So the blazer needs to be closer to earth...questions
Old 07-01-2008, 02:04 AM   #1
Its Mini Blazin now.
Woody22's Avatar
Woody22 is on a distinguished road
Ok im buying an 01 Blazer on monday. 40K original miles. I have a sick set of kmc 18's for it and i want to do a 5/7 drop. My stupid question is cuz ik there is alot of problems with the spindles could i do it this way > http://store.summitracing.com/partdetail.asp?autofilter=1&part=DJM%2DKS2331%2D3% 2D4&N=700+4294908216+4294925130+4294839061+4294844 590+115&autoview=sku
Any add a 2 inch coil and 3 in leafs?
Any questions or pictures of drop blazers would be killer. Heres the blazer.
Old 07-01-2008, 02:07 AM   #2
Get some
Dvst8r's Avatar
Dvst8r is on a distinguished road
Re: So the blazer needs to be closer to earth...questions
go with belltech. 3 inch coils and 2 inch spindals for the front, 3 inch leafs and 4 inch blocks for the rear. Then a mean alignment
Old 07-01-2008, 02:08 AM   #3
Woody22's Avatar
ya thats my original plan but ive been searching on here about the spindles and all ive hear is shitty things.
Old 07-01-2008, 02:11 AM   #4
Get some
Dvst8r's Avatar
nope. Suicide doors wouldn't sell them if they weren't the best. But if not try AIM. I heard sh!tty things about their spindals but i've been running them for 5 years and had them on 4 trucks without a problem.
Old 07-01-2008, 02:15 AM   #5
Woody22's Avatar
No thanks on aim.
Old 07-01-2008, 02:17 AM   #6
Get some
Dvst8r's Avatar
To each his own.
Old 07-01-2008, 02:38 AM   #7
Woody22's Avatar
seriously. i can't wait to drop this thing. its like a damn monster truck compared to my dime. lol
Old 07-01-2008, 02:45 AM   #8
Get some
Dvst8r's Avatar
Iv'e always liked the 2 doors.
Old 07-01-2008, 06:48 PM   #9
I.G.'s FTW!
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
What problems is that? You can't add drop coils to DJM arms so 3" is all you're going to get. The arms are worth about 5 cents anyway.
A 5/6 will probably level it out better. Here's what I'd do:
2" spindles, 3" coils (your a-arms will smack the frame on big dips), lean spacer, 3" leafs, 2" JTR blocks, 3 deg. JTR shims(I'm guessing), JTR setback plates, and a custom or SD notch. That'll give you roughly a 5/5.5 this will give you a slight rake.
Mine is dropped 4/4.5 using 2" Belltech spindles, Lean spacer, 2" DJM coils, pulled leaf, 2" JTR blocks, JTR Setback Plates, JTR 3 deg. shim, and a custom notch w/ nitro 2's. Rides better than factory.
http://www.jagsthatrun.com/Pages/Par...ng-Blocks.html
Also I've ran Summit brand shocks and Belltech Nitro 2 shocks and I like the Nitros a lot better.
The only thing wrong with them is the price.
But if not try AIM.
All they have that I'd run is the SS mirrors.
Old 07-02-2008, 12:45 AM   #10
Woody22's Avatar
ok cool. how far can i drop it without notching the frame. im guessing a bolt in notch is in order for that...
Old 07-02-2008, 04:04 AM   #11
I.G.'s FTW!
ZQ8 Blazer's Avatar
Probably 3.5" mine bottomed out at a 4" drop w/ everything clearanced. I finally built my own notch out of some thick ass steel and welded it in. I have about $5 in it
You can also get the SD notch, but it's like $100.
BTW I don't understand you question all the way. You want to know how far you can drop it w/o notching then you say a notch is in order for that. I'm lost.
Old 07-02-2008, 01:05 PM   #12
Woody22's Avatar
my first question was how far can i drop before a notch.
then im guessing for a 6" drop im gona need a notch...sry i wasn't more discriptive
Old 07-02-2008, 03:41 PM   #13
I.G.'s FTW!
ZQ8 Blazer's Avatar
You can probably go 3.5" w/o a notch (2dr's are a little different than 4dr's) So yes with 6" you'll need a notch.
Old 07-05-2008, 08:29 PM   #14
Woody22's Avatar
sweet deal. thanks guys. look for a project thread starting prolly around tuesday or wed sometime.
Old 07-06-2008, 08:27 PM   #15
Good Bye SonomaST
91sonomast's Avatar
91sonomast is on a distinguished road
idk if i would do a 5/7, a blazer already sits level if not a little lower in the rear also, maybe a 5/5
Old 07-06-2008, 08:34 PM   #16
BOUGHT NOT BUILT
purplepassion's Avatar
purplepassion is a splendid one to beholdpurplepassion is a splendid one to beholdpurplepassion is a splendid one to beholdpurplepassion is a splendid one to beholdpurplepassion is a splendid one to beholdpurplepassion is a splendid one to beholdpurplepassion is a splendid one to behold
is that one a 5-speed? im guessing it is, since its a base model
Old 07-06-2008, 08:51 PM   #17
Woody22's Avatar
yeah its a 5 speed. not power. but im ok with that. i don't ever roll down the windows...lol
Old 07-06-2008, 08:59 PM   #18
BOUGHT NOT BUILT
lucky.
mine is a base model too. the only options mine has is rear defrost and automatic, but mine is a column shift
Old 07-06-2008, 09:51 PM   #19
I.G.'s FTW!
ZQ8 Blazer's Avatar
My 98 was 1" higher in the rear. I 5/7 would take it down too low though.
lucky.
I wonder how hard it'd be to convert it to power? On my 94 fullsize it was easy, I just got all the components, bolted them up, hooked the harness in and ran it through the door jam, and installed the dash harness for it.
Old 07-06-2008, 10:18 PM   #20
this website is lame!
bmxbang's Avatar
bmxbang is an unknown quantity at this point
5/6 will sit perfect, i am at that level with no notch.... dont do that i only can run a half of tank and have a quarter of an inch clearance before my axle hits the frame. im notching it in the coming weeks.
blazers suck spindels arnt cheap but theres nothing wrong with them whatsoever.
Old 07-06-2008, 11:03 PM   #21
Woody22's Avatar
i have most of the parts on order. just need leafs...and a notch. so it will still be a few more weeks before i install all of the stuff. i want to do it all at once so im not tearing it apart 15 billion times. lol yeah i don't mind not having power windows...im getting tint all around this friday so i can actually drive it and feel comfortable...lol
Old 07-07-2008, 12:56 AM   #22
I.G.'s FTW!
ZQ8 Blazer's Avatar
Holy shit I can't believe you've went this long w/o a notch I couldn't take that.
What %? I know this one guy that puts 5% on everything. He has to roll the windows down when he's pulling out at night just so he can see.
Old 07-07-2008, 01:06 AM   #23
i wouldnt undertsand
Wicked Mayhem's Avatar
Wicked Mayhem will become famous soon enough
back up camera FTMFW! plus as im gettin in my blaze at night i kinda look around n make sure no one is walking down the street i can b ack over
and 5/7ish here.. its 2" spindles, 3" coils, 3" leafs and 3/3.5" block/shim/setback plate. and i got a huge ass sub box for 2 15's that brings the back down. and im notched and i hit inside it if i turn the corner with any kind of speed or any kind of bump. so air shocks ftw! the front is still setteling. i had the front all cleared from rubbing inners but recently the tire started hitting the inners on big bumps.
pic whore time!
before air shocks..and the rear end jacked up so it does sit a little lower on the ground
Old 07-07-2008, 01:15 AM   #24
I.G.'s FTW!
ZQ8 Blazer's Avatar
Makes me wish I still had my 20's
What's the piece of jagged metal sticking out between the u-bolts in the 7th pic?
No I mean like when he's at an intersection he can't see headlights of cars until they're right up on him.
Old 07-07-2008, 01:25 AM   #25
No bags, still DRAGS...
1fast4by's Avatar
1fast4by is on a distinguished road
Id damn near kill for a 2wd 2dr 5spd Blazer...Damn near kill....
Old 07-07-2008, 01:31 AM   #26
I.G.'s FTW!
ZQ8 Blazer's Avatar
I'd like to have one to. I miss having a stick shift.
My wifes got an 08 Altima coupe with shiftronic, but it's just not the same...
Old 07-07-2008, 02:57 AM   #27
Woody22's Avatar
wickedmayhem. your the reason why i bought a 2wd 2dr blazer. it looks so sick and not alot a poeple have them. and even less have a 5 speed with 40 thousand miles.
As for the tint i think im gona do 5 on the rear windows and like 30 on the front.
Also i think im going to do a 5/7 cuz i like the look of the rear end sittin a little lower than the front....its static cali lol
Old 07-10-2008, 02:33 AM   #28
Woody22's Avatar
Project thread ladies! http://www.s10forum.com/forum/f30/pr...blazer-360265/
Old 07-10-2008, 02:44 AM   #29
I.G.'s FTW!
ZQ8 Blazer's Avatar
I have a penis
Old 07-11-2008, 08:07 PM   #30
its when i had the flip kit on it. i didnt cut it off all the way.
and he must have something darker than 5% or he's blind as ****. i have 5% all around.. and everything minus the door windows has factory tint so its really darker than 5%. i can see lights just fine in mine at night.
Old 07-11-2008, 09:00 PM   #31
I.G.'s FTW!
ZQ8 Blazer's Avatar
Oh ok.
I know nothing about tint. He told me it was 5% but I rode in it too and you can't see anything at night. I'm surprised he hasn't had a wreck yet.
