1st Gen Blazer with 2nd Gen Blazer spindles for C6 Z06 brakes.... - S-10 Forum
post #1 of 27 Old 02-25-2013, 09:19 PM Thread Starter
User is: mexinaction is offline
I have an 88 s10 blazer that will be bagged and laying frame. I already ordered Thor Bros control arms for a 1st gen blazer. I am going to swap the spindles for a ser of Belltech 98+ Blazer spindles and from what I have read it is not uncommon an not a major problem.
Any one else done the c6 zo6 brake swap on a 1st gen?
Seen it done on a couple of 2nd gens
post #2 of 27 Old 02-26-2013, 04:01 PM
Longbeds FTMFW
gunther19820's Avatar
User is: gunther19820 is offline
Re: 1st Gen Blazer with 2nd Gen Blazer spindles for C6 Z06 brakes....
Starting it shortly
http://www.s10forum.com/forum/f143/p...nto-it-490214/<---- my body drop thread
Originally Posted by aaronweisler View Post
I can one up the hummer
Originally Posted by s10xtremist View Post
By blowing bubbles before you swallow?
post #3 of 27 Old 02-26-2013, 06:58 PM Thread Starter
Originally Posted by gunther19820 View Post
Starting it shortly
What setup are you going to run specifically?
post #4 of 27 Old 02-27-2013, 08:18 AM
Longbeds FTMFW
C5 rotors/C6 calipers/Belltech Blazer drop spindles
You can also do this without switching over to the blazer hub-type spindles.
post #5 of 27 Old 02-27-2013, 08:44 AM
JeremyCollins13's Avatar
User is: JeremyCollins13 is offline
^ Do share, please.
post #6 of 27 Old 02-27-2013, 08:58 AM Thread Starter
Really? Everything that I have been looking into has required the 98+ Blazer spindles in order to do the C6 Z06 brake setup. I talked also with Kore3 and they said it would require the 98+ spindles or ATS AFX spindles (which are way overpriced and not recommended as blazers will not be track cars typically).
Do you have any pics or more info of a 1st gen s1-/blazer that uses the 1st gen spindles?
Thanks
post #7 of 27 Old 02-27-2013, 11:59 AM
Longbeds FTMFW
you take old rotors, and turn them down into hubs. Then slide the hat-style vette or LS1 rotors onto them. I believe you have to trim a little of the spindle away, for the abutments to fit. Also, your track width will increase more (to compensate for your newly made "hub").
A good example is Hi_i'm_sean, look in his thread. I believe he is running LS brakes, not vettes. But you can see what he did with the rotors turned to hubs.
A lot of guys do it this way, because it keeps them from having to buy New spindles (especially if you need drop spindles, they arent ****ing cheap). I wanted to keep my overall track width as close to what i have as possible, so I opted to go with the blazer spindles.
Also, why are you sold on it being "Z06"? They only difference in calipers was color of the paint. I think the rotors may have been a little thicker, but their diam is the same.
post #8 of 27 Old 02-27-2013, 12:10 PM
Longbeds FTMFW
http://www.s10forum.com/forum/f30/86...23/index5.html seans thread
http://www.s10forum.com/forum/f14/1s...e-swap-509517/ a thread i started with some info
http://s-seriesforum.com/forum/showthread.php?t=74977 some great info.
post #9 of 27 Old 02-27-2013, 05:45 PM Thread Starter
Rotor Diameters/Thicknesses:
Base: F 325mm/R 305mm
Z51: F 340mm/R 330mm
Z06: F 355mm/R 340mm
ZR1: F 394mm/R 380mm
All (3) variants Rotor thickness (with exception of ZR1): F 32mm/R 26mm
post #10 of 27 Old 02-27-2013, 05:48 PM Thread Starter
Thanks for the info. I am just going to go with the 2nd gen spindles for this setup. I was just wondering what other options there were for a 1st gen.
post #11 of 27 Old 02-27-2013, 05:57 PM
Longbeds FTMFW
all the brake info:
http://lukeskaff.com/?page_id=333
post #12 of 27 Old 02-27-2013, 05:59 PM Thread Starter
Btw Calipers are completely different on the C6 Z06 compared to the Z51 or base.
C6 Z06: Front 6 Piston Calipers, Rear 4 Piston Calipers
C6 Z51 and C5 use the same calipers but the C6 Z51 uses a larger rotor: Front 4 Piston Calipers, Rear 4 Piston Calipers
post #13 of 27 Old 02-27-2013, 06:00 PM
Longbeds FTMFW
There are multiple threads on here talking about the calipers. If you want to pay more for red paint its cool...
post #14 of 27 Old 02-27-2013, 06:01 PM Thread Starter
Yep, good info.
post #15 of 27 Old 02-27-2013, 06:02 PM Thread Starter
you arent listing years man.
My bad, I should have put, generic in there. But I was just trying to put that there are difference other than rotor diameter and paint color between the z06 and base brake systems for a C6 or C5
post #16 of 27 Old 02-27-2013, 06:03 PM
Longbeds FTMFW
I caught the C6, so I edited my post- my apologies
post #17 of 27 Old 02-27-2013, 06:07 PM Thread Starter
haha no problem I was starting to second guess my knowledge there. I was like wtf!! lol
post #18 of 27 Old 02-27-2013, 06:13 PM
Longbeds FTMFW
so the C6 Z06 are 6 pots, while the C6 Z51, C6 base are 4 pots. I also believe the C5 calipers are identical.
Maybe its the C5 calipers that the only difference is color (between the Z06 and base/Z51)
post #19 of 27 Old 02-27-2013, 06:53 PM
twisted metal fab
User is: danshiflet is offline
I have mmw flat uppers with 98 belltech spindles. The caliper hits the control arm when turning and it would compress the caliper. The caliper is moved up higher on the 98+ spindles. I had to reshape the uppers to work.
http://www.s10forum.com/forum/f143/jimmy-drop-466312/
Twistedmetal Fabrication on facebook
post #20 of 27 Old 02-27-2013, 06:56 PM
Longbeds FTMFW
^with what brakes?? I have MMW uppers aw well
post #21 of 27 Old 02-27-2013, 10:22 PM
twisted metal fab
98+ blazer with 2 piston stock calipers and belltech spindles.
problem fixed
post #22 of 27 Old 02-28-2013, 07:57 AM
Longbeds FTMFW
I have the 1 piece flat uppers... lets see how this works out for me.
post #23 of 27 Old 08-15-2014, 02:33 AM
84blaze's Avatar
User is: 84blaze is offline
I'm pulling this up from the dead... but how would the C6 Z06 Callipers work with SD flat plate uppers and Belltech 2102 spindles? I hope the callipers don't bind like the photo above...
84blaze is offline
post #24 of 27 Old 08-15-2014, 08:21 AM
Longbeds FTMFW
84- mine have been fine.
post #25 of 27 Old 08-15-2014, 10:02 AM
squeak's Avatar
User is: squeak is offline
I know this post is old, but aren't all the C6 except z06 and all C5 brakes 2 piston? I know they aren't opposed calipers, meaning it's a floating caliper with all the pistons on the inside of the rotor.
Edit: a little bit of searching came up with this http://www.kore3.com/proddetail.php?prod=10105-02
they are 2 piston calipers.
Instagram.com/stively
squeak is offline
post #26 of 27 Old 08-15-2014, 12:01 PM
Longbeds FTMFW
you are probably right. I was misinformed.
Mine are C5 calipers- 2 piston
post #27 of 27 Old 08-15-2014, 12:43 PM
squeak's Avatar
I'm interested to see some c7 brake swaps, since they use 4 piston brembos.
squeak is offline
