** 145PSI or 200PSI? what is the Difference? ** INFO
For my numbers I am going to use this setup,
(1) 5 gal tank (1) Viair 480 Compressor (2) 2600 size bags in the front (2) 2600 size bags in the rear ---- First fill time, 110~145PSI switch 0~145PSI = 3 min 58 sec 110~145PSI = 1 min 35 sec 145~175PSI switch 0~175 = 5 min 36 sec 145~175 = 1 min 41 sec 165~200PSI switch 0~200 = 7 min 11 sec 165-200PSI 2 min 12 sec The higher the pressure the more work the compressor has to do, for example, To fill only 10PSI 135~145PSI = 32 sec 165~175PSI = 38 sec 190~200PSI = 43 sec See how the same 10PSI takes longer at a higher pressure? BUT the higher the pressure the more 'air' that is in the tank. For example. Same tank as above. Tank start pressure = 145PSI Fill 4 bags to 100PSI tank will drop to 105PSI ---Drop in pressure =40 Tank start pressure = 175PSI Fill 4 bags to 100PSI tank will drop to 135PSI ---Drop in pressure = 40 Tank start pressure = 200PSI Fill 4 bags to 100PSI tank will drop to 160PSI ---Drop in pressure = 40 The bag will still use the same amount of air from the tank but a tank at an higher pressure will hold more so after the same lift the 200tank can still lift your truck a few more times. Also the higher pressure will 'push' the air through the system faster. Think of it as a hole in a tank the higher the water level the faster the water is forced out of the hole. This is why you hear people say 200PSI is FAST!... It is Things to think about, High pressure PROS: Fast fill speed More fills Small tank size CONS: Compressor runs longer High pressure components are needed You will have more water in your trap and the air will be hotter. Low pressure PROS: Fast compressor refill No special components needed Longer life of components Cooler air with less moisture CONS: Slow system speed Limited play time Larger tank size. One last thing to mention, Tank size remember how I said high pressure has more 'air' ? Let me explain, A 5 gal tank at 200PSI Filling (4) bags twice to 100PSI Final tank pressure is = 120 A 12 gal tank at 145PSI Filling (4) bags twice to 100PSI Final tank pressure is = 112PSI They are equal but the key is now you can have the same play time as a 12 gal at 145PSI with a 5 gal at 200PSI ![]() |
damned 4banger
Re: ** 145PSI or 200PSI? what is the Difference? ** INFO
STICKY IT!!! nice info djd
Maxxsonics Team Captain
djd
great read.. thanks. so, i'm in the middle of building mine now. i've bought everything from a few different people.. i have 2 5 gallon 9 port tanks from avs.. they are rated at 150psi and for comps i have 2 viar 380c's the pressure swtich that came with the tank is 145/175 jerid at sd told me i should have no problem running 175 on a tank that's rated for 150... your opinion?? also, you mention a few times in your post, that higher pressure requires special parts.. what parts do you mean?? i have the two 150 tanks. the two viar's , and 8 smc 3/8 valves. running 1/2 line. front bags are re6 and rear bags are re7 i wont be looking for speed, just play time, and will also be running fill and dump controls to slow it all down. jsut curious if running this pressure switch will be bad, or if it will be ok. and making sure i dotn need any special components. thanks. |
As for special parts. Most compressors are only 145PSI but your 380's are 200PSI Most valves can not operate at 200+PSI your 3/8" SMC's will work intermittent at 199~210PSI 175 is no problem. I hope that helps. |
sweet, so everything i have is kosher.
thanks alot. as a beginner to baggin a truck, i truly appreciate it when someone with more knowledge and experience takes the time to answer what may seem like basic questions, for those of us that are new. |
Happy to help only a few years ago I was in your posision so I understand ![]() |
OT but looks like you know your db's
Do you know the rules well? PM me if you can I have a few questions! |
there he goes again... allways calculating something out.
![]() If i could get you to work on your truck as much as you think about these things... we'd have it bodydropped allready! |
Hardcore 1st Gen'r
cool info man
yes the pressure affects the dump valves.. so make sure you dont go much over 200 psi at all. Doug and i tried this test a few yrs back on my truck. Running all 3/8" smc valves, we filled my tank to about 240 psi then slowwly drained the air out while hitting the switches. the valves wouldnt do anything until we got it down to 209 psi in my air tank. the 1/2" will operate at higher pressures so if anything goes wrong and your comp over fills your tank worst case is you will get stuck up in the air.
un banned
its funny, ive always pondered this in my head. i was waiting for someone to actualy come up with the actual numbers. who else but you, doug
DeXtreme on 20/22's
Doug, why don't you just go ahead and tell the automotive industry how to run alternate fuel at a low cost so we can lower gas prices, we all know you that you can do it. LOL
shhhhh |
damned 4banger
bagged DD on 20's
hondas can do it, but will never look anywhere near as good as an s10 |
Get on your bike and ride
Very informative, only problem is now i have to restructure my air managment system and buy the one more suited for me. But i'm glad to figure these things out before i spend my little bit of money!! Thanks dude!!!
User Registered
< EST 1989....>
ive had 175 in 2600s be4 it was just stupid didnt do anything but make me scared of the bags popin, They were like 3 yrs old and looked rough
