Ok, how does this sound as far as a 3/4 drop?
Old 07-01-2008, 03:23 PM   #1
"Da Dog"
greatdane68's Avatar
greatdane68 is on a distinguished road
Ok, after a little more research, I've decided against the DJM control arms. I called a tech, and all he could tell me was that they fit good with the stock wheels. Besides, some of you were right, I may want to go lower later, and this way all I'd have to do is change the springs out.
So how does this sound; DJM spindles and 1" drop springs for the front, Belltech leaf springs and 1" blocks on the rear.
Now, do I go with Toxic or Belltech shocks? And do I still need to get a pinion shim kit? The truck will be an extended cab.
Isn't it funny that I'm doing all of this research for a truck that I don't even have yet?
Old 07-01-2008, 03:50 PM   #2
Don't tread on me.
Petterle's Avatar
Petterle is an unknown quantity at this point
Re: Ok, how does this sound as far as a 3/4 drop?
if you have an ex cab then yes, you need pinion shims. and a spacer for your carrier bearing since ex cabs have a 2-piece driveline, i think djm sells the spacer. i would also get the crossmember too since the stock one hangs down wayyyy too low, suicide doors makes one.
Old 07-01-2008, 03:58 PM   #3
"Da Dog"
Does that crossmember bolt-in? And could you send me a link to that?
Old 07-01-2008, 04:03 PM   #4
Don't tread on me.
Petterle's Avatar
http://www.suicidedoors.com/S10CarrierBearing.php
Old 07-01-2008, 06:51 PM   #5
I.G.'s FTW!
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
If you can get your blocks and stuff here:
http://www.jagsthatrun.com/Pages/Par...ng-Blocks.html
Yes you'll need shims and IMO Belltech Nitro 2's are way better.
Old 07-02-2008, 12:34 AM   #6
Wanna see some magic?
01cherryreds10's Avatar
01cherryreds10 is on a distinguished road
You can save some money and pick up the Summit shocks from their website. greencactus3 usually reccomends them.
Make sure you get the angled blocks also. And the crossmember is pretty simple to install, make sure you do that before you drop it.
Old 07-02-2008, 12:37 AM   #7
I.G.'s FTW!
ZQ8 Blazer's Avatar
www.performancecenter.com
Has the cheapest prices on Belltech stuff. Got all four of my shocks there for like $130 shipped.
Old 07-02-2008, 03:50 AM   #8
"Da Dog"
Thanks guys! I really appreciate the help. Hopefully I'll get all of this new house stuff out of the way soon so that I can start looking for a new truck. Otherwise I won't be able to start looking until Spring.
Old 07-05-2008, 12:32 AM   #9
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura aboutterryl has a spectacular aura about
What ever you end up doing, when you get it done, measure and check your pinion angle to see if you used the right angled shims. You may need to make a correction with different degree shims and won't know until after the drop is done. And get an alignment!
Old 07-05-2008, 07:16 AM   #10
I.G.'s FTW!
ZQ8 Blazer's Avatar
Yeah and face the shims the right way
Old 07-05-2008, 09:23 AM   #11
"Da Dog"
Um, the alignment is a no-brainer. I wouldn't do a drop without getting one afterwards. I will have to remember to face the shims the right way though. It'll be something that I'll put in there wrong, I always do.
Old 07-05-2008, 08:29 PM   #12
terryl's Avatar
Just don't take measuring to check the pinion angle lightly. Those double cardon joints are expensive to replace.
Old 07-05-2008, 08:44 PM   #13
I.G.'s FTW!
ZQ8 Blazer's Avatar
Really? I'm used to paying $20. How much is expensive?
Old 07-06-2008, 12:58 AM   #14
"Da Dog"
Yeah I know. I used to be an assistant manager at Advance Auto Parts, and I remember how expensive those things were. I think that we had to order them too.
Old 07-06-2008, 01:22 PM   #15
terryl's Avatar
Not the double cardon joints in the two piece drive shafts.
Old 07-06-2008, 08:25 PM   #16
I.G.'s FTW!
ZQ8 Blazer's Avatar
Answer my question bitch
Old 07-06-2008, 11:17 PM   #17
terryl's Avatar
I don't know. I keep my pinion angle right!
Old 07-07-2008, 12:52 AM   #18
I.G.'s FTW!
ZQ8 Blazer's Avatar
Mine makes this real loud clank noise every time I put it in gear, the other day I put it in drive the rear u-jount broke and so did the 2 flanges, the driveshaft just dropped to the ground. I duck taped it all back together and it works great now!
Old 07-07-2008, 10:25 AM   #19
tiresmokinV8's Avatar
tiresmokinV8 is on a distinguished road
I seriously hope your kidding about the duct tape thing.
Old 07-07-2008, 05:13 PM   #20
I.G.'s FTW!
ZQ8 Blazer's Avatar
ha ha I was kidding about it all
Page generated in 0.19184 seconds with 12 queries
