#51 |
Air ride & Audio
Re: 03 Sonoma Bagging Build, Nothing Special
Oh okay. I misunderstood what you were saying.
#52 |
Low Class Minis©
keep up the good work!! its cool to see someone making the best out of airbagit.com junk lol... i built a mitsubishi mighty max about 6 or 7 years ago using airbagit. (was AIM industries then) and it seemed like i never stopped fixing problems with that truck.. it was pretty much a hack job due to the parts..
#53 |
Pewter member
Nice gmc. Please shave antenna. Statement complete.
#54 |
Looking good how much lift do you get in the back with those huge bags it had to use a lot of air lol
#55 |
#56 |
#57 |
#58 |
I only scheduled 2 weeks of work but now I'm on week 4 and only a little over half way through the list of things I wanted to change. I have more pictures but didn't bring my xd card reader.
This is my new avs 5 gallon aluminum tank mounted. I really like how solid this tank is. ![]() I wanted to mount my compressors under the bed and as close to the battery as possible. I ended up picking this spot right between the bed mounts behind the cab. They fit perfect with a little mod to the bed mounts to make some extra room. ![]() Some may disagree but I am still running my compressors through a T fitting with a 225 psi safety valve. At three and a half CFM I should't see much if any difference in fill time with the size tube and pipe I used. ![]() This is my power distribution box located on the frame under the cab. As long as I don't park in 4 inches of water I should never have any problems with it located here. My exhaust and fuel tank will hit the ground before this box ever will. ![]() This is my cluster of passenger side air lines. 3 pressured lines 2 remote filter lines and 1 wire for the pressure switch. On the drivers side I ran 1'' conduit (the same as in this picture) all the way to the trans crossmember for all my electrical wires. It really cleans things up having everything ran through the same conduit. ![]() Now I know this isn't the prettiest thing but it is very functional. This gray waterproof electrical box is where my compressor filters are located. The pvc pipe pointing down is 6'' long with 1 1/8'' ID. This box should prevent any water from ever getting to my compressors. ![]() ![]() On the far left you can see I have my drain plug running into my 9''x12''x12'' valve box to a parker valve. I always hated reaching under the bed to drain water from my tank so I am going to love this valve. I still need to clean up the electrical in this box. I was testing to make sure everything was wired properly in this pic. I also really like my new slow down ball valves. It makes adjusting ride hight so much easier. This valve box does have a cover it just isn't installed in this pic. ![]() Next up is getting some front shocks installed then bodywork. I plan to notch the frame with 2.5'' ID pipe and use Nissan shocks. |
#59 |
Looks great man thats a good idea for the filters , and what kind of box is that for the relays I like it
#60 |
#61 |
Looks really good, I think it was a great choice to voice your opinion with airbagit. Out of curiosity what bags are you running front and back?
#62 |
layed_sdime
![]() Age: 26
^^^ x2 ive never seen bags like that. Do they balloon like the dominators?
#63 |
I agree about running 2 compressors thru a T fitting.Theres so mutch back pressure it really doesnt matter.Not to mention dam near all the filters i've seen can handle wayyyy more cfm than what a couple little viairs can put out.Even at low pressure
#64 |
#65 |
Another junk report. This is my airbagit leader hose after about 6 months of use and never pressured over 140 psi.
![]() Again, don't buy anything from that company. |
#66 |
Here is a look at how my compressor filters are set up in that gray box.
![]() Here is a look at my compressor mount and the clearance the 480s have between the two bed mounts. ![]() ![]() ![]() ![]() ![]() This mount is really strong, I was jumping on it and it didn't move at all. |
#67 |
This is what I'm working on now. I relocated the lower front shock mounts to allow more clearance. I used a piece of wood to align the shock mount to allow the shock to pivot parallel to the control arm. I don't know if it was necessary but I hope it allows the stress to more evenly distribute on that cantilever pin mount. For the pin or lower shock bolt I am just going to use a 1/2'' grade 8 bolt which should be strong enough for what I need it to do.
![]() ![]() The 2.5'' ID pipe takes a huge dip out of the frame. Here is a little preview of upcoming pics. I'll be posting pics of my clearance and what size tire I tested in the pic hopefully before the beginning of next week.
#68 |
SMURF
How do you like the airbagit manifold (air engine)?
#69 |
355 member
I hear it works well, no experience with it
#70 |
Ridin' on Twankies
mine never stuck open or closed, or leaked any air. Most of their fittings suck ass, the leader hoses don't even swivel if i remember right, I think i still have some that are twisted/kinked due to that. but overall the backhalfs, and control arms are built pretty damn beefy. Never gave me any issues, I think Alan can agree with me there. |
#71 |
Put one big ass hole in that frame!!!!
#72 |
#73 |
I also found something new. I believe they use standard bushings in their lower control arms and the S10 uses metric bolts. I went ahead and drilled out the frame and ran standard bolts to prevent any unnecessary play. The guys working at that place are special. |
#74 |
I think I am done with my front shock mounts. I really like the way they turned out and I'm fairly satisfied with the turning radius.
It isn't perfect but I like it. ![]() ![]() I ended up just welding the brake line mount straight to the frame. ![]() I don't know if I can get the shock any closer. It only gets this close at full lift. ![]() Now, I kept a ton of turning radius but it still hits. ![]() ![]() ![]() The tire in this pic is a 225 70 15 on a stock 7'' wide wheel with 3.5'' backspacing. Because the tire is too wide for this wheel it bulges so it is more like 4.5'' backspacing. So If I get a wheel with around 4'' of backspacing I should, or almost, be able to get the tire to the frame. |
#75 |
out draggin.. brb
hey man those sunk shock mounts do look really good. i need to get on doing mine too. Bought the ART brackets but rollin 22'X9.5"s and my wheels hit the shocks instantly so pulled em off. Yours look real good tho nice work
#76 |
SMURF
Shocks look good sunk in. I want to eventually do this too. Got any vids of how well the air bagit manifold works?
#77 |
#78 |
#79 |
Longbeds FTMFW
Shocks look awesome man!
A couple posts up you mentioned you werent sure as to who manufacturers your bags... its airbagit as well. |
#80 |
#81 |
Just some dirty pics. Ignore the horrible headlight alignment, that will be fixed soon.
#82 |
lookin good
#83 |
out draggin.. brb
ya looking good man. cant wait to see you post some rear pics layed out
#84 |
BOOBIES
![]() 2. What paint did u use on ur frame. i realllllly like it. |
#85 |
#86 |
#87 |
Longbeds FTMFW
What size pipe did you use to make your shock mounts?
#88 |
gettin layed
Gunther i used 2 inch and it works fine for a Monroe shocks but i am running RCD Bilstein shocks now and had to cut it out and swap to 2.5 inch pipe....
#89 |
#90 |
Longbeds FTMFW
Thanks guys. I need to do this over the winter to mine.
#91 |
out draggin.. brb
^^ X2
and hope the 22X9.5's will still have plenty of room to turn |
#92 |
Longbeds FTMFW
#93 |
out draggin.. brb
#94 |
Longbeds FTMFW
I keep forgetting you dont have them on the truck now.
#95 |
out draggin.. brb
![]() sry for hi-jacking thread OP. It's all yours now
| Sponsored Links | |
Advertisement | |
