Just starting
Old 10-26-2009, 09:33 PM   #1
Just starting
Dropped it 3/4 with stock size tires. Looks a little weird I know lol. What kinda rim and size tire do you guys think I should use? Kinda wanna stick with something stock. Like off a camaro or firebird etc. thanks
Old 10-26-2009, 11:15 PM   #2
You...Tonight
mostizzle's Avatar
Re: Just starting
1970 camaro z/28 rims, 15x7 with skinny ass 205/65/15's
Old 10-27-2009, 12:48 AM   #3
Re: Just starting
How much drop do you have?
Old 10-27-2009, 11:23 PM   #4
You...Tonight
mostizzle's Avatar
Re: Just starting
its at 4/6 almost 7 in the back. i'll be bringin the front down another inch or so to level it out soon
Old 10-28-2009, 12:56 AM   #5
hrspwr454's Avatar
Re: Just starting
i think it looks pretty good as is
Old 10-28-2009, 09:50 AM   #6
keepin it freshhh
Nitemare's Avatar
Re: Just starting
15x7 camaro wheels 3/3 235-60-15
16x8 camaro iroc wheels 5/6 245-50-16
16x8 zq8 wheels 5/6.5 235-55-16
15x7 swirls 3/3 205-55-15
15x7 steelies 5/6 205-65-15
Old 10-30-2009, 12:55 AM   #7
Re: Just starting
well since it is a 4x4 im assuming with those wheels and the external tire carrier...i would run some vette wheels maybe a 17x9.5 ZR1 with 285/40 all the way around which is shorter than the stock tire size by a lot...or you could try 18x8.5 and 18x10.5 c6 z06 wheels from finishlinewheels.com and run a 245/40 and 285/40 which would leave the sidewalls almost perfectly straight or a tad stretched outward..kinda depends on your tire fitment preference, if you are ok with a shorter tire id do the 18in wheels with 255/40 and 295/35 on the 8.5 and 10.5in wheel..that would look slick
Old 11-06-2009, 12:15 AM   #8
Re: Just starting
How would these rims look on my truck? What do you guys think? There only 15 inch but i can pick them up for 400 with rubber. The rubber is 223/50/15.
Old 11-06-2009, 01:05 AM   #9
keepin it freshhh
Nitemare's Avatar
Re: Just starting
tire to skinny
Old 11-06-2009, 01:09 AM   #10
You...Tonight
mostizzle's Avatar
Re: Just starting
hold off man cuz those rims are booty
Old 11-06-2009, 01:10 AM   #11
02_NomA's Avatar
Re: Just starting
20's for ya! overall diameter of the whole tire is same as stock tires.
Old 11-06-2009, 01:16 AM   #12
keepin it freshhh
Nitemare's Avatar
Re: Just starting
stock tires are too tall he is lowered
Old 11-06-2009, 01:30 AM   #13
Re: Just starting
Ya my front is rubbing really bad lol.
Old 11-06-2009, 08:05 PM   #14
You...Tonight
mostizzle's Avatar
Re: Just starting
i like havin my front rubbed lol
Old 11-06-2009, 08:09 PM   #15
David
-YumYum97s10-'s Avatar
Re: Just starting
I see what you did there
Old 11-06-2009, 08:39 PM   #16
02_NomA's Avatar
Re: Just starting
i realize his rubbing... and so am i .. but its not that big of a deal. just remove the inner wheel well bolts directly above the tire.. one on each side.. then it wont sound as bad lol
Old 11-07-2009, 12:57 AM   #17
You...Tonight
mostizzle's Avatar
Re: Just starting
Old 11-07-2009, 02:22 AM   #18
keepin it freshhh
Nitemare's Avatar
Re: Just starting
ur stoopit
Old 11-07-2009, 04:33 PM   #19
Re: Just starting
Last night I wrecked my outer fender just by cornering to fast lol.
Old 11-07-2009, 04:47 PM   #20
02_NomA's Avatar
Re: Just starting
well mines comes no were close to my fender lol, and no im not stoopit, plus its not like it uber bottoming out when it does rub.. actually its minimal, its mostly the rear cause i havent gotten around to cutting out the bump stop brackets
Page generated in 0.59511 seconds with 31 queries
[Output: 100.92 Kb. compressed to 92.94 Kb. by saving 7.97 Kb. (7.90%)]
