Xtreme Measures
Installing spindles HELP!!!!
Alright i have been fighting these darn things forever. i have all 3 bolts on the spindles off. How the hell do i get the damn spindle out of there? I just removed the shock and i cant get this damn spring compressor to work on my stock spring. If i could get that to work i would just unbolt the lower a arm. could someone give me a quick how to on getting the spindle out of there? Im trying to replace the coils too. I have a 2in drop coil and 2 in drop spindle.
Its a Blue thing.
Re: Installing spindles HELP!!!!
BFH or a pickle fork.
and chips
see post #14
http://www.s10forum.com/forum/f198/h...6-drop-121091/ also there is no need for a spring compressor. |
Put a floor jack under the lower A-arm and compress the spring.
I'll do it tomorrow maybe
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() |
Ding Fries Are Done
Big pry bar between the spindle and a-arm and a sledge the the side of the spindle where the hole for the balljoint is.
Xtreme Measures
Thanks guys. I called nick zigatis and he said to beat the hell out of the lower control arm w/ a bfh or use a pickle fork. I didnt have a pickle fork nor did i have a ride to get one. so i beat the hell out of the lower control arm and it finally fell a half inch onto the jack. Then i took a rachet tie down strap and wrapped both springs to eachother and a little play in the strap. lowered the control arm and yanked the spring out enough to where there was no tension on it. released the strap and pulled it out. The other side was a breeze i spend too long dicking w/ it trying to get the spindle out.
I have a 2 inch drop spindle, 3 inch drop spring for a V6 and i have a 4 banger so its about a 4 inch drop all together in the front and a 3 inch drop spindle in the back. Im scraping my front bumper a lot now. oh well the part thats scraping will wear off eventually lol. |
Xtreme Measures
I need to post some pics but first, I got on the highway today. Theres a metal grinding noise when i let off the gas around 60+ mph. It pulls to the right so i need an alignment. But im worried about the grinding noise. anyideas?
Ding Fries Are Done
Did you trim the dust shield?
I can't really think what'd be doing that in those conditions |
Xtreme Measures
<- nose bleed section
Location: oklahoma city, oklahoma User is: OffLine ![]() |
I got an alignment at hibdons for like 60$
Ding Fries Are Done
I think it rubs the upper a arm, but it's been so long I can't remember.
Takes 30min-1hr depending on afew things. Call around for a price. i pay $40 |
I AM CANADIAN
The lower control arm rubs the dust shield, you should cut out about a 1x2" piece on the very bottom so it never rubs.
Ding Fries Are Done
That's right I had to trim my UCA that's what I was thinking about
bellcranks no more
no, grinding or squeeling noise is most likely not dust shield...
if it was the dust shield it would be more a squeek or screech per bump. not something you would describe as metal grinding.... did you repack your bearings? |
Ding Fries Are Done
bellcranks no more
could also be the brakes.
although not tooooo likely. |
I AM CANADIAN
well regardless.. you still should trim the dust shield, it will rub. What about brake pads? they could be worn causing the squeal piece to hit the rotors, you can bend it back but it's better to replace the pads.
I shaved my ass.
Location: Fairfield, People's Republic of Kalifornia User is: OffLine ![]() |
When I put my spindles in, the dust shield ended up rubbing on the back side of the rotor on one side. Pried it back a bit with a screwdriver and it's good to go now. Also if you have a reg. cab check to see if the driveshaft is bottoming out in the transmission. If so you'll need set back plates.
Xtreme Measures
But ill trim the dust shield and get an alignment tomorrow. I think my front end is lower than i want it though. Im bottoming out on alot of stuff. Even large bumps on the highway the front bumper scrapes the ground. It doesnt sound like the squealers on the pads. The pads were fine it sounds more like a thin piece of metal that has something rubbing up against it. What kinda noise would it make if the driveshaft was bottoming out on the tranny? |
im guessing it would be the 3 inch spindles in the back according to your second post...LOL..just playin
Xtreme Measures
Ok so i went to firestone today and they said they couldnt do an alignment. This is total b/s. My tires are wearing fAST! Its toe'd the fauk out bad there are already bald spots on my tires. 200 miles of driving i drive 100 miles a day. 2 days and bald spots and no one wants to touch it.
bellcranks no more
#24 |
Xtreme Measures
#25 |
Huh?
When I did my spindles last summer, I went to about 6 different places before I found a place that would do it. One place said it was too low to get on their rack with a 3/4 drop, the dealer said they would need the specs before it was lowered, one place wanted to charge an outrageous amount for a camber kit that I didn't need. I ended up at a Goodyear shop for 60 bucks. If you can do it yourself, than don't hesitate.
#26 |
Ding Fries Are Done
The only problem I have had is with my bagged truck, one told me it may not stay aligned, but I just told them to do it like they would a dropped truck and it was fine. Another told me it was "impossible to keep it aligned" because changes in air temperatures throws the PSI gauge off. He said I'd have to get a yard stick every time I wanted lift the truck up, then go to each side and put the stick up against the fender to measure to see if it was right LOL. He said he'd do it, but I just took it to someone that wasn't an idiot. If they use the excuse "it won't go on the rack" it's BS I've seen a 97 ext cab. dropped 5/6 get on a lift w/ no problem, just had to lay boards down. I do the same thing to get the Blazer on our lift. |
