charcoal canister????
Old 01-06-2003, 08:42 PM   #1
Just BAG IT!
99x on air's Avatar
Do I have to remove or relocate this to bag my Xtreme? I really don't want to mess with it unless I have to?
If I have to relocate it, where do I put it??????
Old 01-06-2003, 08:53 PM   #2
SlammedDime's Avatar
If you notch, you will have to relocate or remove(not recommended)...I'll take a picture tomorrow of where mine is relocated to on my truck
Old 01-06-2003, 08:58 PM   #3
Just BAG IT!
99x on air's Avatar
alright... i don't know if i am going to notch yet or not.. but please take a pic anyway...
thanks man :thumbup:
Old 01-06-2003, 10:40 PM   #4
Bandit7's Avatar
weld it on the gastank cross member on the passenger side.
Old 01-06-2003, 10:40 PM   #5
Bandit7's Avatar
on the front of it, towards the cab
Old 01-06-2003, 10:43 PM   #6
WANTED: 4" Bodydrop
laynframe's Avatar
i am going to get a fuel cell when i bag mine so what should i do???
late,
richard
Old 01-06-2003, 10:46 PM   #7
Bandit7's Avatar
i guess do the same. i don't see why it would be any different.
Old 01-06-2003, 11:00 PM   #8
Bandit...that's exactly what I did
Old 01-06-2003, 11:07 PM   #9
Bandit7's Avatar
it fits there perfectly like gm should of put it there to begin with
Old 01-06-2003, 11:12 PM   #10
yup
Old 01-06-2003, 11:14 PM   #11
WANTED: 4" Bodydrop
laynframe's Avatar
i dont need to extend tubes or wires???
late,
richard
Old 01-06-2003, 11:18 PM   #12
Bandit7's Avatar
it depend on where you mount it. if you need to extend them, all you have to do is buy more rubber hose that is longer to lengthen it.
Old 01-06-2003, 11:29 PM   #13
Afterhours Admin
AVTekk's Avatar
eh, wrong..you will need to relocate it even if you dont notch, that includes lowered trucks. dropped a friends xtreme 3", had to move it cuz the brake line was cutting into it somethin fierce. also, heres were i put it on a recent job altho pushing it back this far will require you to extend the lines:
http://www.s10forum.com/forum/attach...&postid=180487
Old 01-06-2003, 11:42 PM   #14
I hate working on trucks
Re: charcoal canister????
I relocated mine right behind the cab. I made a bracket and welded it to the gas tank X member.
http://www.s10forum.com/forum/showth...threadid=24930
Old 01-06-2003, 11:49 PM   #15
Bandit7's Avatar
Hey dave, my truck was dropped 4 inches for a year and mine didn't get relocated until it was bagged. I would mount it off of the gas tank x member so you don't have to run those lines all the way to the back.
Old 01-07-2003, 12:17 AM   #16
That was the cool thing about it. I just used the stock lines. They worked fine.
Old 01-07-2003, 12:32 AM   #17
Just BAG IT!
99x on air's Avatar
can you guys take pics of this? I don't want to change any lines... thanks
also, I have had 4 inch blocks on my x for about a year and have never had any problems??
Old 01-07-2003, 12:37 AM   #18
Look at the link I attached. The pic is crap but you can kinda see it. I will take better ones.
Old 01-07-2003, 12:51 AM   #19
Just BAG IT!
99x on air's Avatar
is that is on the passenger side above the muffler?
Old 01-07-2003, 01:14 AM   #20
Yeah.
Old 01-07-2003, 02:15 AM   #21
use the existing bracket and mount it to the center of the gas tank x-member and then it will sit over the muffler...like I said earlier...i'll get pics up tomorrow morning of what I did unless someone beats me to it with their pic :P
Old 01-07-2003, 02:21 AM   #22
Afterhours Admin
AVTekk's Avatar
im just telling ya a way to do it, didnt say its the only way.
also Im not a big fan of placing fuel lines and a canister containing combustable vapors above a hot muffler. just not my style..
Steve your truck is a 95. in 98+ the bracket is completely different and the brake line WILL rub
Old 01-07-2003, 02:40 AM   #23
look in the right at this pic...you can sorta see it....http://www.s10forum.com/forum/showth...threadid=25337
Old 01-07-2003, 09:18 AM   #24
Bandit7's Avatar
ok dave.
Old 01-07-2003, 12:17 PM   #25
Here we go
Old 01-07-2003, 12:30 PM   #26
Does the driveline rub it? I had mine over the drive line and it rubbed like a mofo. My muffler is a good foot away from it.
Old 01-07-2003, 12:33 PM   #27
No rubbing...i'm still running stockers on 205/60R15's I have a good 2-3" before the drive line hits the inside of the notch on the gas tank x-member...Even with up to 17's I should be fine
Old 01-07-2003, 12:37 PM   #28
Funny that is the same tire size I am running. I think I had mine mounted a little lower than yours. If you look at the bottom of the can you can see dent marks where the counter weight off the driveline hit it. Oh well. I can place my hand under the can with the truck running and there is no heat from the muffler. At first I was worried about that. I was going to make a heat shield but it doesn't need it.
Old 01-07-2003, 12:39 PM   #29
I know...it really isn't that hot right under it so I didn't worry either
Old 01-07-2003, 01:32 PM   #30
Afterhours Admin
AVTekk's Avatar
Its good to offer up more than 1 idea to do things. My truck has 2 mufflers there, standing vertically stacked next to each other. If I were to move the canister there, somethin sh!tty could happen..
Old 01-07-2003, 01:34 PM   #31
That's so very true.
Old 01-07-2003, 01:39 PM   #32
Just BAG IT!
99x on air's Avatar
Hey Slammed 96, the pic isn't working for me?
Old 01-07-2003, 01:52 PM   #33
Sorry
I'm having problems with my web server...here we go...
And I do Agree with Av...you guys that have done other things...post 'em up...the more Ideas the better
Old 03-07-2006, 10:00 PM   #34
Getting back in the game.
Fast_Lo96's Avatar
mines a 96 and it rubbed through my e-brake line, im on a smoke break from relocating it as i speak...i only have 4 inch blocks
Old 03-07-2006, 10:01 PM   #35
Fast_Lo96's Avatar
...talk about bring back an old thread...well, maybe it will be of use once again
Old 03-08-2006, 01:16 AM   #36
lowsdime3ff/emt's Avatar
I moved mine to where my spare tire is and just put the spare snug up to it. But you do have to extend the hoses.
