#51 |
What's really retarded is arguing about suspension design with someone who has a degree in Mechanical Engineering, who has had many classes on suspension design and vehicle dynamics, who has personally built and used custom suspensions, and who happens to work for the Chassis Division of a leading automotive supplier. Especially when you have never owned a 2 Link or 4 Link, and your only argument is that there are plenty of "show trucks" that run 2 Links.
If you have enough skill to build a 2 Link, I don't see why you can't build a 4 Link instead? It doesn't require any extra special tools, and the extra material itself is inexpensive. The whole "I don't care about hitting side to side" is bs...Your truck cares about side to side when driving over uneven pavement. But alas you have blindly jumped on the 2 Link bandwagon and are now determined to prove everyone wrong. Good luck rewriting the laws of vehicle dynamics. Last edited by SlammedDime : 06-29-2003 at 10:37 PM. |
#52 |
#53 |
down to earth
i've been using a 2 link on a daily driver for about 10 months now and have had no problems with it. When my truck goes in for the bodydrop, I'm switching over to a 4 link for something new. A 4 link is deff. a better suspension design.
#54 |
well regardless of all this i am gettign a 2-link. i will let you all know how it works out, setup ideas, problems and whatever else...thanks guys
#55 |
little pink pink
AND IT IS STUPID TO ARGUE W/ A RETARD SUCH AS YOURSELF! |
#56 |
Turbos and Naws
why? lift?
#57 |
#58 |
little pink pink
#59 |
haha nice pxl. good luck with your 2-link thats what im going with. screw the haters.
#60 |
People who understand facts do not equal haters...
People who refuse to listen and/or try to understand equal ignorant. Did you guys argue with your math teacher in school that 2+2=Eleventy Billion? |
#61 |
ok not haters. people that dont think it is 'best' different is good. practicality is good. its whatever you want. not what everyone else wants. i want a 2-link and thats what i am gonna have you guys want your setups and you have them. im sure i will chang eover sometime but fo rnow thats what i want. thanks guys
#62 |
Turbos and Naws
all right, here is the pictures i promised of my bent 2 link made outta 2.5"x1.5"x0.120" tubing
Those tig weld held nice and stong though!!!!!! http://216.82.131.146/cyipher/2%20link%20bent/ |
#63 |
little pink pink
where did you have your bags mounted at w/ that setup? And did that crossbar work good, Was that used instead of a pan hard bar? |
#64 |
![]() If that doesn't show up here's the link, to his gallery: http://216.82.131.146/cyipher/bags/ I also see remember him stating that the crossbar didn't help at all, and was going to be fabbing up a panhard bar...but then the 2 Link bent and he scrapped it entirely. |
#65 |
Cyipher also killed about 4 sleeve bags with that setup, and the reason I believe they blew is because of excessive the lateral movement. They didn't overextend vertically because his shocks limited them, and they didn't rub on anything. The most likely scenario is he kept tearing the bags apart from the axle moving laterally while driving. A panhard bar would have fixed this problem.
#66 |
Turbos and Naws
yes it is true the cross bar didnt do crap! actually i killed 5 bags, blew the last one while removing the 2 link. hahah lowtown how do remember all this?
#67 |
Turbos and Naws
you can also see how the links are bent verticaly in the picture of it laying againts the garbage can. and you can see my VW bug in other pictures
#68 |
so yours woulda worked out with beefier bars and a panhard?
#69 |
Turbos and Naws
as good as a 2 lionk would
#70 |
I totally agree with your point and i understand what u are saying. If there is change in my pinion angle which i havent gotten to it with an inclino meter or anythign to see if there is a degree of cahnge or not, it is less then 2 degrees, i cant tell with my eye that it is changing, if you dont believe me i will get a video of me raising and lowering my truck and tape the pinion angle. If the angle moves less the 2 degrees that isnt worrying me. Its kinda funny that there is lots of people on the board that dont like 2 links...so be it..i dont care. I have a 2 link with a panhard bar...along with many other people. I will go back to what i have said from the first time that i posted that i have a 2 link and u have bashed me every time. If im so wrong how does IF custom get by with all the 2 link w/ panhard bars they do? The way they explained to me over the phone was the exact same way they did theirs....they could be feeding me a line of BS, but im pretty sure they dont...i dont think i have ever seen a truck come out of there with a 3 or 4 link.....maybe just me tho... Larry u are god, i have never said anything bad about you or anything bad about the things that u have built...i dont like some of it, but that is my opinion. If u dont like 2 links so be it...u dont like em, i have never had a problem with mine, and my truck isnt inferior to anyone elses' that is on this site. People do what u want to do, a 2 link costs less then 50 bux to build....(at least mine did). But if u want to be 'cool' in larrys eyes, spend the money and buy a 4 link from him. Im not trying to get into a b!tching match either, just stating that people have their own preferences like what Taylor said 2 link works fine for me, never had any problems. I can already hear it coming. Go forth and bash larry. Last edited by EyePoppin : 06-24-2003 at 01:35 PM. |
#71 |
Pssst.. Got Bags??
I hated my 2 link, i shredded 2 sets fo tires because of that dam*ed thing and i busted 3 universal joints, IMO i would just save some more and have the 4 link done professionally
#72 |
EyePoppin.... Look at this for example...and I am going to exadurate a lil bit to get my point....
Take a 4 link on the back of a truck.... With a perfect pinion angle (we'll say the diff is parallel with the ground at a perfect angle), if you lift the truck up 2 ft with that 4 link....if it a properly built 4 link, that differential will still be parallel to the ground....that is a NO CHANGE in pinion angle. Take a 2 link on the back of a truck.... lets say that at ride height, you have perfect pinion angle, and the diff and bars of your 2 link are both parallel to the ground.... If you lift the truck up 2 ft in the air... your bars are no longer parallel with the ground, and because the way a 2 link is designed, the differential is at the same angle the bars are at, and there for the pinion is NOT CORRECT, and does not remain the same at all heights. I'm not tryin to bash your two link or anything, but I thought this little explaination might help others that don't quite understand pinion angles and such. |
#73 |
Well... you have done nothing to prove your point. But don't worry I will prove mine.
Let's start with this... AND... And lastly, I didn't say buy a four link from me. I sent him to Jason. You need to learn how to read. |
#74 |
Now let me show you gys how little eyepoppin' knows...
Here is a picture of a 22" long four link bar... The end in the vise represents the front pivot point ( and it actually has a bushing in it ) It is level, and the angle finder in reading 0... |
#75 |
And I forgot the picture
#76 |
little pink pink
you guys know what....we all know everyones views and opinions...so why must you keep posting them over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over and over!
STFU ALREADY! |
#77 |
And now same bar... same mounting set up... dropped 15" ( just like eyepoopin' gets )... I apologize for the dirty angle finder, and it's not being readable, but look at the bar angle, and look at the angle finder. see the little red rointer hanging straight down ? It has a white line in the middle for a pointer. now look at the small red pointer off to the left of it. That is ZERO. The bar got 44 degrees of movement. This bar is the bottom nar from one of my blazer four link kits, sao it is pretty close to the length of a two link bar. ( in fact you can see the reast of the parts of the kit behind it. I opened a box and dumped it ou to get a bar to do this. )
And now think of a 2 link design... It piots in the front, and is mounted solidly at the axle. So no matter what... the pinion angle has just as much movement ( degree change ) as the bar. So now eyepoopin'... it is your turn. You wanted to bring this post back up. Do you have anything intelligent to say ? |
#78 |
1 question how many people DRIVE at 15" up? why the hell would the pinion angle matter when yer maxed out????
it would matter where the normal drive height is... |
#79 |
If you and eyepoppin', or anyone else, want's to run a two link, I could care less. But as long as you guys keep telling people that don't know any better, that a two link is good, this will keep coming up. |
#80 |
little pink pink
#81 |
#82 |
#83 |
Eyepoppin says his gets 15" of lift with no pinion angle change. So I used 15" to make a point. And I never said they don't work, go up and read again. |
#84 |
