2 or 3
Old 11-10-2009, 09:48 PM   #1
2 or 3
what is the difference between the 2 or 3 inch cups. for different wheel sizes people use?
Old 11-10-2009, 10:01 PM   #2
Re: 2 or 3
anybody??
Old 11-10-2009, 10:07 PM   #3
Who's got the fish?
Joker Relentless's Avatar
Re: 2 or 3
Depending on the size bag you will be using, the cup will give you more total height. As a rule of thumb, you should probably wait more than 10 minutes before bumping your thread and asking "anybody??"
Old 11-10-2009, 10:10 PM   #4
Who's got the fish?
Re: 2 or 3
Let me rephrase that...the 3 inch cup is taller than the 2 inch cup giving your a higher base line for lowering and lifting the truck...combine that with the size bag you use and you can have a higher amount of total lift when air up fully. Guys that are using bigger rims will use a larger bag as they can get away with because of rubbing issues, then run a taller cup in order to achieve the lift needed to clear the tire.
