Xtreme Measures
Grinding noise after 3.5/3 Drop
Truck is a 97 std cab 4cyl standard suspension {NOT xtreme stock suspension], with 178,000miles.
I have a grinding noise in possibly my rear diff or from my driveshaft when i get going about 55-60 and up. I wont take it up over 70 cause im worried. Its only when i let off the gas or take the truck out of gear at those speeds, If i accelerate or hold my speed it doesnt make the noise. I installed beltech 2in drop spindles, v6 2in drop springs on a 4cyl truck so i ended up with around 3.5in drop up front. and i installed 3in straight drop blocks in the rear. My neighbor thinks its the diff making the noise. when i let off the gas the slack in the bearings from the mileage causes the input shaft to travel a little out of the mesh of the gears in the diff. At least thats his theory. Anyone else had this problem before? I have heard a lot of shim talk or back spacers but im suppose to go out of town this weekend. 4 hr drive each way. Im not so comfortable now. I may end up pulling the kit off and going back to stock for a while. Last edited by xtrememeasures10 : 07-02-2008 at 09:21 PM. |
Xtreme Measures
Re: Grinding noise after 3.5/3 Drop
I put 4in angled blocks on last night to correct the angle the diff was sitting at. Now the grinding noise has stopped. But there is a high pitch whining noise coming from possibly the differential or drive shaft when i get above 5 mph. It is the same pitch no matter what speed and does not increase in loudness. I am about to take this damn drop kit off HelP>>>>
i need a paint job
sounds like a bearing.
Xtreme Measures
I'll do it tomorrow maybe
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() |
Very simple and inexpensive. Much cheaper than actually shortening the driveshaft. Last edited by terryl : 07-04-2008 at 11:51 PM. |
Xtreme Measures
Xtreme Measures
Sweet my buddy and i made them today. took a half inch thick piece of steel. milled it down to size. drilled holes in it, cut a 9/16 rod and welded a piece in the block.
Looks nice. Just be sure to keep an eye on them after you install.
Xtreme Measures
Xtreme Measures
You'll probably be ok, but if you want you can us this tank crossmember from SD.
$ 149.99 ![]() ![]() S10 Raised GastankHere's the link: http://www.suicidedoors.com/S10RaisedGastank.php |
