1987 s10 build - Page 8 - S-10 Forum
1987 s10 build
Old 03-28-2013, 12:18 AM   #351
Re: 1987 s10 build
I understand yall are putting yalls opinions forth. And I appreciate the honesty. But the dude has used that tubing before. He told me himself. And theres NEVER been a problem w any of it. Never had any of it bend or break or whatever. Again. Theres no rule anywhere saying that tubing. Or "pipe" is forbidden to use on trucks. Whats the big deal? Leave it alone and let it be. It is staying the way it is. If I had it painted before I posted a pic yall wouldnt know the difference. So please let it go. Hate on it all u want. But theres no point in continuously poating comments bashing it. I like it and thats all thay matters to me.
Old 03-28-2013, 05:43 AM   #352
Registered Asshole
rstadelmaier's Avatar
Re: 1987 s10 build
They are fine. If it were the link bars than I'd be concerned. What diameter and thickness are those link bars btw?
Old 03-28-2013, 10:19 AM   #353
Inferno Fab
flnole78's Avatar
Re: 1987 s10 build
I didn't see a single post of anyone bashing the work that was done. All we did was point out what we feel is a saftey precaution. Its up to you whether or not to do anything about it. This forum is to help people and for people to learn. There are no rules regarding what can and cant be used but there are standards and safety precautions.
Old 03-29-2013, 03:14 AM   #354
Re: 1987 s10 build
I understand all of what you just said. And I appreciate the concern. But the man has used that material on other trucks and never once has had a problem. I'm not concerned w anything. I trust the man who built it.
Old 03-29-2013, 03:26 AM   #355
Re: 1987 s10 build
Here is one of the trucks he did. The truck is beautiful and doesn't have any or never has had any problems with "pipe" or tubing or whatever u wanna call it. I don't mind the opinions and concerns. But the man that built this truck built my back half.. So I'm not worried ab sh*t.
Old 03-29-2013, 04:37 PM   #356
Longbeds FTMFW
gunther19820's Avatar
Re: 1987 s10 build
I know this is beating a dead horse... But still interesting
http://www.jalopyjournal.com/forum/s...d.php?t=133951
"Are there any strength difference between the pipe I can get from the hardware store compared to DOM steel tubing? I'm not sure if I could use the pipe in place of DOM and still retain the strength?
There is a difference in strength between ordinary pipe and DOM tube; for the same OD and wall thickness DOM will be considerably stronger but if you are planning on using the material for the tracks on a router or something like that this is completely unimportant.
The important property for a router application is stiffness not strength and there is a very important distinction between these two properties of material. Strength is a measure of how much force needs to be applied to something before plastic deformation occurs; i.e. it is permanently bent and does not return to the original condition. Stiffness is how much elastic deformation occurs under a given load and when the deformation is elastic the material or structure returns exactly back to the original condition when the load is removed.
With any material under load elastic deformation occurs first followed by plastic deformation when what is called the yield strength is reached. With DOM tube a great deal more load can be applied and a great deal more elastic deformation will occur before the yield strength is reached than with pipe.
Ok I got a question, What is the material difference between black pipe and DOM,I know black pipe has a lacquered finish to minimize rusting, pipe is measured ID, DOM is measured OD, DOM wall thickness is .120 where as pipe is .113, ( BTW I am talking 1" DOM or 3/4 black pipe) whats the metalurgical difference. I want to use black pipe to build a motor cycle frame. I talked to a pro TIG welder and he mentioned that pipe does not weld as good as DOM? Any input.
Black pipe is not suitable for this application; I could say definitely, absolutely not suitable. Black pipe is very low carbon steel with a low yield strength and a low ultimate strength. DOM can be obtained in low and medium carbon steel and in some alloy steels. It has a much higher yield strength and ultimate strength.
Making a motor cycle frame is something that you need to get experienced advice on. Having a weld break or having the frame crumple while you are riding could make life interesting for a short while."
Old 03-29-2013, 04:59 PM   #357
S10's-R-Us
Lowl!f3's Avatar
Re: 1987 s10 build
Lol, pipe is for poop
Old 03-29-2013, 05:53 PM   #358
Re: 1987 s10 build
Good lord I give up. F*ck this
Old 03-29-2013, 06:30 PM   #359
i don't like people
Retro Ten's Avatar
Re: 1987 s10 build
ok again im going with the fact that the bracing between his pipe on his truck is a plus, what i was trying to say before. He has a reverse three link bad idea! Now has any of his trucks been in a wreck? thats truly when black pipe is a bad idea. your truck will be fine but i would brace it up a bit for piece of mind, and again still no one is bashing, and niether am i
Old 03-29-2013, 06:54 PM   #360
needs a cheeseburger
tohoopty's Avatar
Re: 1987 s10 build
well i think the truck is turning out great.
Old 03-30-2013, 04:13 AM   #361
Re: 1987 s10 build
Thanks man
Old 03-30-2013, 04:13 AM   #362
Re: 1987 s10 build
Ok....
How did you hear about us?
Enter a URL or Site name of who refered you to this site. (required. Only admins can see this)
State
Please enter your two letter state name to help other users and clubs find local users to them.(required)
Insurance
Please select your insurance company (Optional)
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
You may post new threads
You may post replies
vBulletin Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
