best static to go with?
Old 08-19-2008, 10:19 PM   #1
billetproof97' is on a distinguished road
hey guys im new to the forums. i own a 97 chevy S-10 with a 2.2L in it. the front is lowered incorrectly because i think the previous owner either heated the stock springs or did a chop job on them to make it lower in the front. i have the WORST alignment, and oh yeah its got chevy lean too! so i think its time to fix his hack job. now my question is whats the best static suspension to go with? i see a lot of guys going with the Belltech and JDM suspension. I know i need to go out and measure what my ride hight is at now so i can choose what drop i want. i was thinking 4/5, 5/5, 5/6, BUT i might be dreaming. LOL i do have rims to go on the truck when i get this done they are 17x8 im not sure what tire to use either maybe a 205/45/17? i just wanted to see what everyone's opinion is on this. i think they both would be great on my little S-10. i think i will be buying all my suspension parts from summit. also whats the difference in the mono tube and twin tube for the shocks?
Brandon
Old 08-19-2008, 10:36 PM   #2
civil's Avatar
civil is on a distinguished road
Re: best static to go with?
from that pic it looks like a 5/6. and it looks good like that. you should be able to fit those 17's with no problem with that drop. also with measuring you might find out that you need a notch... if that truck doesnt have one already. but it looks good now. it'll ride a fook load better when you change all that crap for real stuff.
Good place for info when you measure:
http://www.s10forum.com/forum/f12/fi...ht=FInd+stance
Old 08-19-2008, 10:43 PM   #3
Quote: Originally Posted by civil
from that pic it looks like a 5/6. and it looks good like that. you should be able to fit those 17's with no problem with that drop. also with measuring you might find out that you need a notch... if that truck doesn't have one already. but it looks good now. it'll ride a fook load better when you change all that crap for real stuff.
you talking about C notch the rear? i dont think it is, but i need to look. i was just looking at your 5/5 drop and thats how low i want mine, if its possible. your truck is sex on wheels! i notice when i drive on the highway it pulls pretty good to the left (left side is lower than the right side up front). dang alignment!
Old 08-19-2008, 11:35 PM   #4
civil's Avatar
yea i was talking about a C-notch for the rear. and a 5/5 is totally possible for your truck. Gonna wait on the alignment tell you get it lowered correctly? be the best way to go. no point in paying twice. Only reason why i ask about the notch is because some people need it for the rear. and some don't. they all come out different. but for me the 5" in the rear gives me that little bit extra of clearence so i don't smack frame and axle. if it isn't notched and you still have stock bumpstop brackets back there.. those should be gone with how low your truck is. but you'll need to grind those off if they arn't already. big ride difference and lots of extra clearence. lol and im sure you've read most of this on the forums so far.
Old 08-19-2008, 11:43 PM   #5
im trying very hard to research all i can. ive used static to lower my previous car. but nothing compares to a 5/5 drop. the most ive lowered my previous car was 1.8in all the way around. yeah for the rear are you using stock leaf springs? or did you buy belltech. i was thinking of buying the belltech multi-leaf the price is kinda steep $95.95 on summit, but if it helps to lower the truck then why not? LOL and as for the front my brother was like "you need an alignment" and i was telling myself " im not paying twice when im going to correctly lower the truck" LOL also did you have to modify the frame in the back where the driveshaft is? did you notch that? or would that be for the bagged guys? LOL...also can you direct me to where you bought your belltech's 5/5 drop at?
Brandon
Old 08-20-2008, 01:02 AM   #6
civil's Avatar
pm sent.
And to answer a few questions. I didn't need to modify my frame at all. Summit has all the parts i needed. i just cross checked my part numbers with Belltech's part numbers on Summit and ordered away.
Old 08-20-2008, 01:05 AM   #7
Registered Habitual User
WhiteNoise96's Avatar
WhiteNoise96 is on a distinguished road
4/5 because you can still get into most places without having to worry much.
Old 08-20-2008, 01:05 AM   #8
bellcranks no more
greencactus3's Avatar
greencactus3 will become famous soon enoughgreencactus3 will become famous soon enough
driveshaft wont hit anything until you get a notch, then you start hitting the gas tank xmember
Old 08-20-2008, 11:32 AM   #9
thats what im worried about. getting too low and start hitting stuff
Old 08-20-2008, 02:17 PM   #10
civil's Avatar
its a standard cab. he shouldn't have any problems with that... should he? i haven't run into this problem.
Old 08-20-2008, 10:12 PM   #11
Have a nice day!
ProTouring2.2's Avatar
ProTouring2.2 will become famous soon enoughProTouring2.2 will become famous soon enough
get a bigger tire than 205/45, those will be like rubberbands
Old 08-20-2008, 10:56 PM   #12
bellcranks no more
i dunno. my std cab hit.... but its a longbed.... who knows
Old 08-21-2008, 07:52 PM   #13
how bout a 215/45? or should i go bigger?
Old 09-08-2008, 09:44 PM   #14
Re: best static to go with? update!!! 9-8-08
ok so i got chevy lean check out the pictures LOL
Old 09-08-2008, 09:56 PM   #15
Have a nice day!
that's like a 3/4 drop
i think 4/5 is the best drop to have... low enough to look good while retaining good suspension geometry and not bottoming out all the time
Old 09-08-2008, 10:09 PM   #16
yeah today i tried to check the drum brakes, but i couldnt get the rims off. i checked and it appears the frame is notched. it looks like a 2 inch C notch. i will have to post pictures of it. the welds are OK they dont look the greatest. and yesterday i was looking at the front greasing up everything and on the left front there is a ball joint that crushed? i need to fix this asap! more pictures to come, and i need to order my belltech stuff pronto!
Brandon
Old 09-08-2008, 11:23 PM   #17
Mr. Token Black
chvys10's Avatar
chvys10 is on a distinguished road
Brandon
If you are looking for springs, I have a pair of belltech 3 inch drop springs and 2 pair of 3 inch drop blocks and 1 pair of 4 inch drop blocks if you are interested.
just shoot me a pm if you are, and good luck with the re-build up
Old 09-09-2008, 02:38 PM   #18
thanks this will be my first build up, LOL the previous owner did all the work. but pm sent, and thanks again
Old 09-10-2008, 01:27 PM   #19
civil's Avatar
love how the truck was lime green before it was rattle canned? or someone used a spray rig for texturing a house. but for your truck id agree with the guys and go with a 4/5. you'll sit damn close to what the truck does right now. and it will ride a crap load better. with a 4/5 you'll still have to watch out for speedbumps, curbs, concrete blocks(shitty story ). So go with for the front 2" drop spindles, and 2" drop springs. And for the rear get 3" drop leafs, and 2" drop blocks. and some Nitro2 drop shocks all around. Easiest way to go.
Old 09-10-2008, 04:23 PM   #20
so a 5/5 isnt recommended? i really dont drive it much over bumps, and i take alternate routes when i travel to work to avoid this situation. and civil id like to hear this story pm me man! and the previous owner did the primer job on it and its pretty smooth i guess he took his time in wet sanding it? it wasnt rattle canned i dont think. the interior green plastic pieces were done by a paint shop.
Old 09-10-2008, 05:35 PM   #21
Doin it My Way
Cauzin_Statik is on a distinguished road
6/8 including tires. 5/7 w/o. These are 17x8 wheels. For everyone that says dont go that low is just scared of taking a lil bit of a beating. Nuthing drags that shouldn't on it and its drives, handles, and feels better than stock.
Old 09-10-2008, 05:51 PM   #22
are you using belltech as well? truck looks good! i like the stance. i wouldnt mind a 5/5 drop i just need to be extra careful
Old 09-10-2008, 06:34 PM   #23
also you guys with 5inch drops in the front do you guys have rubbing issues? i have rubbing issues when i make sharp turns.
Old 09-10-2008, 06:44 PM   #24
llorracs93s10's Avatar
llorracs93s10 is on a distinguished road
check out the sticky at the top of the wheel/tire/brake section. Theres a thread about wat size tires you can go with certain drops.
here it is
http://www.s10forum.com/node/47
Old 09-10-2008, 06:51 PM   #25
here it is
thx. idk why my stock rims, and tires rub. the truck is lowered improperly in the front. i have a 17x8 and it should fit. thanks for the help
Old 09-10-2008, 06:53 PM   #26
no problem...although i dont know if that is exactly correct or not on all sizes, i just know that its helpful when you dont know anything.
waht size tires u got on them?
Old 09-10-2008, 07:35 PM   #27
civil's Avatar
5/5 is not recommended for the driver that won't take the time to slow down. :P i drive daily on a 5/5 drop. And i drive it like a crazy a$$hole. but the roads out here are really nice. i love the ride. its nice and stiff and responsive. Since you live in texas.... im assuming your roads are pretty good? an inch in the front won't make much of a difference. its totally upto you man.
Old 09-11-2008, 12:18 AM   #28
i have 17x8 MB motorsports "boost" rims. they are wrapped in 205/45/17 tire, but i need new tires. heres a pic of the rim
heres my old car i had them on...
Old 09-11-2008, 12:21 AM   #29
LOL dont worry i will try to be careful. and texas roads here are OK. they are not the greatest. but when i travel to work and such i plan my route out. hell one time i went through this intersection with a big ass dip i was doing bout 40 and i bottomed out. i was like crap no damage luckily
Old 09-11-2008, 10:07 AM   #30
Doin it My Way
I dont have any rubbing, but if you use those wheels you are gonna. Your spacer is gonna push em out too far.
Old 09-11-2008, 01:50 PM   #31
so my 17x8 has to much space? i thought the sticky with the rims sizes recommended the 17x8 on a 5inch drop...
Old 09-11-2008, 04:16 PM   #32
civil's Avatar
