Need help lowering!!
Old 08-21-2008, 06:19 AM   #1
99 SoNoMa is on a distinguished road
I'm new to this web site but have already found out tons of use full info, but i want to lower my stock sonoma but still have enough room to clear 18's or 19's. What would ya'll suggest as far as brand, how low, and what parts will i need because bagging is out on how much i use my truck bed. I may can do ome trading on some 18's if anyone has a lowering kit or parts. Thanks for the help and info. Cory
Old 08-21-2008, 10:54 AM   #2
The How-To Guy
beandip's Avatar
beandip has much to be proud ofbeandip has much to be proud ofbeandip has much to be proud ofbeandip has much to be proud ofbeandip has much to be proud ofbeandip has much to be proud ofbeandip has much to be proud ofbeandip has much to be proud of
Re: Need help lowering!!
Welcome to the forum!
well here is a tire fitment chart to help you find out how low you can go with the size tire you have.
http://www.s10forum.com/node/47
as far as brand, Belltech, DJM are the most popular and im guessing you could probably do a 3/4 drop or a 2/3 drop.
with spindles and blocks you do not need shorter shocks, but with springs and leafs you do need shorter shocks or else your factory ones will go bad.
also is your truck an extended cab or regular cab? if its an extended cab you will need to get angled blocks and check your pinion angle, if its regular cab you need straight blocks and you could possibly need setback plates to prevent the drive shaft from bottoming out into the tranny (wont know until you drop it)
summitracing.com has all the drop parts you need and this thread here ---->http://www.s10forum.com/forum/f12/co...numbers-95599/ will help you find the parts at summit if you cant seem to find them.
Old 08-21-2008, 11:10 PM   #3
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura aboutterryl has a spectacular aura about
Good summarized info. ^^
Old 08-22-2008, 04:01 AM   #4
Which is better spindle's and blocks or spring's and leaf. My truck is an ext cab.
Old 08-22-2008, 05:25 AM   #5
nemesis8's Avatar
nemesis8 is on a distinguished road
use spindles and blocks so you can keep the stock shocks
Old 08-22-2008, 07:18 AM   #6
I.G.'s FTW!
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
Here's the cheapest place for Belltech stuff
www.performancecenter.com
Old 08-22-2008, 09:37 AM   #7
The How-To Guy
beandip's Avatar
im not sure about that... that site has belltech spindles at $164.14 (free shipping)
summitracing.com has them for $149.95 with $11.75 handling so $161.70 shipped.
not much difference but im cheap
Old 08-22-2008, 11:12 PM   #8
I.G.'s FTW!
ZQ8 Blazer's Avatar
^well they're usually the cheapest anywhere, they're about $30 cheaper than summit on Blazer spindles, and a lot cheaper on their leafs as well.
Old 09-09-2008, 04:34 AM   #9
Is belltech the Best???
Old 09-09-2008, 09:00 AM   #10
Dropped 3/4
Driveway Kustomz's Avatar
Driveway Kustomz is an unknown quantity at this point
i wouldnt say best, but belltech is a trusted company that makes good quality products, I pieced my drop kit using belltech
Old 09-09-2008, 12:31 PM   #11
I.G.'s FTW!
ZQ8 Blazer's Avatar
Yeah DJM, McGaughy's, and Belltech are all on the same level. Just don't go with Chassis Tech or Bullit
Old 09-09-2008, 09:11 PM   #12
Useless posting member
Wrkn prgs's Avatar
Wrkn prgs will become famous soon enough
How good are your stock shocks? If they are worn, you should go ahead and get drop coils. If they are good, get spindles.
Old 09-17-2008, 03:56 AM   #13
Are coils better? and either way should i go with blocks in the back?
Old 09-17-2008, 09:09 AM   #14
rican 25's Avatar
rican 25 is on a distinguished road
I was told if you want better ride quality to go spindles and leafs.... I dont guess there is really a better way to lower it as both ways will get you low, its just how you want to ride after you lower it.
Old 09-17-2008, 11:30 AM   #15
Wanna see some magic?
01cherryreds10's Avatar
01cherryreds10 is on a distinguished road
Drop leafs are so much nicer than drop blocks as far as ride quality, I wish I spent the extra cash when I first dropped my truck. Blocks suck, but they are cheap.
Page generated in 0.14376 seconds with 12 queries
