angled blocks vs reg blocks
Old 07-24-2008, 10:08 PM   #1
Sipolt89 is on a distinguished road
im doin a 6 inch drop in the back and i got 3 inch leafs and 2 inch blocks but im gonna drop another inch and cut the bump stops like halfway out. my question is whats the dif beetween angled 3 inch and reg 3inch.i know its got a slight angle but does it make a difference? and if so what does it do.i got a 97 reg cab
Old 07-24-2008, 10:21 PM   #2
mechanicix's Avatar
mechanicix is on a distinguished road
Re: angled blocks vs reg blocks
Angled blocks are used to change your pinion angle so the driveshaft doesn't get thrown off balance and vibrate.
Old 07-25-2008, 01:31 AM   #3
so would they be better than?would it make a difference in ride height?theyre both the sam eprice so im just deciding what one to get
Old 07-25-2008, 09:54 AM   #4
Ticket Magnet
Rhotpursuit's Avatar
Rhotpursuit is on a distinguished road
1. Yes...unless you don't mind the vibration and ensuing carnage. Drop the driveline before you do the drop. If it won't go back in, get it shortened.
2. No
Take the entire bumpstop and bracket out.
Old 07-25-2008, 10:53 PM   #5
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura aboutterryl has a spectacular aura about
You may not need angled blocks. The only way to know what you need is to do the drop and then measure the operating angles at each end of your drive shaft. If they match you are ok.
If your drive shaft is bottoming out in your tranny after the drop, you can add setback plates under the blocks to gain 1/2" more clearance. A lot cheaper the having the shaft shortened.
Old 07-25-2008, 10:55 PM   #6
Llama > Penguin
dngrous_dime's Avatar
dngrous_dime is an unknown quantity at this point
buy the non-tapered blocks, and be ready to order shims to correct the angle if it's off.
Old 07-25-2008, 11:23 PM   #7
Ticket Magnet
If they match they are not ok...You need a little angle to ensure needle bearing rotation in the u-joint. Setback plates may work, but 1/2 inch may not be enough. The original u-joints are probably still in there and are probably due for a change. Shortening a d/s isn't that bad and in the long run you won't grenade the tranny and you get new joints....but to each his own..
Old 07-25-2008, 11:39 PM   #8
terryl's Avatar
I agree that 1 degree off would be ideal for lubrication. On the shaft, if 1/2" is enough, it would be much cheaper. He needs 3/4" between the tranny and yoke when at ride height. Any less could cause the problems. If the joints are not bad, don't replace. If they are, then replace. Simple.
Old 07-26-2008, 08:26 AM   #9
Llama > Penguin
If you've got it all apart, I'd go ahead and change them. They're only like $5 each. On the other hand, if your vise is a piece of shit that likes to launch sockets across the shop, causing the bearing caps to drop needle bearings on the floor, then you might wanna just let it be until they DO go bad.
Old 08-09-2008, 06:25 PM   #10
terryl's Avatar
If they match you are not ok...You need a little angle to ensure needle bearing rotation in the u-joint. Setback plates may work, but 1/2 inch may not be enough. The original u-joints are probably still in there and are probably due for a change. Shortening a d/s isn't that bad and in the long run you won't grenade the tranny and you get new joints....but to each his own..
After reading this again, I disagree. If the two operating angles match you are OK. Rhotpursuit you are confusing operating angles matching to operating angles being 0.
If you have, for example, an operating angle of 3 degrees for the tranny to shaft and an operating angle of 3 degrees for the shaft to the pinion, then it is perfect and will be lubricated because no one operating angle is 0. If an operating angle between two components is 0, then no lubrication.
You need at least one degree operating angle between any two components. The angle causes the second component to speed up and slow down, thus forcing these grease to move around in the joint.
Page generated in 0.14804 seconds with 12 queries
