bellcranks no more
pinion angle measuring locations
since there have been some questions as to WHERE to measure from for pinion angle corrections,
this below diagram applies only for 1pc driveshaft trucks. this means all std cab shortbeds, 2nd gen std cab longbeds, all blazers. if you have an ext cab of any sort, or a first gen (pre 93) longbed truck, ignore this diagram. ![]() for 2pc driveshaft owners, see this thread http://www.s10forum.com/forum/f12/pi...xt-cab-184873/ while i have your attention, i will repeat what i always say. no matter if its a mild drop or a slammed or bagged truck, ALWAYS measure your pinion angles and correct them, as it will wear your ujoints mostly, but it can wear away more expensive parts such as your transmission and rear end, and believe it or not, theoretically it can wear your rear tires and brakes as well. you can pick up the angle finders at most good hardware stores (home depot is not a good hardware store) or harbor freight also has them for just about $5 well worth the cost. http://www.harborfreight.com/cpi/cta...emnumber=34214 |
Re: pinion angle measuring locations
so why do you have the rear end pointing down so much? everything that ive read allways tells you that with a single piece driveshaft that uses regular u joints (not cv joints) should have the angles within 2* of each other and the angles should be equal but opposite. So shouldnt your rearend be at 0* also in that pic??
bellcranks no more
technically you want the "correct angle" purely based on efficiency of the universals, the matching angles would be good, but due to flex and compliance, i have read you want to have some downward angle on the diff side, because under acceleration you will have the pumpkin twist "up", where it should match the trans output angle. so say your leaves allow for 4 degrees of pinion angle change due to moment from the tires (extreme case) so then if your static diff angle is down 2 degrees and the tranny is at 0 degrees, under acceration, the diff angle goes to upwards 2 degrees. something like that. 3 degrees may be excessive, but it really depends on the compliance. even with linked setups, you want a small amount of downward angle at the diff as opposed to a weak leaf pack, but there will ALWAYS be compliance. as for braking, im assuming the opposite is not as critical because of weight transfer etc. i cannot say how much downward angle you would want, but within reason, you always want more downward at the pumpkin compared to the trans, than upwards. *to save my ass if im way off* -the 3 degrees was just a drawing. not to be though of as the ideal difference lol |
ok that makes sense with the spring wrap and all..
So how do we go about correcting the problems if we find them? What about the blocks that have the pinion angles already in them?
bellcranks no more
I'll do it tomorrow maybe
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() ![]() |
Measuring points for 2 piece shafts with 1 u-joint and 2 double cardan joints (CV joints)
Tranny output shaft ![]() First drive shaft ![]() Second drive shaft ![]() Rear pinion ![]() |
Registered Asshole
are we supposed to be able to read the gauge in every pic or what?
Nope. Just reference points for taking measurements.
Starting from scratch...
Thanks for the info, gc3 and terryl. I know there's plenty of threads about pinion angle around here, but this one breaks it down into simple pictures I can understand. The pretty colors are nice to!
bellcranks no more
i forgot to bring the angle finder to belletire today when the truck was over the pit getting aligned...... dammit. and noone there had one lol so i guess i have to crawl under the truck still |
They P'd on my F'n rug
So terryl... Wanna sell that catalytic converter in your pics? I'll give ya $10 for it.
Damn, waited 10 min (exactly) to edit my post
I think I might measure mine to see what it's like, although I'm still not getting front bump stops Thanks for the how to. |
Im having a problem with vibration of the driveline on my truck found this to be helpfull.maybe it will help others
