dropped 6 inch rear
Old 08-22-2008, 03:49 PM   #1
AUTOMAN is on a distinguished road
dropped 6 inch rear
2000 dime std cab sht bed dropped 6in rear
, if i cut the bumpstop brkt out, the rear end will sit 2 inches from frame. wont it bottom out all the time? belltech springs, 3 in block, nitro shocks-the front is spindle and 2 in coils. also my truck has a heavy bed cover and the roof is in the bed-hardtop convertible-this stuff weighs about 350 lbs.
Old 08-22-2008, 09:26 PM   #2
Re: dropped 6 inch rear
I GUESS NOBODY KNOWS. I THINK I WILL TAKE OUT THE BLOCK AND TRY IT AT 3 INCH. WITH THE WEIGHT IN THE BACK SHOULD LOOK LIKE 4 INCH
Old 08-22-2008, 10:47 PM   #3
casey g's Avatar
casey g is on a distinguished road
with that much weight u might be all the way botemed out. get air shocks and a mini c notch. the dearched leaf springs are not as stiff at the originals!
Old 08-23-2008, 08:51 PM   #4
Doin it My Way
Cauzin_Statik is on a distinguished road
I have an ext. cab lowerd 7 in the back. Frame has about 1" of clearance from the axle. Notch it or use the frame as the bump stop to prevent over articulation/
Old 08-23-2008, 10:32 PM   #5
pulled out block ended up 4.75 drop just right fit my 225/70 15 just right,measurement is 27 inch in rear,26 up front
Page generated in 0.09292 seconds with 12 queries
