5" blocks
Old 06-29-2008, 01:27 PM   #51
bellcranks no more
greencactus3's Avatar
Re: 5" blocks
nah, if they wanna think its safe or a good ride with tall blocks, let them... my truck isnt on the road
i used to think blocks give the same ride, but from when i took my 3" blocks out, i will never say blocks are a good way to drop a truck.
Old 06-29-2008, 02:26 PM   #52
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura about
Re: 5" blocks
I've only ran the 2" blocks and didn't notice any difference. Not interested in trying tall ones though.
Old 06-29-2008, 03:30 PM   #53
Ding Fries Are Done
ZQ8 Blazer's Avatar
ZQ8 Blazer will become famous soon enough
Re: 5" blocks
^do you have a 2/2.5 drop or a 2/2.5 drop on top of the 1.5 drop???
Come to think of it mine does ride better now with a pulled leaf, 2" blocks, shims, and set backs. I was using the same shocks with the 4" blocks that I'm using with the new setup. What would make the ride better other than different pinion angle(the 4" ones had a different degree on the angle) and the setbacks. I mean it's not drastically better or anything, but it is noticeable.
Old 06-29-2008, 09:47 PM   #54
terryl's Avatar
Re: 5" blocks
02 Black S-10 Xtreme ext. cab 4.3, additional 2/2.5 drop and a bunch of other stuff
You have shorter shock travel now with the pulled leaf. Drop shocks maybe?
It's only a guess, but you more than likely need about the same angle shims you had before. You still have near the same total drop don't you? Need to get those measurements if you haven't already.
Old 06-29-2008, 10:10 PM   #55
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
Sorry me no read so good.
I thought the distance of travel on my drop shocks might come into play with the ride but didn't know.
The pinion angle is correct now. That 4" block threw it off. I am 1/2" lower now.
Old 06-30-2008, 10:23 PM   #56
Xtreme Measures
xtrememeasures10's Avatar
xtrememeasures10 is on a distinguished road
Re: 5" blocks
Quote: Originally Posted by chrisisdashiznt
i have 4" angled and it rides awesome i also cut all bumpstops off
You have 4" angled on a std cab? i though angled were only for ext cab? I have 3" straight blocks on mine but a set of 4" angled sitting around. My front bumper is 3 inchs from the ground i would like to pull it up about a half to 1 inch lowering the back a little bit more.
Old 07-01-2008, 02:07 AM   #57
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
You need an angled block beyond 3" in most cases. But read my sig...
Old 07-01-2008, 11:10 AM   #58
This is doo doo baby!
wildman ss's Avatar
wildman ss is on a distinguished road
Re: 5" blocks
A Smart Man Washes His Hands After He Pees, A Smarter Man Doesn't Pee On His Hands
I don't see what that has to do with blocks
Old 07-01-2008, 03:21 PM   #59
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
Oh you're hilarious!
Old 07-01-2008, 08:54 PM   #60
Xtreme Measures
Re: 5" blocks
So Not to whore this guys thread or anything but my drive shaft is making a nasty noise over 60mph I think its the angle that my rear diff is sitting at now. Im curious i have 4 inch angled blocks too would that set my diff up at the correct angle?
Old 07-01-2008, 08:56 PM   #61
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
Maybe, maybe not. Is it a noise or a vibration?
Old 07-01-2008, 09:55 PM   #62
Xtreme Measures
Re: 5" blocks
Noise. Its a grinding noise.
Old 07-01-2008, 11:37 PM   #63
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
Check to see if it's hitting the crossmember.
Old 07-02-2008, 12:04 AM   #64
Banned
sonomanator is infamous around these partssonomanator is infamous around these parts
Re: 5" blocks
this redneck by my house used hockey pucks to do a body lift.
Old 07-02-2008, 12:20 AM   #65
that short kid
shortS10owner's Avatar
shortS10owner is on a distinguished road
Re: 5" blocks
Ok. An den?
Old 07-02-2008, 12:30 AM   #66
Banned
Re: 5" blocks
thats all i heard some one else talk about it. but longer story my friend got it off the guy right before he did it and he didnt relize how it was done till recently.
Old 07-02-2008, 12:31 AM   #67
that short kid
Re: 5" blocks
an den?
Old 07-02-2008, 12:35 AM   #68
Banned
Re: 5" blocks
no an den!
Old 07-02-2008, 03:00 AM   #69
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
HEY, this is relevant to the thread! Wow imagine that.
Old 07-02-2008, 03:02 AM   #70
Banned
Re: 5" blocks
Quote: Originally Posted by lowcherrydime
or you can use blocks of wood or hockey pucks lol.
that
Old 07-02-2008, 03:12 AM   #71
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
Fixed it.
Oh yeah that was on the 1st page, I haven't read it in awhile...
Old 07-02-2008, 03:21 AM   #72
Banned
Re: 5" blocks
lol nice fix
Old 07-02-2008, 04:28 AM   #73
Real Men Wear Skirts!!
my2ks10xtreme's Avatar
my2ks10xtreme is on a distinguished road
Re: 5" blocks
I'm currently running zq8 leafs and 4" angled blocks, rides fine but I bottom out on my frame just as much when I had 3" angled blocks, don't see the big issue in it.
I'm also running 20s with 35 series tires, bagged in the front. I never heard or would recommend a 5" block doesnt sound save, Only temporary until I bag the rear in the next few months
Old 07-02-2008, 02:43 PM   #74
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
If you don't see the big issue then that's ok.
I don't see how you can bottom out on the frame the same when you're an inch closer to it...
Old 07-02-2008, 06:03 PM   #75
Re: 5" blocks
Basically what I was trying to say is I bottom out on my frame at the same exact areas I used to bottom out when I had my 3" blocks, one spot is on the freeway going to work and another spot going home from work other than that I never bottom out.
So to me there is no difference between running either or, Now if your going to be permanently static I would recommend just picking up 3" drop leafs and 2"-3" blocks with a bolt in c-notch.
Old 07-02-2008, 06:34 PM   #76
Call me Mario, Princess
AceHaag's Avatar
AceHaag is on a distinguished road
Re: 5" blocks
Quote: Originally Posted by 5" blocks
YOU'RE TOO CHEAP TO DO IT RIGHT!
Old 07-02-2008, 07:43 PM   #77
Ding Fries Are Done
ZQ8 Blazer's Avatar
Re: 5" blocks
Ok I gotcha now.
Page generated in 0.30117 seconds with 11 queries
