Do drop spindles move the wheel out a bit?
Old 08-12-2008, 02:20 PM   #1
t_wade is on a distinguished road
Noob question. I was thinking about dropping my 97 a bit, and wanted to use drop spindles, but with the jacked up wheels that were on it when i got it, it doesn't look like the mount point for the tierod end will clear the wheel if i add a drop spindle. Do the drop spindles move the wheel out a bit for more clearance or is the wheel position the same? Thanks for any help you guys could provide.
Old 08-12-2008, 02:39 PM   #2
bellcranks no more
greencactus3's Avatar
Re: Do drop spindles move the wheel out a bit?
yes, they widen the track a bit but the tie rod clearance gets worse
Old 08-12-2008, 02:51 PM   #3
Ok, I understand that since the wheel moves up on the spindle, the tie rod gets closer to the wheel. I have 16 x 8 wheels, with spacers behind them, and would be willing to change the spacer to match the offset of a second gen ZQ8 wheel. If I understand correctly, if I matched that offset, and added the drop spindle, the tie rod should clear. Is that correct?, and what is the stock offset of a ZQ8 wheel anyway?
Old 08-12-2008, 09:17 PM   #4
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura aboutterryl has a spectacular aura about
That sounds correct. However, you still will not be able to run normal hammer on weights on the inside. Will have to use stick ons.
Old 08-12-2008, 10:36 PM   #5
bellcranks no more
not necessarily, the wheel profile varies between wheels, matched offset will not guarentee clearance, although it is a good guesstimation.
Old 08-13-2008, 03:23 PM   #6
Well, my wheels are steel, and should be a bit thinner than most aluminum wheels. I think I will give it a shot and see what happens. Thanks for your help.
Old 08-17-2008, 07:59 PM   #7
JJ83 is on a distinguished road
Whoa whoa whoa. I'm currently lowering mine '98 S-10 with the newer ZQ8 wheels. I'm going down 3" in the front. Am I understand this correctly that i'll hit the tie rod ends? I'm using a 1" lowering spring and 2" spindles. Do I have to use spacers, and if so won't that push the wheel out too far. I think I would hit the inner fenderwell?
Old 08-18-2008, 02:15 AM   #8
terryl's Avatar
I believe you should be fine. Another 1/2" drop and you would be right next to the inner lip of the wheels. You will still be above the lips. Probably. lol
Old 08-18-2008, 03:09 PM   #9
mk2gti is on a distinguished road
factory tie rod ends wont hit. aftermarket ones will, i have drop spindals on my truck and i put 2 new front tie rods that are aftermarket and they were slightly bigger, had to take them back and buy used factory ones
Page generated in 0.10357 seconds with 12 queries
