LCA question
Old 07-03-2009, 02:42 PM   #1
Short Tempered Smartass
midwests10's Avatar
LCA question
yes i did search the how to for this thread... i have a 03 s10 for some reason i cannot get the LCA to come out of its mounts, all the bolts are out of it i have the shock removed do i have to pry it down or is there a step i missed?
Old 07-03-2009, 02:58 PM   #2
Riding High 2wd
BillsDuster's Avatar
Re: Lca
My lower arms pretty much fell out when I took the bolts out. Just pry them out there is nothing to hurt. It'll come out, to aid in installing wack the frame brackets where it goes in a couple times with a hammer to open it up a bit.
Old 07-03-2009, 03:09 PM   #3
midwests10's Avatar
Re: LCA question
k thanks much didn't want to mess something up
Old 07-03-2009, 03:26 PM   #4
midwests10's Avatar
Re: LCA question
recap of the how too.
1. take the top bolt off the shock.
2. take bottom shock bolts out.
3. remove shock.
4. remove front lca arm bolt
5. remove back lca arm bolt
6. Lca should lower down...
i tried prying on my to lower i put a cheat bar in there and litterally jumped up and down on it and nothing...
Old 07-03-2009, 05:01 PM   #5
midwests10's Avatar
Re: LCA question
problem solved. it was pushed into the chaise one side done will post pics when finished
Page generated in 0.55695 seconds with 31 queries
[Output: 52.72 Kb. compressed to 50.03 Kb. by saving 2.70 Kb. (5.11%)]
