Bump stops?
Old 11-12-2009, 01:29 AM   #1
Chipride-slow.'s Avatar
Bump stops?
Im new to S10 forum. No one could help on blazerforum with this one. But I have a 99 4door blazer Ive lowered it 2/2 so far but I wana drop the back more to make it look lower. But my rear bump stops are already hiting with just 2in blocks in the back and I was wondering do I shave them? or can I just cuz some of the bump stop off? I have alot of bumpy roads and dips were I live and my blazer still gos places it shouldent cuz its lowered but Im woried about bottoming out.
Old 11-12-2009, 02:20 AM   #2
s10dollar's Avatar
Re: Bump stops?
just trim them u should be fine
Old 11-12-2009, 03:57 AM   #3
Short Tempered Smartass
midwests10's Avatar
Re: Bump stops?
stylin trucks makes replacement bump stops for 2-5inch drops if u want to spnd 15 bucks to replace them or that a hack saw to yours nothing wrong with that either
Old 11-12-2009, 07:39 AM   #4
keepin it freshhh
Nitemare's Avatar
Re: Bump stops?
this is on a truck but the process is almost the same for your blazer
http://www.s10forum.com/pictures_and...brac kets_off
Old 11-12-2009, 07:57 AM   #5
Jesus Damnit
redngreedy's Avatar
Re: Bump stops?
I was able to unbolt mine...Not sure how the 99's are mounted.
Old 11-12-2009, 09:04 AM   #6
keepin it freshhh
Nitemare's Avatar
Re: Bump stops?
you can do that to remove the bumpstop, but it is in his best interest to remove the whole bracket assy as well
Old 11-12-2009, 10:11 AM   #7
Jesus Damnit
redngreedy's Avatar
Re: Bump stops?
My brackets were bolted on as well.
Old 11-12-2009, 12:21 PM   #8
stupid regular cab!!
01x.joyride's Avatar
Re: Bump stops?
lucky you, i have an 01' and i don't see any bolts holding mine in at all....cut away!!
Old 11-12-2009, 01:14 PM   #9
Jesus Damnit
redngreedy's Avatar
Re: Bump stops?
Do you own a blazer?
Old 11-12-2009, 02:08 PM   #10
Re: Bump stops?
do you see a blazer in my sig???
sorry douche i didn't know there was a difference between the blazer and s10.
Old 11-12-2009, 02:10 PM   #11
Jesus Damnit
redngreedy's Avatar
Re: Bump stops?
Do you see a s-10 over
there?
Just saying.
Old 11-12-2009, 02:15 PM   #12
Layn Dime's Avatar
Re: Bump stops?
lolwut
Old 11-12-2009, 02:19 PM   #13
355 member
scrubz's Avatar
Re: Bump stops?
they'res not really. just frame, suspension, body & interior.
moron
Old 11-12-2009, 02:26 PM   #14
Re: Bump stops?
I looked at the bump stops on stylin trucks and Im not sure if mine bolt up like the ones they sell. I know my bump stops are just pushed up into the bracket on the frame. But I think Im going to go with triming them.
Old 11-12-2009, 04:16 PM   #15
Re: Bump stops?
moron
well obviously there is more dipshit from just by looking, i was just referring to the bumpstops...why would one be bolt on and one not?
**** you.
what is with you d bags?
Old 11-12-2009, 04:23 PM   #16
Jesus Damnit
redngreedy's Avatar
Re: Bump stops?
**** you.
Considering the frames of s10's, 2 door blazers, and 4 door blazers are different from each other...
Old 11-12-2009, 05:16 PM   #17
355 member
scrubz's Avatar
Re: Bump stops?
**** you.
Old 11-12-2009, 07:56 PM   #18
Re: Bump stops?
you guys should stop making harley noises...for real.
Old 11-12-2009, 08:18 PM   #19
Blu N' Primer...
Blk N' Blu's Avatar
Re: Bump stops?
you need to watch a little less south park
Old 11-12-2009, 08:25 PM   #20
Re: Bump stops?
seeing how i didn't even watch that episode...i heard about it at work
seems like maybe you should stop watching yourself
i haven't watched southpark in about a year because of switching to direct tv. thanks for telling me what i should and shouldn't watch though. highly appreciate it.
Old 12-07-2009, 01:38 AM   #21
Re: Bump stops?
nice extreme s10. i got a regular cab ls 1998 s10 and want to put a xtreme body kit on it. i got a 3/4 drop and NEVER have problems with my bump stops though
Old 12-07-2009, 08:25 AM   #22
Draggin Moderator
98layinframe's Avatar
Re: Bump stops?
i swear you bunch of idiots can find anything to argue about..
but for the original question,
blazer - pull that huge foam bumpstop out (it pops out of the metal clamp mount) and trim it down. Theres 3 large sections to the bumpstop, i cut the middle section in half and then round the end over to a point so i looks just like the factory end. This softens the impact when you hit them. Reinstall.
truck - just cut the entire metal bracket off along with the rubber.
Old 12-07-2009, 10:26 AM   #23
DriftinBlzr's Avatar
Re: Bump stops?
Here's how I did mine for my 2" block drop...
I popped the snubbers out and cut them at the 2nd groove from the bottom which shortened them about 2.5".
At ride height...
Later, Doug
Old 12-07-2009, 11:18 AM   #24
Tuckin15's's Avatar
Re: Bump stops?
Wow the blazer has a cool bumpstop setup going on there.
