7" or 8"
do they make a 7" or 8" lowering kit
BOUGHT NOT BUILT
Location: Mt. Washington, KY User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: 7" or 8"
search
and you still have a couple years before you can legally drive |
Neglect
Re: 7" or 8"
5/7 or sometimes 6/7 is the lowest people usually go static. 3" coils, 2"spindles, 3" leafs, 4"blocks. Most people just put a kit together using the the brands they prefer. I like belltech stuff. Don't forget to add drop shocks.
i wouldnt undertsand
Re: 7" or 8"
5/6-5/7 drop is plenty low with a fairly small tire tho man.. good luck ![]() |
Re: 7" or 8"
well i am going to put 20s or 18s i know i will have to cut the wheel wells out and with a 7 or 8 in will i have to do a small c knoch
BOUGHT NOT BUILT
Re: 7" or 8"
dude, do some research before you actually buy anything. i can't even put 20's on my 4/5. if i rode with them on, and hit a bump while turning, my fenders would be toast
and no, you will not need a small notch, you will need a big notch |
bellcranks no more
Re: 7" or 8"
no, youd need more than 2.25" cnotch for 8"+ in back. i pretty much laid in the notch for 8"
Re: 7" or 8"
do u get over speed bumps nice? lol
bellcranks no more
Re: 7" or 8"
Re: 7" or 8"
greencactus3 what is ur drop?
bellcranks no more
Re: 7" or 8"
Re: 7" or 8"
i am feeling a 6" 6" drop what dose every one think?
bellcranks no more
Re: 7" or 8"
Re: 7" or 8"
no i do time and money
bellcranks no more
Re: 7" or 8"
BOUGHT NOT BUILT
Re: 7" or 8"
yea, listen to ryo, he knows what he's talking about. even with my 4/5, i have to avoid speedbumps, steep driveways, little things that you wouldn't think twice about in a regular height truck
I.G.'s FTW!
Re: 7" or 8"
With 18's you can go that low with a thin tire, with 20's nope.
By the time you can drive then your S-10 will be a classic |
started as a 4X4 anyway
Re: 7" or 8"
I you want to ride that low with big rims you are going to have to bag it. I drove my 91 jimmy around with the frame 1 inch off the ground, with a 28 inch tall tire. The front control arms need to be dehumped, inners removed, notched for tie rod clearance, and a full notch in the rear is a must.
My front fenders got messed up from hitting the tires, so I bagged the front. So if you plan on going that low just at least bag the front, you will be happy you did. |
Re: 7" or 8"
Re: 7" or 8"
i am going 5 all the way around
I.G.'s FTW!
Re: 7" or 8"
How Old Are You Really??????
Re: 7" or 8"
18
I.G.'s FTW!
Re: 7" or 8"
I'm 25
#24 |
Xtreme Measures
Re: 7" or 8"
Just got back from a camping trip. My bumper became a shovel in the dirt lol. Its alright tho cause its on there now with about 50 hi-loc's so its not coming off. |
#25 |
I have the disease
Location: E. central MN User is: OffLine ![]() ![]() ![]() ![]() ![]() |
Re: 7" or 8"
If you want to realistically drive your truck static, don't go any lower than a 5-6 drop, any more than that, you need bags. I had a 91 ext cab that was 5-6 and I had to be very careful.
#26 |
I.G.'s FTW!
Re: 7" or 8"
I seen a guy that had just dropped his S-10 about 6.5/7, he lifted it back up the next day.
#27 |
Re: 7" or 8"
I had a 6" drop on the front of my truck years ago... drove it around the block once and promply parked it until i could order new taller coils with a stiffer spring rate to lift it back up and make the ride alittle tighter. Even then with a 5" drop i still had rubbing and would bottom out once and a while.
Just do a 5/6 drop for now as you will probably be more then happy with it. Also ya have to remember with that much drop the stock height 205 75 15 tires wont clear the inner fenders for shit, so you will have to get a set of new tires more along the lines of a 215 60 15 which will also lower the truck down some more on top of the drop ya allready got with the kit. |
#28 |
Blazer User
Re: 7" or 8"
off topic post but i seen the lowest static drop other day.
it was on a 4dr blazer. the leaf spring was maybe like maybe 2, 3in max off the floor. i seen higher bagged trucks than that. LOL! |
#29 |
Have a nice day!
Re: 7" or 8"
5/6 is too low for me, i'm lifting up to 4/5
it ****in sucks after a while... theres no real benefit to being that low. None. |
#30 |
4/5 drop
Re: 7" or 8"
my 03 was a 4/5 drop on 18's. it was pretty damn low. it got old at times and took a lot of explaining to people that had no idea why it scraped when i drove. dates were kinda awkward. lol. |
#31 |
I.G.'s FTW!
Re: 7" or 8"
when I 1st got my 99 Sierra it had a 4/6 drop and crappy shocks w/17" bald tires, took a girl on a date in it and she bitched about the ride, it did ride rough though
#32 |
dropt
Re: 7" or 8"
i got a 4/5 on 20's i rub the inners on big bumps. gotta explain it to people like the guy above me. and i love slamming speedbumps. don't ask me why, i just like to. my roll pan got ****ed up the other day when i took a load of stuff to the landfill. big ruts and stuff from the big trucks, the compactor drivers stopped and looked at me like i was crazy. i don't let being low hold me back. i'm about to bag my truck though, so it don't matter.
#33 |
I.G.'s FTW!
Re: 7" or 8"
I know this guy that had hi |
