#51 |
i can beat a geo...barely
Re: How To: Correct Chevy Lean
I tried this method out on my truck. I had about a 3/4" differential between the two sides (with truck basically on empty.) I took two hex nuts (equalling about 3/4" together) plus three 1/8" washers (large enough to keep the bushing there) totalling 1 and 1/8" of total adjustment. I wanted to put a little more in than what i measured because i figured my driver's side would sink with more fuel and me sitting in there. Anyways, I took it out for a 4 mile swervy drive and after measured that the driver's side was 1/4" higher than passenger side. Needless to say, I'm happy with a little more on the drivers side, I'll measure it again after i fill it up...next week if gas prices go down, I won't be driving much this weekend. One thing i did notice though, the roll/spring rate effect seemed a bit stiffer on the driver side than before. That's understandible, because i assume the driver's side is loaded more. If i dont make a "big" purchase here within the next few months, ill be upgrading to a 4dr blazer/zq8 front sway bar anyways. Anyways, nice thread. AJ |
#52 |
Kingdom Mini's
Well when I lowered my truck it had the same lean. I went back cause I believed it was a spring that wasn't seated right. Well I compressed the spring and turned it and it turned a little and well I thought it was definately fixed. Well as with the one side I heard it seat in when lowered it from the jack, this side I still didn't after reseating the spring. So I drove it and went over some speed humps in my brothers sub-division and heard and felt nothing. And as I pulled in his driveway finally heard and felt it seat in there. That pretty much took care of mine.
If your springs aren't in the correct place at the end of the coil that will cause the lean as well. Marc |
#53 |
**Newbie Alert**
Do you need to correct the chevy lean if you drop your truck using spindles up front and blocks in the rear with all the other components staying stock? |
#54 |
Tonight the world is mine
Well I did this in my drop and it worked here.
#55 |
US Beer Drinking Team
Location: Lancaster, CA - Southern California User is: OffLine |
#56 |
hey man that is awesome but how do u fix the lean in the back, i heard that all u have to do is take out a couple of leafs out of the leaf spring what do u think
#57 |
I RIDE LO
#58 |
#59 |
www.putfile.com/sokr2004
^^^no correction needed
#60 |
I drive upside-down
im going to try the spacers & hex nuts on the drivers side. Hope it helps !
#61 |
I got a new belltech spacer for sale if anyone wants it.
#62 |
Still 2 High
I don't know if this was covered, I didn't read the whole thread...
What we did on my work truck was get those metal coil spacers that just basically screw into place in between a coil on each side. Slapped 2 of those in the driver's side coil, and no more lean. My truck doesn't ride any different than it did before, and it's been like that for almost 2 years with 0 problems. And, the best part is it only took 30 seconds, and I think the spacers were like $5. |
#63 |
My truck barely leans so I will probably just use the method described in this thread. I already have the new sway bar end-link. I just haven't got around to installing it.
#64 |
I drive upside-down
Did this over the weekend...it was so simple, the hardest part is cutting the gold spacer!
corrected my lean problem , thanks! |
#65 |
Banned
So now that some of you have had this mod done for a year or more, hows the long term looking, any problems?
IM in the middle of swapping my 2K Bravada onto a 96 2wd frame and going with 2in drop coils and drop spindles and 3in leafs and 2in blocks out back for the drop and want to fix the lean, and like the low buck approach used here. |
#66 |
Hates 'know-it-alls'
how do you know it's gonna have the lean?
#67 |
My truck now has a 4/5 drop, and still 1" more drop on the right rear to keep it square. Do it any way you want, but... those sway bar bushings should still be tightened down with no pre-load in order for it all to work properly. In your specific case... I would recommend doing it as you posted, and then - depending upon whether you want to raise one side or drop the other to make it "look right" - purchase either a 1" block set, or a 3" block set, and use two different lowering blocks in the rear to make it square. Last edited by Thanatos56 : 03-25-2007 at 10:38 PM. |
#68 |
I know to some it sounds stupid but, I have no sway bar...and still have S10 lean.
#69 |
<3 redheads
damn i wish i had seen this thread alot earlier. oh well i'm gonna try the spring spacer i bought from belltech. if that doesn't eliminate my problem i'll do the endlink trick.
#70 |
Ok i am wondering how much that will correct the problem. or can you shrink one and extend the other?
thanks Dave New Ground <SNMTCC> |
#71 |
doesn't sound stupid to me at all, I have seen many trucks that didn't have a sway bar and had the lean. yeah you can do that, but you are just putting more stress on the swaybar and taking away it's abilities even more. By modifying the endlinks you are just defeating the whole reason to have a swaybar. |
#72 |
Stock
i agree, this is the most getto way of "fixing" the problem.
#73 |
&amp;lt;3 redheads
just use the spacer. i put it in today and it worked like a charm. |
#74 |
this is your sway bar link . If you change it and make it shorter on the passenger side...the driver side is going to be off...which me more stress on one side no ?
#75 |
does this lower the highside or raise the low side?
#76 |
If you put it directly on the bushing it will eat its way inside of it and then you will have a loose, noisy sway bar. |
#77 |
it will put stress on the entire sway bar and both end links... all the sway bar does is resist body roll. In theory, it shoudl be able to rotate pretty freely within the frame bushings. I wouldnt personally do this because the truck will handle differently around turns, whether you feel it or not in the seat of your pants. Put your truck on a set of scales and see what it looks like. I'll bet that you have alot of weight on diagonally opposite wheels (driver front and pass rear) adn not so much on the others. This is a big no-no in trying to make a vehicle handle well.
Balance out the ride height with spring spacers(not b/w the coils either... on top or below). It will keep your spring rate the same from left to right, and it shoudl even out your corner weights as well. |
#78 |
Banned
cheaper then that belltech spacer
#79 |
And alot easier too, but that doesnt make it the best solution.
#80 |
Stock
#81 |
Banned
ok then go waste 50 bucks on that spacer
#82 |
Stock
to me, doing things the correct way is not a waste. i'd rather do that than half ass it and compromise handling.
#83 |
No mor bags juice or dubs
i did this like 2 years ago on my bagged 2001 i dunno why it leaned in the first place being bagged, i measured the cups and everything was the same so this seemed like the only thing that could possibly work and it did. i drove my truck a few months with out the sway bar it was terrible NEVER DRIVE WITHOUT SWAYBAR. my truck drove better after i cut the links and i just put the extra on the top to keep from getting a shorter bolt
#84 |
Negative 10
Hey Guys So For I Have Only Lowered The Back Of My Truck. I Used 4 Inch Blocks And Cut My Bump Stops. Now The Only Problem Is, It Leans The The Drivers Side. About A Half Inch. Is This The Same As The Chevy Lean Even Though Its In The Back?
#85 |
I RIDE LO
#86 |
bellcranks no more
'may'.... why does the lean bug you guys soooo much? lol.
#87 |
Trick MotorSports!
But the theory of what he's doing isn't bad, in fact its common practice in road racing. Just do a search of "Adjustable Sway Bar End Links" and you'll see. Granted almost a full 1.5" is on the extreme side, but the idea works. |
#88 |
Has Training Wheels
my passenger rear is an inch lower than the drivers side, its the opposite of what you guys are saying... my swaybar was rusted and broken, no end links...
any way to fix this? i dont know what size or where to get swaybar end links either, |
#89 |
Would this also work if you're using drop spindles instead of drop coils?? I don't see why it would be different, someone let me know...
#90 |
bellcranks no more
#91 |
Whood'a Thought
couldnt you just put a spring 1 inch lower in the pass side?
#92 |
bellcranks no more
#93 |
Remembering My Dad....
man oh man it took me forever to find this thread...should be a STICKY!!! read all of it ppl sayin bootleg this will stress bla bla bla...man act like spacers isnt bootleg. why not have the actual corrected spring made being bigger? ..but ya now im going to go do this!!! sticky it!
#94 |
bellcranks no more
#95 |
it's gonna be clean
spacer ftw
#96 |
i pitty the fool!
my truck leans to the passanger side a bit..full tank of gas fixes that problem
#97 |
i corrected mine with a spacer and it toor a few days to settle and then it totally evened out!
#98 |
well i didnt do it anyway...wanted to but was lazy... maybe someday it wont have the lean get wit a fat chick to have her make my right side even out. spacer link?
#99 |
Keepin' it Gangsta!
Location: Levittown, PA-☆-NE Philly-☆-Trenton, NJ-☆Tha 19057 Bitches☆ User is: OffLine |
Does summit carry the sway bar end link?
I can't find one on their site...And I need to replace mine |
#100 |
Keepin' it Gangsta!
Summit part# bel-4930 |
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f12/how-to-correct-chevy-lean-247314/
| What do you guys think about this fix? - High Altitude Imports | This thread | Refback | 12-31-2007 09:46 AM | |
| Kansas City S-Series Forum :: View topic - Its begun | This thread | Refback | 06-26-2007 11:50 PM | |
| Kansas City S-Series Forum :: View topic - Its begun | This thread | Refback | 06-26-2007 10:58 PM | |
| Kansas City S-Series Forum :: View topic - Its begun | This thread | Refback | 06-26-2007 10:57 PM | |
| sitting lop-sided - Blazin Low Forums | This thread | Refback | 06-26-2007 12:24 AM | |
| sitting lop-sided - Blazin Low Forums | This thread | Refback | 06-25-2007 03:31 PM | |
| sitting lop-sided - Blazin Low Forums | This thread | Refback | 06-25-2007 02:50 PM | |
