leaf spring causing vibration? - S-10 Forum
post #1 of 3 Old 12-26-2004, 01:48 AM Thread Starter
black culture thief?!
truckramrod's Avatar
User is: truckramrod is offline
Send a message via AIM to truckramrod
I had a problem where my U-joint went out and my D-shaft hit my gas tank, muffler, frame and the ground at a high rate of speed like 80 mph. I have gotten the D-shaft retubed and balanced with all new U-joints and a Carrier bearing. The BAD vibration from 25-40 mph stopped and the rear view mirror stoped vibrating at highway speeds, but there was a very slight vibration at around 70 mph. That vibration is starting to get worse and I am about to go on vacation 150 miles each way and I don't feel like putting up with an annoying vibration for 3 hours at a time.
So my driveline is stock except for the fact that I have a rebalanced driveshaft AND my passenger leaf spring LEAF CLAMP in front of the spring is bent open and can no longer effectively clamp the leafs together. If you jack the truck up with the tire off the ground you can wiggle that middle leaf from side to side. Would that cause the vibration?
BTW I have my two stock winter tires on the back that I just balanced myself at school and I am about to balance my other two summer tires and put them on the back and move the stock tires to the front.
I plan on installing my ZQ8 springs tomorrow if I have time, but I am hoping the new springs and used shocks will fix the vibration. What do you all think? I have read up on other threads concerning this but all they mentioned is the Ubolt being loose causing a vibration.
Please respond back soon guys! I appreciate your help!
R is for RACE right???
95 Ext cab red 4.3TBI 5spd ZQ8+2/3 drop Caddy/K&N CAI,Taurus Efan, Flowtech Afterburner/ gutted cat...
Kappa60.5cs comps (everything else was stolen)
Coming : repairs and zq8 wheels
post #2 of 3 Old 12-26-2004, 02:09 AM
mildkustom00's Avatar
User is: mildkustom00 is offline
Re: leaf spring causing vibration?
If you can move the center leaf from side to side, your u bolts are not tight enough, and also the center bolt that goes through the leaf pack is not tight enough. When both of these are tight, there should be no way that any of the leafs can be moved around. As for your vibration, i seriously doubt that the spring is the problem. You need to check your pinion angle and correct it if necessary. This is what causes vibration. And this vibration probably also caused the u-bolts and spring bolt to loosen over time. Correct the pinion angle and you shouldn't have any more problems.
2000 Space Blue Ext. Cab, 3/4 drop, billet grille, cowl hood, SS gen 3 front valance, 15" American Racing Salt Flat Specials w/ knock-offs
post #3 of 3 Old 12-26-2004, 11:32 AM
Hates 'know-it-alls'
User is: grndscrpr03 is offline
Send a message via AIM to grndscrpr03 Send a message via Yahoo to grndscrpr03
I would definately get it fixed before you go on vacation cause chances are the driveshaft will not hold up for that long of a drive. My buddy lost his driveshaft due to the pinion angle being off and did the same damage as your's did only his also busted the rearend and took out a rim and tire in the process. He was about 7 hours from home too, so it's not something you want to go through.
