Just a member
Commonly used drop components part numbers.
OK guys I was saving this info for the droppinit.com site that we are bringing online, but we seem to get this question alot. So I am gonna add this to the forum as a sticky until this info is up on the site for everyone to see. This is a list of some of the more common used companies drop part numbers. I hope it helps.
*Note- These numbers are taken from thier actual sites and dealers. So if there is an error in the part numbers, do not blame us. Talk to them. Drop products part numbers listed by manufacturer. DJM 2 Inch Drop Spindles=DS2031-2 1 inch drop Coils=CS2321-1 2 inch drop coils=CS2321-2 3 inch drop coils=CS2321-3 1" Lowering Block Kit =LB1LK 2" Lowering Block Kit =LB2LK 3" Lowering Block Kit =LB3LK 4" Lowering Block Kit =LB4LK 1" Steel Lowering Block Kit = SB1LK 2" Steel Lowering Block Kit = SB2LK 3" Steel Lowering Block Kit = SB3LK 4" Steel Lowering Block Kit = SB4LK 2 Degree Pinion Shims= 2PS 1997-2003 S10 3" Block Kit. Includes block plates.=LB1023-3 1997-2003 S10 4" Block Kit. Includes block plates.= LB1023-4 3 inch lowered control arm=CA2331L-3 S10 Spring Plates with Shock Mount= 1023-SP Kits 1982-2003 2/3 Drop Kit = K2031-2/3 2" Spindles / 3" Blocks 1982-2003 3/4 Drop Kit= K2331-3/4 3" Control Arms / 4" Blocks 1982-2003 4/4 Drop Kit= K2031-4/4 2" Spindles, 2" Coil Springs / 4" Blocks Belltech Coil spacer= BEL-4930 2 Inch Drop Spindles (1998-2003 S10/S15 Blazer/Jimmy) = BEL-2102 2 Inch Drop Spindles (all others)=BEL-2100 1 inch drop Coils 6 cyl= BEL-4202 2 inch drop Coils 6 cyl= BEL-4223 3 inch drop Coils 6 cyl= BEL-4227 1 inch drop Coils 4 cyl=BEL-4200 2 inch drop Coils 4 cyl=BEL-4220 3 inch drop Coils 4 cyl=BEL-4225 1 inch straight blocks=BEL-6000 2 inch straight blocks=BEL-6100 3 inch straight blocks=BEL- 6200 1 inch 2 deg angled blocks=BEL-6002 2 inch 2 deg angled blocks=BEL- 6102 3 inch 2 deg angled blocks=BEL- 6202 3 inch drop leafs (all s-10 and 83-94 S10/S15 Blazer/Jimmy) = BEL-5954 3 inch drop leafs (95-97 S10/S15 Blazer/Jimmy) = BEL-5956 3 inch drop leafs (98-03 S10/S15 Blazer/Jimmy) = BEL-5964 Ground Force Kits 2/2 82-Up S-10 PU/Jimmy/Blazer (spindles/blocks)=9222 2/3 82-Up S-10 PU/Jimmy/Blazer(spindles/blocks)=9223 3/3 82-Up S-10 Pickup Reg/Ext Cab(4cyl.)(spindles/coils/blocks/shocks)=9233 3/3 82-Up S-10 Pickup Reg Cab(4cyl)(spindles/coils/monoleafs/shocks)=9333 3/3 82-Up S-10 Pickup Ext Cab(4cyl)(spindles/coils/monoleafs/shocks)=9433 3/3 82-Up S-10 Pickup(4 cyl.)(coils/blocks)=9920 3/3 82-Up S-10 Pickup(V6)(coils/blocks)=9921 5/5 82-Up S-10 Pickup Regular Cab (4 cyl.)= 9255 (IncPickup Extended Cab (4 cyl.) 5/5 82-Up Pickup Extended Cab (4 cyl.) 82-94 S-10 Jimmy/Blazer (4 cyl.)(Includes new mono-leaf rear springs)= 9256 5/5 82-Up Pickup Regular Cab (6 cyl.)= 9258 (Includes new mono-leaf rear springs) 5/5 82-Up Pickup Extended Cab (6 cyl.) 82-97 S-10 Jimmy/Blazer (6 cyl.)= 9259 (Includes new mono-leaf rear springs) 2 Inch drop spindles(82-Up S-10)=6002 Chassis Tech 2 Inch drop spindles(82-up s-10)= SPI-CV82XX 2 Inch drop spindles(82-97 Chevy S-10 Blazer)=SPICV8297BL 1 Inch drop blocks =BLO1 2 Inch drop blocks=BLO2 3 Inch drop blocks(come straight or 2 deg tapered)=BLO3 4 Inch drop blocks(2 deg tapered)=BLO4 3 inch drop leafs(82-up s-10)=CV8200 3 inch drop leafs (95-up Blazer)=BL9500* *most companies make different leafs for 95-97, and 98-04. 83-94 are the same as 82-04 S10 Last edited by xxosiris9xx : 07-12-2005 at 11:38 AM. |
Just a member
Re: Commonly used drop componenets part numbers.
Also I do not have some of the chassis tech's common used parts on the list. I do not have the coils and leafs. I could not find a specific list pertaining to certain years and engine sizes, so I left it out. SO if you guys know the numbers or where I can find them. Please let me know so I can add them to the list. I also have other part numbers as well, but as stated in the 1st post, this is some of the more common used ones. So if you have a question about one and do not see it listed, let me know. Chances are that I have the part numbers saved.
Thanks |
