06 PM
SlammedDime's Avatar
User is: SlammedDime is offline
Send a message via AIM to SlammedDime Send a message via Yahoo to SlammedDime
Re: air shocks
AiR SHOCKS = GHETTO
post #9 of 30 Old 02-17-2004, 03:29 PM
EX-Minitrucker
anotherblacks10's Avatar
User is: anotherblacks10 is offline
Re: air shocks
Originally Posted by SlammedDime
AiR SHOCKS = GHETTO
*quote from the big lebowski* "Well that's like. . . your opinion man ."
He's got a static drop and he's looking for advice on AIRSHOCKS not you 2 cents on what YOU would rather do.
Airshocks are perfectly good for what you want to use them for since you're just wanting to adjust your ride height. And NO they don't leak like people will tell you. We use them on fleet trucks to level a load or to help with towing. Mine ride nice as hell and i'm about 1/2" from laying out when aired out and it does ride nicer than any static drop i've been in.
post #10 of 30 Old 02-17-2004, 03:35 PM
420
YellowXtreme's Avatar
User is: YellowXtreme is offline
Re: air shocks
sorry to whore....what are you runnin? a 4" block and the airshocks??
03' yellow X...
post #11 of 30 Old 02-17-2004, 06:23 PM
ShattyFatmas's Avatar
User is: ShattyFatmas is offline
Send a message via AIM to ShattyFatmas
Re: air shocks
i'm running them and like them. a little stiff but not too bad. i get about 3" out of them. i have them hooked up to my tank though so it only takes about a second to fill, and i'm using 3/8" line, not the 1/4" it comes with. it may be ghetto to use that in place of bags, but mines just temp till summer when i can actually bag the back, and meanextreme just wants to level his truck out. i say go for it if its worth the $50 to get your truck level and you don't mind the rear being a little stiff.
post #12 of 30 Old 02-18-2004, 05:05 PM
EX-Minitrucker
Re: air shocks
Yes it's a 4" block and airshocks and they ride really soft IMO. they give me about 4.5" of lift so that's as much as my friend gets with his over the axle setup. I also have a SD bolt in notch. It's all just a temporary setup until i get my 4 link this summer.
post #13 of 30 Old 02-18-2004, 07:20 PM
Concept S-Series's Avatar
User is: Concept S-Series is offline
Re: air shocks
yeah air shocks leak but bags blow....
90 eclipse turbo, Sold the dime about a year ago.
post #14 of 30 Old 02-18-2004, 11:03 PM
lowhombre's Avatar
User is: lowhombre is offline
Re: air shocks
bags dont blow if installed right, air shocks still leaks even installed right...
post #15 of 30 Old 02-19-2004, 02:43 AM
FTW
slammed 97s1o's Avatar
User is: slammed 97s1o is offline
Send a message via AIM to slammed 97s1o
Re: air shocks
ive had air shocks on my camaro for 2 years and have not lost any pressure yet
97 s10 2.2 5 speed
2" performace accessories body lift
98 harley davidson heritage softtail classic
roadking saddlebags hoppe industries fairing
1997 gmc k1500
6"lift 35"tires
post #16 of 30 Old 02-19-2004, 03:17 AM
giggity
Extd_on_20s's Avatar
User is: Extd_on_20s is offline
Send a message via AIM to Extd_on_20s
Re: air shocks
anyone have pics of air shocks installed aired up and down??? if air shocks can get the same amount of lift as an over axle setup, has anyone layed out with them?? I mean... would it not be the same if 4" leafs and 3" blocks were installed??
-Darnell-
http://www.youtube.com/watch?v=w_QL7pzgrtU
Originally Posted by Bootylicious View Post
here we go again with people trying to start shit in real life because of what was said on the internet....
Originally Posted by andizzle View Post
all the best things are illegal lol
post #17 of 30 Old 02-19-2004, 09:56 AM
SOLD
MX_Racer32's Avatar
User is: MX_Racer32 is offline
Re: air shocks
air shocks wont get you the same amount of lift as an over the axel setup, and if they did, the ride qaulity wouldnt be anywhere near bags. I ve heard people saying 5-6 " of travel with there airshocks before but have never seen anything above 3-4". NCHEVY??..something i cant remember his whole user name, hes got a red s10 dookie-bagged. Its got bags in the front and air shocks in the back and i think he either does lay, or is really close to laying frame. Its an all red s10, with all black wheels\tires. Search for his username and then look for his truck buildup, hes got tons of pics. hes got a 2.25 notch though too, i dont want you to think that you can just unbolt the old shock and bolt up airshocks and think ur gonna layframe, thers more too it than that, but not much.
post #18 of 30 Old 02-19-2004, 12:52 PM
EX-Minitrucker
Re: air shocks
This is with 4" blocks and a monoleaf setup and airshocks. I'm about 1/2" to 1/4" from laying but it will lay when I get smaller tires (225/45/16) or i cut a small hole in the bed where the pumpkin hits.
This is with the rear all the way up (i'm only limited by my pressure switch here) I have a 110/145 pressure switch with a 5 gal tank and I only get around 120 Psi in the airshocks at full pressure. I don't know what kind of lift I would get if I had more air and higher Psi but this is good enough.
post #19 of 30 Old 02-19-2004, 03:57 PM
lownineyfo's Avatar
User is: lownineyfo is offline
Send a message via AIM to lownineyfo
Re: air shocks
i went to advance to try to get those fifty dollar air shox. and they dont have em...so do u guys have a part #or somehting???
front bagged,doin back in the spring
http://www.suicidedoors.com
"hittin switches for fine bitches"
http://www.mys10.com/your_truck/view_truck.asp?postid=1228923264
post #20 of 30 Old 02-19-2004, 04:37 PM
EX-Minitrucker
Re: air shocks
try autozone or o'reilly's. I have Monroe "Max-Air" shocks Part # MA759 and there's another number next to it, it might be important it's 28-80425 <----- that might be the part number and the first one might be the type of airshock. These have like a bag design at the bottom that fills up just like a bag instead of just a cylinder full of air so maybe that's why they ride well.
post #21 of 30 Old 02-19-2004, 06:06 PM
SOLD
MX_Racer32's Avatar
Re: air shocks
never heard of any bag at the bottom of an airshock, hell maybe they got smart and made them different so they will ride better.
damn those zq8's look good on ur truck man, too bad they didnt come any bigger then 16's. The new corvette has some nice rims on it, from what i could see from the commercial, kinda looked like zq8's but chrome and bigger.(sorry, off topic)
post #22 of 30 Old 02-19-2004, 08:11 PM
lowclrnce's Avatar
User is: lowclrnce is offline
Send a message via AIM to lowclrnce
Re: air shocks
Damn that is some pretty good lift u get out of those air shocks. I think I am gonna do that too. Not enough dough to bag the rear too. Looks killer man!!!!
post #23 of 30 Old 02-19-2004, 08:40 PM
lays frame on 22's
neverfinished94's Avatar
User is: neverfinished94 is offline
Re: air shocks
you guys know this post is 3 years old right? the 4th post down "hydroblazer" is my old username on here when i had my blazer and thats my old nissan that had air shocks. i miss those trucks
post #24 of 30 Old 02-19-2004, 09:05 PM
giggity
Re: air shocks
so, if you got the 5" block from gauge or something, you'd lay won't you?
-Darnell-
post #25 of 30 Old 02-19-2004, 09:54 PM
lowhombre's Avatar
Re: air shocks
lol...i didnt realize that it was that old of an issue...lol
post #26 of 30 Old 02-20-2004, 03:05 AM
EX-Minitrucker
Re: air shocks
It's kinda like a sleeve made out of the same material as bags and it's basically the seal that holds the air in the cylinder. when you air it up it expands and blows up just like a bag. Thanks for the compliments on the truck, it takes all my free time so i'm glad at least one other person besides me likes it. I found some wheels made my Enkei that resemble the old school zq8 wheels and they come in 18s pretty cheap only $168 a piece. they might need spacers though i'm not sure buy I dig them.
post #27 of 30 Old 02-20-2004, 03:09 AM
dansellbuddy's Avatar
User is: dansellbuddy is offline
Re: air shocks
they definitely look to be of the FWD type. looks hot though.
post #28 of 30 Old 02-20-2004, 10:39 AM
Re: air shocks
Yup - but its still fun
post #29 of 30 Old 12-29-2004, 07:40 AM
User is: GearShftr12 is offline
Re: air shocks
Yeah i know this post is old but can anyone tell me where to find some air shocks that will give me at least 4 inches of lift. Im runnin' a 4" block and soon mono-leaf. Thanks Y'all.
post #30 of 30 Old 12-29-2004, 01:51 PM
ibanez691's Avatar
User is: ibanez691 is offline
Send a message via AIM to ibanez691
Re: air shocks
gabriel sky jackers
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter."
-Ernest Hemingway
