Canyon Carver
Find that Stance
Lets say you want to lower your truck. Think about all the factors involved in finding the stance you want.
- Overall height - Rake - Tire diameter - Ground effects A simple ?/? drop question simply doesn't cover it today. Since not all trucks are alike, a 2/3 on one truck can look very different as compared to another 2/3 truck. Plus throw in the ZQ8 package and 4wd's and it can get confusing quick. How about a thread where all this info is listed where you can browse through, find some trucks you like, and then find out exactly what height they are at by looking at their measurements. You can then compare these measurements to yours, to see what all you need to do to get it to that stance. 1. Fender height. This is a measurement from the ground to the highest point on the bottom lip of the crown of the wheel well. These dimensions would be listed at all four corners. Make sure to do this on level ground after the suspension has settled. DF = (Driver Front) PF = (Passenger Front) DR = (Driver Rear) PR = (Passenger Rear) ![]() 2. Tire Size. List your tire size at the front and the rear, even side to side if you feel so inclined. Front = ???/??/R?? Rear = ???/??/R?? 3. Drop Parts. The good old fashioned ?/? information, and what parts you used to achieve it(if applicable). 4. Pictures. A simple front and rear shot will do it, if you could resize them to decrease load time, that would be swell. |
Canyon Carver
Re: Find that Stance
1.
DF= 24 - 15/16" ---------- PF= 25" DR= 25 - 15/16" ---------- PR= 25 - 13/16" 2. Front = 245/40/R18 Rear = 295/35/R18 3. 4/5.5 Front - 2" Belltech Drop Springs, 2" SSBC Drop Spindles, Belltech "Chevy Lean" spacer on the driver side, 1/4 coil removed on the pasenger side. Rear - 3" Belltech Drop Leafs, 3" Drop Blocks, Roadmaster Sping set up raised it up 1/2" from the tension. 4. ![]() ![]() |
1.9 Proud Liters
I'm glad someone put something like this.....VERY NICE truck by the way.....that looks AWESOME
I've been trying to explain this to people for months when they ask about lowering their truck. I'll be sure to measure my truck when I get my C6s back on.
Possibly another suggestion would be wheel size and offset and if it rubs or not. This would make this a definitive list for what wheels fit and don't. |
Canyon Carver
On the front of mine, the tire will hit the frame before full lock. If the suspension compress completly, the top of the tire will rub on the inner fender, a rare occurance though. This is with a 18x8 with 4.5" of backspacing |
hey man i love your truck dude...what is your drop...and what is the size tire your running i have been saving for those wheels for the last few months... and i am coming up on the time of purchase hopefully...but if you can tell me what your drop is, and all the specs on your wheels and tires...thanks man
oh shit dude i feel like an ass...i completly over looked your 2nd post man...sorry...love your truck tho...
The Dave Inc.
id keep the wheel/tire info in the wheel tire section...keep this from getting too bogged down...ill measure mine all up if i get a chance
They are dependent upon each other, it needs to be here. |
Canyon Carver
1.
DF= 30 - 13/16" ---------- PF= 31 - 3/16" DR= 31 - 5/16" ---------- PR= 31 - 3/4" 2. Front = 215/75/R15 Rear = 215/75/R15 3. 0/0 Rear has an add-a-leaf to compensate for the weight of the campershell. 4. ![]() Wheels are the stock 15x7, I've never measured the backspacing. No rubbing or decrease of turning radius. Last edited by s10cyncrvr : 01-19-2007 at 12:24 PM. |
Tonight the world is mine
1. Fender height.
DF = 26" PF = 27" DR = 26 3/4" PR = 26 3/4" 2. Tire Size. Front = 205/75/15 Rear = 205/75/15 3. Drop Parts. 3/3, coils and blocks. No rubbing on anything. Sway bar mod 4. Pictures. ![]() Click for bigger pics. |
Undecided
looks like it should be a sticky
Wow S10cyncrvr I think that is one of the nicest trucks on the forum! It's so clean looking! Nice work...
Hey s10cyncrvr, love the truck especially the rims, what kind are they, thanks.
Canyon Carver
nice trucks
Dialed!
I don't meant to get off topic, but I currently have a 2/3 right now, my rear is dynamic since i got shocks that you can pump air into to raise it, so my truck is usually around a 2/3. If I need to, it can be a 2/4 or 2/1.
Anywho, I want to go lower, and i'm wondering if anyone ever had their wheels rub with 2" spindles and 2" coils. I have the stock tires, 205/75/15. |
bellcranks no more
205/60R15, 2in spindles, and "2in v6 coils" i bought which dropped me about 3inches,
and blocks and pulled leafs(from the z85) the massive chevy lean on the rear as shown on these pics has been fixed since, and now both sides of the rear are within 1/4" of eachother, although i dont rememebr the measurements. the front's chevy lean has not been touched. driver front ![]() pass front ![]() driver rear ![]() pass rear ![]() for this stance on 205/60/15s http://i113.photobucket.com/albums/n...s/P1010865.jpg ![]() ![]() ![]() Last edited by greencactus3 : 01-24-2007 at 12:55 PM. |
Getting Layed
df- 26 1/2''
pf- 26 3/8'' dr- 27 3/8'' pr- 27'' front= 2'' belltech spindles, 1'' v6 belltech coils rear= 3'' belltech drop leaves, 2'' belltech drop blocks toxic shocks all around, cut bumpstops sitting at 3/5 255/50/17 all around, about 27'' tall on the truck. ![]() ![]() ![]() ![]() ![]() i want to go 4/6 or something but i'm scared of more rake or gap. also, i have big tires. i want to do 245/45/17 front and 275/40/17 rear with the 4/6 sometime in 07' |
dont scare her, shock 'er
good looking truck RKs95blackSS, real nice. really likin the tinted tails,
Canyon Carver
Thanks for posting your info guys.
Getting Layed
thanks bro
So Fresh N So Clean
This is a great thread, thanks a lot for posting. Also, if you ever want to sell those rims, I'll buy them. =] They are pretty awesome. |
#24 |
mine
#25 |
zeroclearance.ca
D F= 25 - 3/8" ---------- P F= 25 - 5/8"
D R= 26 - 7/8" ---------- P R= 26 - 5/8" Front = 225/50/R16 Rear = 245/50/R16 5/6 Front - 3" Belltech Drop Springs, 2" Belltech Drop Spindles Rear - 3" Belltech Drop Leafs, 3" Belltech Drop Blocks ![]() ![]() |
#26 |
Buffa Beats
1.
DF= 26 7/8" ---------- PF= 27" DR= 27 1/2" ----------P.R= 27 3/4" 2. Front = 245/35/R20 Rear = 245/35/R20 Tire diameter= 26.8" 20x9 Boss 304 3. 4/5 Front - 2" Belltech Drop Springs, 2" Belltech Spindles spacer on the driver side Rear - 3" Belltech Drop Leafs, 2" Belltech Drop Blocks 4. ![]() ![]() |
#27 |
2 Tone
#28 |
cokehead
Location: Libertytown, MD- near Frederick User is: OffLine |
says 20x9's in his post. look at #2, last answer. |
#29 |
Front: 32 1/4" Rear: 32 3/4"
Tire size: 235/75 R15 I want a 3/4 drop but i figure the tires are too big so ill settle with 2/3. ![]() |
#30 |
Extcabs10 does your frame scrape or wheels rub? Does the axle bottom out on the frame? I like that look and stance....Rulayd do you have any more pics of your truck?
#31 |
zeroclearance.ca
wheels rub the lower control arm when its almost at full lock, but its pretty easy not to rub them axle will bottom out if you hit soemthnig REALLY hard - very rare occasion and i DONT have a c-notch |
#32 |
#33 |
I hate my truck.
Reading owns you, it says 235/75...a 3/4 is a big hell no on that tire size. 235/75's rub as it is on a stock sprung s10. I no that for a fact.
#34 |
Will a 3" coil and a 2" spindle give you a true 5" drop in your ride height or no?
#35 |
I hate my truck.
suspension wise yes, you would then also have to account in the lesser size of tire for the full drop from stock height.
#36 |
this has been a very helpful post thanks s10cyncrvr, but i think it might also be helpful if you posted the overall diameter of the wheel and tire
#37 |
zeroclearance.ca
example 225/50R16
50% of 225 will give you the side wall in MM (metric) = 112.5MM X2 (top and bottom) = wow 225MM 225MM divided by 24.5MM/inch equals...use a calculator = 9.18...inches plus the 16 wheel = approx 25.2" tall |
#38 |
STPSYDR
awesome thread, I agree with the guy who said this should be a sticky, I should have my info up very shortly
#39 |
my lower toy
Location: Dartmouth, Nova Scotia, Canada User is: OffLine |
Jeremy, that is one beautiful canyon carver.
Here is my truck...5/6 drop DF 24" PF 24-1/8" DR 25" Page Ranking 25-1/4" Front 225/60/15 anything bigger rubs bad, fender lips rolled under, top bolts removed Rear 255/60/15 just clears wheelwheel Front: spindles, springs (right cut 1/2 coil to eliminate lean) Rear: 3" block, removed middle leaf, traction bar clamping all leaf springs, modified swaybar ![]() and at speed... ![]() and here is a shot showing the various rakes, black ss is 2/3, mine is 5/6 and the blue flamed truck is @ 5/3. ![]() |
#40 |
Nothin Special
s10cyncrvr i just wanted to say that your truck looks amazing. Also i couldnt help but notice you have the classic chevy cross flags on your fender. I did the same thing, just found a nice set at a swap meet for 2 bucks (except mine r on the fender).
#41 |
1.
DF=28 3/4" PF=28 1/2" DR=28 3/4" PR=28 1/2" 2. Front=235/55/18 Rear=235/55/18 3. I call it a 3.5/4.5 but here is the breakdown. Original Heights- DF=31 3/4" PF=32 1/4" DR=33 1/4" PR=33 3/4" so... Drop from Original Heights= DF=3" PF=3.75" DR=4.5" PR=5.25" Parts Used: Front: Belltech Drop Torsion Keys Rear: Belltech 3" Drop Leafs, 3" Belltech lowering blocks machined down to roughly 1.5". The blocks aren't the same because I cut them to set my truck down perfectly. If I had milled them evenly I would retained a left/right lean. 4. Before: ![]() After: ![]() 5. Wheels: Corvette C6 in 18x8.5 +56MM offset. Drivers side rubbed at full lock to the right but slight grinding on the UCA solved this. 1/4" spacer would work as well. Factory 15s with 235/75/15s still fit fine and don't rub at all so I run them for winter. Last edited by dillon_b12 : 07-22-2007 at 01:27 AM. |
#42 |
I hate my truck.
Looks sick for sure, but with that stance and looks... It needs a power adder. For instants a blower or turbo heh. Along with a shift kit and gears. Then it would be ridicules.
#43 |
#44 |
Drag Truck In Making
Location: Westwego, LA outside of New Orleans User is: OffLine |
Here we go. Probably got the dirtiest pic up here. hehe.
2/3, 02' xcab. X-zq8. Guy changed to stock suspension before I bought it, that ****er! Picked up 3'' autozone blocks/hanging kit for about $30 over a year ago, no problems. Till recently been riding 0/3. Found a set of Belltech 2'' drop spindles in the paper for 75bucks. New in box. Bought them installed, aligned. Looking better now! Yes they have belltech stamped/cast/w/e in the spindles. Next step is 4'' angled blocks from sumit and 1.5'' Zq8 coils. Measurements are: DF...26 5/8'' PF...26 5/8'' DR...26 7/8'' PR...26 7/8'' 225/75/15 on swirlies. Rubs hard at full lock. Hit inner fender well over speed bump (went to fast.) Other than rubbing Im happy! Anyway here's some pics: 0/3 165/80/15 front 265/50/15 rear ![]() 2/3 225/75/15 on swirlies ![]() 2/3 225/75/15 ![]() Hope you all enjoyed my drity lil' noma' |
#45 |
bellcranks no more
thought we should keep this thread up to date
1. Fender height. DF = 23 3/8 PF = 23 3/4 DR = 25 5/8 PR = 25 1/2 2. Tire Size. Front and rear = 205/60/R15 3. Drop Parts. 5.5/5 (approximate) 3" coils 2" spindles 2 leafs pulled out of the 98z85 leafpack 4. Pictures. ![]() ![]() |
#46 |
Scoop
DF 25 1/2 PF 26
DR 26 3/8 PR 26 3/4 Front 215/60/16 Rear 255/50/16 ZQ8 springs and 2" Belltech Spindles up front ZQ8 leafs and 2" angled blocks out back ![]() ![]() Last edited by sonomaguy : 01-27-2008 at 11:59 PM. |
#47 |
Have a nice day!
Driver front: 24 1/2
Passenger front: 24 5/8 Driver rear: 25 1/2 Passenger rear: 25 1/2 3" 2.2 drop coil 2" drop spindle Pulled leaf Helper spring/leaf clamp 3" block 225/60/15 on some camaro wheels with a 3/8" spacer up front for tie rod clearance ![]() ![]() |
#48 |
Damn I wish I had measured my X before I started my coilover/spindle install. Although the front is now going to be adjustable I used 3" blocks in the rear. Pics hopefully very soon to come.
#49 |
Belltech 3 inch drop springs with chevy lean bushing driver side
Belltech 3 inch drop leafs Belltech performance shocks Belltech front and rear swaybars Toyo Proxes S/T 295-50-15 tires front and rear Ion Series 171 black wheels 8 inch wide Performance mods are air cleaner box removed with highflow filter. The truck sits 6.5 inches from the ground to the frame. Front measurement is 25.5 inches to the fender and 26.75 to the rear fenders (I haul my dirtbike in back I want it a little high in the back so i can carry some weight) Future plans call for baer disk conversion for rear drums, posi, 13 inch rotor big brake kit for front. 2 inch drop spindles, 2 inch drop blocks, and Energy Suspension bushing kit. Makaveli or ZE forged wheels with 335-30-18 for rear and either 275-35-18 or 285-30-18 for the front. Motor work will be the norm of just a high flow exhaust but not ratty sounding $h!t can for honda civics running around these days. Computer upgrades and intake. The tires rub a hair on the sway bar only at full lock, i did have to beat the wheel well back about a quarter of an inch. driving hitting bumps rubs on the inside of the fender on driver side only but only polishes the lip now that I've rolled them . |
#50 |
![]() Last edited by billetsdime00 : 08-06-2008 at 04:28 PM. |
