suggested tires size for 20's - S-10 Forum
post #1 of 17 Old 02-17-2011, 12:24 AM Thread Starter
kbarbee00s10's Avatar
User is: kbarbee00s10 is offline
looking at getting some boss 335's 20 inch and i think there 9 inch's wide. truck is dropped 3 in the front w/ djm 3 inch springs. back is 4 inch djm blocks. might trade out for 3 inch leaf springs and 1 inch block. but anyways what would yall suggest for tires on those 20's. not lookin for any rubber bands but not so much tire itll rub on everycorner. if possible i would like for them not to rub at all. is that possible? and what size tires? maybe spacers too?? thanks for the help in advance guys
post #2 of 17 Old 02-17-2011, 01:49 AM
User is: AfflictedPast is offline
Re: suggested tires size for 20's
I have a 5/5 drop on my 92 blazer.
Front is 20x8.5 255/35/20 rear is 20x10 275/40/20.
If I was going 3/4 I would do 245/45/20.
post #3 of 17 Old 02-20-2011, 12:43 AM Thread Starter
all the way around?
post #4 of 17 Old 02-20-2011, 01:06 AM
Needs a new license plate
tonsOfun's Avatar
User is: tonsOfun is offline
Send a message via AIM to tonsOfun
255/35/20 worked well for me
'98 2.2L 5 speed, Front bagged with RE6's and 7" static drop in the rear on MC Exclusive 942 20's, firewall tubbed and trailer fenders.
tonsOfun is offline
post #5 of 17 Old 02-21-2011, 02:18 PM
Originally Posted by kbarbee00s10 View Post
all the way around?
Or you can go 245/45 front and 275/40 rear if you want a wider rear tire. Both will have the same sidewall as well as height.
255/35 isn't enough tire for a 3" drop imo.. I run that size with a 5" drop.
post #6 of 17 Old 02-23-2011, 06:25 PM Thread Starter
tonsOfun good lord ha ur truck is literally exactly like mine when i get my wheels. i am very jelous. good lookin truck son!
post #7 of 17 Old 02-23-2011, 10:29 PM
The WaterBoy
nomacane07's Avatar
User is: nomacane07 is offline
I had 245/35-20 on the front of mine with a 3" drop and that was with 8.5" rims that's about the skinniest tire that would fit it. If your going with a 9" rims your gonna have to go with 255 or 265. You also want to run about a 4"- 4 1/2" backspacing
post #8 of 17 Old 02-23-2011, 10:42 PM Thread Starter
thanks for the help everyone and thanks for the bs nomacane07 was wondering that as well
post #9 of 17 Old 02-23-2011, 10:42 PM
98layinframe's Avatar
User is: 98layinframe is offline
Send a message via AIM to 98layinframe
you guys do realize its a lowered 2wd truck not a lifted truck, that and a 255 35 20 is already the same height as stock a wheel and tire combo...
Either way, a 255 35 20 is about the best fitting size for these trucks without alot of rubbing problems.
These are 245 35 20's on 8.5" wide rims.
post #10 of 17 Old 02-24-2011, 01:58 AM
On a static truck that's only getting lowered 3/4 personally I'd like to see less wheel gap then a 255/35 would offer and he said he wants the most tire he can get.
post #11 of 17 Old 02-24-2011, 02:02 AM
Check your ground
556mm's Avatar
User is: 556mm is offline
Who said anything about a lifted truck?
556mm is offline
post #12 of 17 Old 02-24-2011, 02:04 AM
S10 TIRE/WHEEL MASTER
NORCAL SS's Avatar
User is: NORCAL SS is offline
done this on numerous trucks over the years
the fronts are 20x8.5
255 35 20 on a 3/4 drop
take out the bolts on the top of both fenders and pass side you will see how fender bubbles down on back of fenderwell. Pound that in flat with a mallet and you will be good to go and just on big dips will hit top of fenderwells but nothing to worry about as long as you remove those bolts
any other questions feel free to call me 24/7 415 519 2432 or email me tony@tbssowners.com
DJM LOWERING PARTS GARAGE BLOWOUT!!!
http://www.s10forum.com/forum/f291/d...erally-680138/
If you have any questions on lowering or tire sizes that fit on a s10 feel free to call or text me 415 519 2432 my name is Tony and around to help 24/7. YES 24/7 email norcalss06@aol.com
post #13 of 17 Old 02-24-2011, 08:18 AM
i said that because people are recommending he install a 29" tall tire on a lowered truck... thats 2" taller then stock. not to mention would look retarded with a 27" tall front tire.
post #14 of 17 Old 02-24-2011, 11:37 PM
The WaterBoy
nomacane07's Avatar
Just so we all know the factory 2wd s- series is a 205/75-15 and a 235/55-16 which are both right at 26" tall depending on the brand. So a 245/35-20 is going to be about the closest to stock. If you want a little more sidewall go with a 245/40-20 that will put you at about 27". If you want a little more width go with a 255/35-20 (which is right at 27" tall and 98layinframe said that's the best size even though he said 27" tires look retarded on the front), 255/30-20, 265/30-20, or a 265/25-20. None of these will be much taller than 27" they just get wider. If anything just listen to norcal ss. Sounds like he knows what he's talking about.
post #15 of 17 Old 02-25-2011, 12:05 AM
NORCAL SS's Avatar
thanks for the props but kinda off on your tire sizes
235 55 16 are 26.1
205 75 15 are 27.1 tall (this is why gm says zq8 is 1.5 lower the tires are 1 inch lower and the drop is only 1/2 inch on the springs)
255 35 20 are 27 inches tall about so pretty much same height as stock
with a 3 inch drop 245 35 20 would be good to go.
post #16 of 17 Old 02-25-2011, 01:10 AM
The WaterBoy
nomacane07's Avatar
235 55 16 are 26.1
No problem and my bad on those 235/55-16s lol. Here's a list I found on the good ol internet. Maybe it'll help him out.
20 INCH TIRE TIRES HEIGHT
225/30-20 25.31"
235/30-20 25.55"
275/30-20 26.5"
285/30-20 26.73"
225/35-20 26.2"
245/35-20 26.75"
255/35-20 27.03"
265/35-20 27.3"
275/35-20 27.58"
315/35-20 28.68"
245/40-20 27.72"
255/40-20 28.03"
275/40-20 28.66"
295/40-20 29.29"
305/40-20 29.61"
post #17 of 17 Old 02-26-2011, 10:49 PM
no reread it.. and since it didnt come across well enough.. i ment it would look retarded with 27" fronts and 29" rear tires. Id try to stick with a tire thats alot closer in height front to rear if it were my truck.
