front bumpstops
Old 08-13-2008, 07:47 PM   #51
I.G.'s FTW!
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
Re: front bumpstops
I don't even have any bump stops, but I have 2" drop coils and the ones that were on there kept hitting the frame and riding rough. To answer your question most people get a pancake bumpstop or cut theirs down.
Take a pic of your coils
Old 08-13-2008, 08:09 PM   #52
xtremewhite99 is infamous around these parts
Re: front bumpstops
so does anyone know fif I use the belltech coil with the 1" drop will that be just as stiff as the factory zq8 coil
Old 08-13-2008, 10:50 PM   #53
I.G.'s FTW!
ZQ8 Blazer's Avatar
Re: front bumpstops
When I had a 1" coil it rode like stock
Old 08-13-2008, 11:24 PM   #54
Re: front bumpstops
ok so most likeley I am looking at sitting about a 1/2" higher in the front than I am now. So I am just going to go and buy the Belltech spindle and belltech 1" coil and spacer to level it out.
Old 08-13-2008, 11:31 PM   #55
Canyon Carver
s10cyncrvr's Avatar
s10cyncrvr will become famous soon enoughs10cyncrvr will become famous soon enough
Re: front bumpstops
Quote: Originally Posted by xtremewhite99
ok here is a picture of my front can anyone tell me if these are than aftermarket spindles. And you can also see mu bumpstop kinda
That's a stock spindle. Now you know that all of the front drop is through the spring. What you want to do now is get a measurement from the ground to the fender on both sides of the truck, and compare it to some other stock xtremes. This should give you an idea of how much it was lowered through the springs. Then you can pick your components from there.
What size wheels and tires are you running?
Old 08-13-2008, 11:40 PM   #56
bellcranks no more
greencactus3's Avatar
Re: front bumpstops
no, i always recommend keeping the stock front bumpstops zq8 or not, on static lowered s10s.
and as jeremy said, that is a stock spindle.
Old 08-14-2008, 12:43 AM   #57
Re: front bumpstops
ok well as of right now I am sitting on 25 1/4" DF and 25 1/2" DP and 25 3/4" in the rear. And right now well the previous owner installed the 225/60/16, I know that the oem size is 235/55/16, so when this is all said and done I am hope that it still looks level
Old 08-14-2008, 02:02 AM   #58
I.G.'s FTW!
ZQ8 Blazer's Avatar
Re: front bumpstops
Isn't a stock S10 SUPPOSE to be 31" up front? If that's right then he's got cut coils.
What's wrong with not running one? If I was another inch lower I'd get a pancake, but I've only bottomed out once in 9 months on a real bad pothole and even then it barely hit.
After I cut it down it was hitting all the time.
Old 08-14-2008, 09:53 AM   #59
Ticket Magnet
Rhotpursuit's Avatar
Rhotpursuit is on a distinguished road
Re: front bumpstops
For a ZR2....
Old 08-14-2008, 01:47 PM   #60
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura aboutterryl has a spectacular aura about
Re: front bumpstops
^$3 for a can of semi-gloss paint Terryl, GEEZ
Oh and your bump stop has a crack in it. Any reason why you haven't you got some different ones or cut those down? Mine was about that close when I dropped it and it rode awful.
Just send me $3
And the bump stop does not have a crack in it. I put a small amount of grease on there because I wanted to. That's what you see.
I haven't cut them down because there is no need to. It rides great like it is. I never even know when it bottoms out unless I do something stupid.
Any more questions?
Old 08-14-2008, 09:31 PM   #61
This is doo doo baby!
wildman ss's Avatar
wildman ss is on a distinguished road
Re: front bumpstops
Quote: Originally Posted by terryl
Any more questions?
where do babies come from?
Old 08-14-2008, 09:44 PM   #62
I.G.'s FTW!
ZQ8 Blazer's Avatar
Re: front bumpstops
Quote: Originally Posted by Rhotpursuit
For a ZR2....
I was thinking abot my Blazer that's where it was stock .
Terryl- I see now plus I forgot the ZQ8's were softer mine rode like crap w/ the hard rubber ones.
And yes where do babies come from
Old 08-14-2008, 09:57 PM   #63
Re: front bumpstops
ok so does anyone know what the factory height is from the ground to the middle of the wheel well lip as mine is 25 1/4"
Old 08-14-2008, 11:57 PM   #64
bellcranks no more
Re: front bumpstops
mine was 30~31 stock
Old 08-15-2008, 12:02 AM   #65
terryl's Avatar
Re: front bumpstops
Ask Greencactus3. He goes to school!
Old 08-15-2008, 12:11 AM   #66
bellcranks no more
Re: front bumpstops
GTGAGGCGCAGCTGACCAGTCAG........................... ....................................something like that
Old 08-15-2008, 01:10 AM   #67
Re: front bumpstops
so are the zq8 xtreme's like 27-28" factory in the front
Old 08-15-2008, 01:27 PM   #68
bellcranks no more
Re: front bumpstops
roughly yes, because of 1.5" sus, .5" tire, and 3/4" flares.
Old 08-18-2008, 01:06 AM   #69
Re: front bumpstops
ok so I am ordering my 2" spindles and 1" coil. I am just wondering will my rims and tires still work on my truck right now I have the 16x8 american racing iroc rims with the 0 0ffset and 225/60/16 tires, will anything rub at all because dont the spindles push your front tires out a bit.
Old 08-18-2008, 02:35 AM   #70
I.G.'s FTW!
ZQ8 Blazer's Avatar
Re: front bumpstops
My fender lip is about 27" from the ground and I'm running a 26.2" tall tire and mine only BARELY rubs when I turn and hit a bump.
Your tire is 26.6" tall. If you drop yours 3" from factory height then I believe it should raise you up 1"-2" depending on your truck, so if you're not rubbing now then you won't be when you lift it up some. Are you rubbing?
Yes I believe drop spindles push the wheel out a tad.
Old 08-18-2008, 11:21 PM   #71
Re: front bumpstops
ok so it seems like most members with the 2/3 ontop of the factory zq8 sit around 25" mark so I am just guessing that the factory height of the xtreme's are around the 27" mark in the front so with mine and the 2" spindles and 1" belltech coil I schould sit at 25.5" in the front correct.
Page generated in 0.18059 seconds with 12 queries
