c notch install? - S-10 Forum
post #1 of 87 Old 02-06-2005, 12:26 PM Thread Starter
philly d from canada
likes it low's Avatar
User is: likes it low is offline
Send a message via MSN to likes it low
Talking c notch install?
Does anyone have a install guide or anything for installing jasons c notch into a first gen s10? I know its pretty basic but it always help to have a how to or something like that....phil
post #2 of 87 Old 02-06-2005, 03:21 PM
No more switches
CustomS10's Avatar
User is: CustomS10 is offline
Send a message via AIM to CustomS10
Re: c notch install?
i have a 2nd gen but it's all basically the same shit. I made a template out of cardboard and i measured the frame and the axle and made sure to get it center..then i put the template on the frame marked the frame and cut that bitch out. Drill the holes bolt it on and bam ur done.
-Ben-
Dime sold...but not forgotten
post #3 of 87 Old 02-06-2005, 07:44 PM Thread Starter
what did you use to cut the frame? its a round notch hole so im thinking a orch is going to be the way..phil
post #4 of 87 Old 02-06-2005, 07:50 PM
No more switches
CustomS10's Avatar
i used a sawzall and a cut off wheel.
-Ben-
post #5 of 87 Old 02-06-2005, 11:47 PM
2LO4BC
lowriderbowtie's Avatar
User is: lowriderbowtie is offline
Send a message via MSN to lowriderbowtie
use a cutoff wheel
you will be able to follow your lines better, then you can just clean up the edges with a grinder
2011 Mazda 3 GT
2004 Dodge Ram 2500
2012 Polaris RZR 800
post #6 of 87 Old 02-06-2005, 11:50 PM
SOLD
MX_Racer32's Avatar
User is: MX_Racer32 is offline
if my gallery wasnt down you could chek out a bunch of pics that i have in there...
post #7 of 87 Old 02-07-2005, 12:10 AM
Hates 'know-it-alls'
User is: grndscrpr03 is offline
Send a message via AIM to grndscrpr03 Send a message via Yahoo to grndscrpr03
what kind of notch are you installing?
post #8 of 87 Old 02-07-2005, 12:34 AM
Static Dropped Dime
BlizzardofOzz's Avatar
User is: BlizzardofOzz is offline
Send a message via AIM to BlizzardofOzz
im gonna get that bolt in notch to for mine
I NEED ANOHTER DIME!!!!!
post #9 of 87 Old 02-07-2005, 07:40 PM
Honest Abe's Fab Shoppe
BlackEsDime's Avatar
User is: BlackEsDime is offline
Send a message via AIM to BlackEsDime Send a message via MSN to BlackEsDime Send a message via Yahoo to BlackEsDime
-Ryan
I build aluminum fuel cells. Maybe...
www.honestabesfabshoppe.com
post #10 of 87 Old 02-07-2005, 07:56 PM
****head
EvenFlow's Avatar
User is: EvenFlow is offline
Send a message via AIM to EvenFlow
Yup pretty easy. I've helped with 2 (one being mine). We marked the cut with a sharpie, grinded a lil notch to start it, and then used a sawzall for the majority of the cutting. Then cleaned it up with a grinder. Drill holes and bolt it in. We welded it as well for extra strength but it is definately not necessary. Jasons cnotch is badass. Pretty easy. I'll upload some pics to my .org gallery and post the links in a few.
*edit* .org is down, I will do it as soon as I can if you want some pics.
Jeremy - Teh Gummybear of Candycornia
EvenFlow is offline
post #11 of 87 Old 02-08-2005, 08:36 PM
****head
EvenFlow's Avatar
Here's a few pics, sorry about taking so long.
Here is the cut (pretty rough)
Notch bolted in
Closer pic
Hope this helps, should be relatively the same as 1st gen.
EvenFlow is offline
post #12 of 87 Old 02-08-2005, 09:19 PM
No more switches
CustomS10's Avatar
might be the pic but the notch looks a little far foreword from dead center..
-Ben-
post #13 of 87 Old 02-08-2005, 09:53 PM
****head
EvenFlow's Avatar
Its the angle I suppose. Once we got it back on the ground its dead center
EvenFlow is offline
post #14 of 87 Old 02-08-2005, 11:06 PM
SOLD
MX_Racer32's Avatar
mine looked like that too with the suspension with no load on it but when compressed its dead center. my pics are working since the galleries are up if you want to check them out.
post #15 of 87 Old 02-09-2005, 07:35 PM
No more switches
CustomS10's Avatar
ahh that's right it's not under load. d'oh!
<--- captain obvious
-Ben-
post #16 of 87 Old 02-09-2005, 07:38 PM
SOLD
MX_Racer32's Avatar
its ok, i have plenty of brain farts myself when i overlook the obvious..lol
post #17 of 87 Old 12-27-2008, 12:16 AM
84blaze's Avatar
User is: 84blaze is offline
did you guys jack the truck right off the ground and support both ends of the frame your cutting?
I'm about to do a 1st gen blazer with the suicide doors bolt in c notch, im just worried about the frame torquing and ending up with my frame bent and outta shape... Would it be better to drop my leafs so theres not strain what so ever on the frame rails??
never done this before thats why soo curious...
84blaze is offline
post #18 of 87 Old 07-17-2009, 04:31 PM
Can't fly when your High
solow-noma's Avatar
User is: solow-noma is offline
Send a message via AIM to solow-noma
EvenFLow, what kind of shock are you runnin there? are they better than Belltech nitrodrop 2's
post #19 of 87 Old 07-17-2009, 10:51 PM
keepin it freshhh
Slowlowandbangin's Avatar
User is: Slowlowandbangin is offline
i have the suicidedoors bolt in c notches in mine, but i bolted them in and welded them in. i used a cut off wheel.
it came with a template to cut out, so i spray painted over the template, leaving white where i had to cut / drill.
then i did work.
my friend nate did the welds, his tip got messed up or they would have been a little cleaner.
really good notches for a static dropped truck. i never bottom out. so smooth.
here's the piece i cut out
and here they are sitting on my bed b4 install
Slightly static dropped: SLAB
Totaled
1st Time Around
Follow me on Instagram! @slowlowandbangin
Originally Posted by IhaveNoPantsOn View Post
You shut your whore mouth!
Originally Posted by BlazerZR5 View Post
all straight fact based on observations of your continued retardation.
post #20 of 87 Old 07-19-2009, 01:22 PM
Shazam!
BlazedLow's Avatar
User is: BlazedLow is offline
Are yall boxing in the inside of the frame? Or just putting the notch on and going with it? Because I know the inside of my frame is open and when I put mine I am gonna Brace the inside as well.
post #21 of 87 Old 07-19-2009, 02:35 PM
keepin it freshhh
no boxing.
painted it this morning.
Totaled
1st Time Around
post #22 of 87 Old 07-19-2009, 02:36 PM
keepin it freshhh
even flow why did you grind down the frame and put the notch over it? i hope you painted the bare metal or something...
Totaled
1st Time Around
post #23 of 87 Old 07-20-2009, 04:50 PM
4point3's Avatar
User is: 4point3 is offline
For the 2nd gen jimmy do I have to buy blazer c-notch, or I can use s-10 c-notch?
Thank you
Greg
95 4x4 jimmy 2dr. belltech 3/4 drop.2.25" y pipe.3" magnaflow exhaust.DP front brakes.zq8 steering box.ss mirrors.xtreme ground effect.salad shooters.
Poject:http://www.s10forum.com/forum/f30/pr...le-box-496647/
4point3 is offline
post #24 of 87 Old 07-20-2009, 10:54 PM
keepin it freshhh
blazer
Totaled
1st Time Around
post #25 of 87 Old 07-21-2009, 10:07 PM
yellow s10 dude
dustin_shull's Avatar
User is: dustin_shull is offline
yup, gotta use a blazer offset notch. heres the one i did on my buddies blazer....
post #26 of 87 Old 07-21-2009, 10:10 PM
yellow s10 dude
o...btw, here's sum pics of my notch and my gas tank crossmember notch....
post #27 of 87 Old 07-21-2009, 10:11 PM
BarelyGettinBy's Avatar
User is: BarelyGettinBy is offline
Thinking im gonna end up going this route since Im probably keepin my dime static for a while
post #28 of 87 Old 07-22-2009, 12:47 AM
keepin it freshhh
static is the way to go. forced to stay low. pussies with bags bring em up for speed bumps and driving. waste of money.
ride low 24/7 motha fuccccccccccc
Totaled
1st Time Around
post #29 of 87 Old 07-16-2010, 11:33 AM
User is: skindeep is offline
i no this thread is kinda old but i didnt really wanna start a new thread bout it cuz it all seems to go together but i hav a 2000 sonomma and i have this black box thts mounted to the frame right were i need to notch and cut. i think it has to do with thefuel system? but i hav no idea what it is and i was planing on getting my notches soon but i gotta figure out what to do bout tht box
2000 Sonoma base color white, with green and gold scolps lowered 3/7 belltech leafs ground force coils and local auto parts lowering blocks. 15 in baby moons.
DASH SWAP UNDER WAY, 57 chevy
98+ grey dash for sale!! its compleet wit air bag, ac vents, fuse cover, bezel! and if wanted radio,hvac control, gauge cluster etc
and complete ac unit minus the black box
skindeep is offline
post #30 of 87 Old 07-16-2010, 11:51 AM
o and dose anybody hav a pic of the template with a few mesurements? i am throwing arouund the idea of making my own and thought it would be easyr if i had something to go off of lol
skindeep is offline
post #31 of 87 Old 07-16-2010, 03:56 PM
joster's Avatar
User is: joster is offline
how strong is the frame after doing the bolt in c notch? i was talkin to my dad and he was sayin by cutting into the fram at all will weakin it and the c notch is like a bandaid. is this true? i thought it would beef it up alittle
joster is offline
post #32 of 87 Old 07-16-2010, 05:30 PM
Fronk-en-Steen
mostizzle's Avatar
User is: mostizzle is offline
skindeep-that's the fuel evap canister and it has to be relocated when doing a notch. alot of guys just mount it on the gas tank xmember above the muffler by either welding the bracket right to the xmember or drilling holes and using self tapping bolts(you can see it in that location in dustin_shulls post). i mounted mine on the drivers side frame rail which will only work if you have a roll pan because it's mounted right where the bumper bracket would be. where ever you decide to put it you'll need to lengthen the rubber hoses which IIRC are 1/4'',5/16'' and 3/4''.
joster-i can see why your dad would think that but there's no way it compromises the strength of the frame IMO. if anything i'd say it's stronger in that area now.
TelAmeriCorp
post #33 of 87 Old 07-16-2010, 06:41 PM
ok thanks mostizzle. and i hav a cali combo so tht wont be a prob lol i lik tht spot to btw
that answers one question lol any in put on the other one? lol
thanks yall
skindeep is offline
post #34 of 87 Old 07-17-2010, 12:06 AM
Fronk-en-Steen
mostizzle's Avatar
i do still have the template. i'll get a pic tomorrow if you want. what measurements do you want?
TelAmeriCorp
post #35 of 87 Old 07-17-2010, 01:00 AM
joster's Avatar
see thats what i thought too. i was just gettin a second opionon on it. i was going to do it anyway haha. i have one more question. is it necesarry to notch the crossmember for the gas tank?
joster is offline
post #36 of 87 Old 07-17-2010, 12:43 PM
overall size LxW and the diamiter of the arch. and the length of the curved piece
and the plate is 1/4 correct?
skindeep is offline
post #37 of 87 Old 07-17-2010, 07:28 PM
Fronk-en-Steen
mostizzle's Avatar
yeah it's a 1/4'' plate. personally if i was to make my own notch considering the bolt on notch is a universal deal and not necessarily made for s10's i would make my own template that better follows the s10's frame rail shape.
you can see in nitemares post how they're kind of a weird shape and they don't really follow the lines of the frame. then get a length(width of the frame or a little more) of 6'' 1/4'' wall tubing and cut it down the middle then use a half for each side.
the air is on and i'm too lazy to go out to the thousand degree garage to measure stuff lol
TelAmeriCorp
post #38 of 87 Old 07-18-2010, 12:04 AM
lol i no wht yu mean bro the heat and humity are out the ass lol
and i think i prob will make my own considering what you just said.
skindeep is offline
post #39 of 87 Old 07-18-2010, 02:09 PM
s10dollar's Avatar
User is: s10dollar is offline
I couldn't imagine living without my notches after getting them done this weekend I bought the s10 notches from suicide doors the line up really well had a problem with one bolt hole lining right up with bracket but still really worth it hardest part is getting the bed off !!
post #40 of 87 Old 09-15-2010, 02:05 PM
Under Construcktion!
SlamThiz's Avatar
User is: SlamThiz is offline
Send a message via MSN to SlamThiz
im getting ready to do my c notch install. but i got a question. i have relocated the charcoal canister. but on the drivers side there is a plate that holds a line that goes to the brakes or whatever. will i have to remove it or can i work around it?; and also it not be in the way for the c notch to get bolted in?
SlamThiz is offline
post #41 of 87 Old 09-15-2010, 03:45 PM
iroc2nv's Avatar
User is: iroc2nv is offline
What about a '01 blazer ? I'm thinking about the bolt in one from SD. Can't remove the bed from the blazer. I'm on 4" blocks in the back.
iroc2nv is offline
post #42 of 87 Old 09-15-2010, 06:16 PM
Fronk-en-Steen
mostizzle's Avatar
i cut it flush with the frame rail and bent the line slightly so i could move it towards the back some, then i just drilled a hole through the rest of the bracket and the frame and put a bolt through it with a nut.
TelAmeriCorp
post #43 of 87 Old 09-15-2010, 08:32 PM
SlamThiz's Avatar
mmmmm so u did have to cut it all the way out =/ i was hoping for a no lol but i guess it will have to be done, also how did u bend the line? any special treatment?
SlamThiz is offline
post #44 of 87 Old 09-15-2010, 09:44 PM
Fronk-en-Steen
mostizzle's Avatar
i didn't have to take the brake line off or anything. the first pic shows the chunk of frame i cut out for the notch with the piece of the bracket that i got rid of.
i just use my hands to tweak it a little so it would sit where i needed it to be, drilled a hole a popped a bolt through it. it was no biggie.
TelAmeriCorp
post #45 of 87 Old 09-16-2010, 05:54 PM
SlamThiz's Avatar
thanks dude. ill let you know how it goes. should get to it sometime this week. saturday probly
SlamThiz is offline
post #46 of 87 Old 09-16-2010, 08:41 PM
Fronk-en-Steen
mostizzle's Avatar
no problem man, good luck with it.
TelAmeriCorp
post #47 of 87 Old 09-22-2010, 04:37 PM
SlamThiz's Avatar
so i did the notch and had no problems!! haha thanks for the help
SlamThiz is offline
post #48 of 87 Old 09-22-2010, 05:53 PM
Fronk-en-Steen
mostizzle's Avatar
congrats man, did you take any pics?
TelAmeriCorp
post #49 of 87 Old 09-26-2010, 01:32 PM
SlamThiz's Avatar
well no i did not, but idk if i should lol. it was my first hack haha. to me it looks good i was impressed but i dont want to get attacked cuz it was my first time with something as serious as the chassis, the way i see it is do it right or your SOL hahaha
SlamThiz is offline
post #50 of 87 Old 09-26-2010, 02:22 PM
SlamThiz's Avatar
there.
[IMG][/IMG]
Bad eh?
SlamThiz is offline
