5" blocks
will 5" blocks work on an xtreme with a 45 series tire?. what will I need in the front to even it out.
Re: 5" blocks
um....i will have to say,
![]() that is bad due to the fact your u bolts will be so close to the ground it will not be funny. And its unsafe in my eyes to have blocks that tall for many reasons. Just get 3 inch leafs and 2 inch blocks. worht it to get leafs. ALso the ride will be crap with taht tall blocks. |
that short kid
Re: 5" blocks
Where can you even get 5 inch blocks? I don't like my 4 inch ones, Id hate to be rollin on 5 inchers
Re: 5" blocks
might as well just weld you rear end to the frame.
stayin static
Re: 5" blocks
now theres an idea!
I'll do it tomorrow
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() |
Re: 5" blocks
And you would have to let the air out of the front tires.
Ding Fries Are Done
Re: 5" blocks
This is the dumbest question ever yet people keep on asking it. The mods need make a sticky that says "NEVER USE 4" or 5" BLOCKS"
I'll do it tomorrow
Re: 5" blocks
You gotta admit, it still gets a laugh though.
Ding Fries Are Done
Re: 5" blocks
yeah it does.
It'd be better if he ran two straight 3" blocks stacked with 4 hellaciously long u-bolts Last edited by ZQ8 Blazer : 06-28-2008 at 05:05 PM. |
Ding Fries Are Done
Re: 5" blocks
that short kid
Re: 5" blocks
Re: 5" blocks
So i go, why not take a look its only a beater....turns out he had 2 blocks stacked one on top of the other...i was like, wtf and just to tell you, the ubolts were about 1/2 inch off the ground, ![]() |
Re: 5" blocks
i have 4" angled and it rides awesome i also cut all bumpstops off
Founding member of DA
Re: 5" blocks
i dont understand how a block affects how it rides? you dont change the shock or the spring you're just changing how far the rear end is from the leaf
but 5 inch blocks are def. a bad idea |
Ding Fries Are Done
Re: 5" blocks
I had 4" blocks to start with and the u-bolts were real close to the ground I drug them coming out of my driveway and pulling out at other spots and I'm running 235/55/16. I had EXTREMELY bad wheel hop. If you're running a 15 or a 16 inch wheel with low-pros then it'd be even worse.
One of my big beefs with a 4" is that it makes the back end look funny because it puts a big space between the axle and the leafs. If you like the 4" blocks then keep them, but they're not the best way to lower a S-10. 1. The pinion angle is not correct, you'd get vibrations. 2. If the u-bolts drag. 3. If the frame hasn't been clearanced for the drop. I originally lowered mine 3/4 but then was going to do 4/5 and was telling another guy that lives around where with a blazer and he told me to get a 1" block and " Stack em' " I ended up pulling a leaf and getting JTR stuff to give me a 4/4.5 Last edited by ZQ8 Blazer : 06-28-2008 at 05:39 PM. |
truth
Re: 5" blocks
blocks are cheap for a reason.
Ding Fries Are Done
Re: 5" blocks
Did you know that you can also lift some vehicles with blocks? THAT IS AMAZING!
truth
Re: 5" blocks
or you can use blocks of wood or hockey pucks lol.
Ding Fries Are Done
Re: 5" blocks
Don't even joke about that. There is a guy around here that bought a POS S-10 and took the coils out and put a block of wood between the frame and lower a-arm then mono leafed the back. That thing looked like it rode great
Re: 5" blocks
okay, so no one answered my question, you all just argued whether not that tall of blocks were a bad idea or not. so if i was to buy leafs. what would I need in the front to even it out? and would it be alright on a 45 series tire?
Re: 5" blocks
That's funny, any idea what size the blocks were?
I originally lowered mine 3/4 but then was going to do 4/5 and was telling another guy that lives around where with a blazer and he told me to get a 1" block and " Stack em' " I ended up pulling a leaf and getting JTR stuff to give me a 4/4.5[/quote] they probably were 3+3 cuz the stock tires/wheels were damn near having no wheelwell gap. okay, so no one answered my question, you all just argued whether not that tall of blocks were a bad idea or not. so if i was to buy leafs. what would I need in the front to even it out? and would it be alright on a 45 series tire? well i woudl do 3 inch leafs and 2 inch blocks and than get 2 inch drop spindles and 2 inch coils. That would give you a 4/5 drop |
Ding Fries Are Done
Re: 5" blocks
If I was you I'd get 1" coils, 2" spindles, and keep your 1.5" leafs then get a set of 2" blocks. That will give you a 3/3.5 drop. If you don't like a little rake then JTR sells 1/2" blocks.
Your coils are also worth a little since they're 1.5" drop coils I just typed that above because I was thinking it was a 16" wheel with a smaller tire since it's an Xtreme, but his avatar's truck has a set of wheels on it. Last edited by ZQ8 Blazer : 06-28-2008 at 06:26 PM. |
truth
Re: 5" blocks
#24 |
I'll do it tomorrow
Re: 5" blocks
#25 |
I'll do it tomorrow
Re: 5" blocks
#26 |
Ding Fries Are Done
Re: 5" blocks
What now HUH???? One more time! lol |
#27 |
that short kid
Re: 5" blocks
And I'm not saying that 4 inch blocks are the best way to lower a truck either. I would much rather have bought 3 inch leafs with 2 inch block in the back, but then I still wouldnt be the same height since I have a zq8. It would be either a 4, 5 or 6 inch drop depending on what size blocks are added to the drop leafs. But at the tiem I did it, money was tight, so I went with blocks, and have had zero problems, and still didnt have wheelhop even when I would screw around, wet or dry pavement. But like I said, I'm not trying to jump on anyone or trying to make myself sound bad, it just annoys me when people say do this, dont do that, when if you do what your supposed to with the blocks, everything is perfectly fine and normal with no residual effects..... Last edited by shortS10owner : 06-28-2008 at 07:30 PM. |
#28 |
I'll do it tomorrow
Re: 5" blocks
Just because I agree with you doesn't make us right. And, for the record, I'm not dead against 4" blocks if you take it easy on the gas. I am however against axle wrap. Try getting on it with those blocks. That's the problem I have. It just gives the leafs too much leverage. |
#29 |
Re: 5" blocks
#30 |
that short kid
Re: 5" blocks
haha. good. I know some people may not like them for various reasons, but thats with any product of any kind. I just hate people saying "Zomg! Do not use 4 inch blocks!" Nothing against you guys. Especially you old man
#31 |
