Wynjammer 4.3 dyno's? - S-10 Forum
post #1 of 53 Old 10-08-2012, 03:44 PM Thread Starter
User is: 98s104wd is offline
Hey guys, I am just curious as to the tyipcal power output from the Wynjammer (both 6psi and 9psi) on our 4.3L.
If you have a Wynjammer on a 4.3 please post up dyno numbers/graphs and 1/4mile times if you'd like.
I've only seen like 2 dyno sheets after searching for hours and they all seem pretty low.
98s104wd is offline
post #2 of 53 Old 10-08-2012, 05:37 PM
i need a paint job
s106banger's Avatar
User is: s106banger is offline
Send a message via AIM to s106banger
Re: Wynjammer 4.3 dyno's?
i have some dyno numbers in my "small wynjammer build" thread.
1997 S10 266ci V6-turbo. 4l80e. 8.8. 23lbs.
10.93@122
526rwhp 531ftlbs on a mustang dyno @20lbs.
build thread-http://www.s10forum.com/forum/f11/no...r-more-481754/
2002 S10 2.2-DD 80% ZQ8 clone "TuTu Powa" w/efans. 98rwhp 111ftlbs!
post #3 of 53 Old 10-08-2012, 05:43 PM Thread Starter
Do you care to post the numbers and/or graph in this thread so people searching Wynjammer dyno can come across it easier?
98s104wd is offline
post #4 of 53 Old 10-08-2012, 07:01 PM
i need a paint job
s106banger's Avatar
depends what dyno your talking about...
220whp-228ftlbs on a mustang dyno with a stock engine, headers and fmu
239whp-250ftlbs on a dyno jet, same setup.
244whp-260ftlbs? on a superflow with a comp 270, marine intake, 0411 ecu.
all runs with 8lbs of boost.
all the dyno sheets are already posted in there? its not like its a hard thread to find...
10.93@122
post #5 of 53 Old 10-09-2012, 11:27 AM Thread Starter
You only put down 244/260 on 8 lbs, comp 270 cam and marine intake?
I guess breaking 250whp with the Wynjammer is proving harder than I orignally thought.
98s104wd is offline
post #6 of 53 Old 10-09-2012, 11:47 AM
Reiners Rigs
User is: reiners88 is offline
It can be done. The comp 270 isn't the best choice for boost. That's why I've stated having comp spec you a cam that will make power with the jammer. It's not impossible, but you can't expect to make big numbers with minimal mods and then bolting a SC.
96 ext cab 4.3, TES Edelbrock headers, 3/4 drop, speedway UCA's, 75shot
99 ZR2 Blazer 2 inch shackle and t bar crank.
post #7 of 53 Old 10-09-2012, 01:07 PM
White03s10's Avatar
User is: White03s10 is offline
I dont have dyno numbers,but my D1SC charged s10 with minimum mods moves pretty well....
2003 S10 X-cab with 4.3L, D1SC Procharger w/10lbs boost, ATI Intercooler,Alcohol injected, 36 lbs injectors,Custom Y-pipe, Tuned, Magna-Flow exh., T-blade mod, C5 Z06 front brakes, Rear discs, Caltracs, B&M Ratchet shifter, 3/3 drop, ZQ8 wheels-swaybars- and steeringbox,KYB shocks. Daily driver and very fun at that!!!
DEMODDED AND SOLD.....
Bought a Silverado SS
post #8 of 53 Old 10-09-2012, 01:28 PM
i need a paint job
s106banger's Avatar
im not sure why your stuck on dyno numbers?
if i would have put it on the dynojet with the same setup i would have put down 275ish...
dynos are for tuning, if your going to compare it better be the same dyno.
now the truck did run 13.7@100 with meth and a 2.0 60'. with a converter it would have ran mid to low 13's.
10.93@122
post #9 of 53 Old 10-09-2012, 02:52 PM Thread Starter
I was hoping to hit 300whp and break into the 12.9's if possible, but both goals seem a little far fetched for a mild 4.3 with a Wynjammer.
98s104wd is offline
post #10 of 53 Old 10-09-2012, 03:16 PM
Reiners Rigs
Only way you'd hit 12.9 is with a little bit of spray with the jammer. You'll get some good power out of the 4.3 with a jammer but don't expect to stay with a new camaro or mustang.
post #11 of 53 Old 10-09-2012, 05:20 PM
i need a paint job
s106banger's Avatar
i like how reliable the thing was. held up for years, plus i bought it used.
10.93@122
post #12 of 53 Old 10-09-2012, 05:38 PM
Reiners Rigs
Theres one in the classifieds for 1200. Wish I had the cash id get it!
post #13 of 53 Old 10-09-2012, 06:11 PM
HopnDude's Avatar
User is: HopnDude is offline
What area?! St Louis, MO?!
EDIT: No, mine's at 1300.
HopnDude is offline
post #14 of 53 Old 10-09-2012, 06:54 PM
i need a paint job
s106banger's Avatar
wouldnt mind one for the tutu...
it would make cool noises and run 16's. lol.
10.93@122
post #15 of 53 Old 10-09-2012, 07:02 PM
Reiners Rigs
Haha ^
post #16 of 53 Old 10-09-2012, 07:42 PM
HopnDude's Avatar
LoL!
HopnDude is offline
post #17 of 53 Old 10-10-2012, 12:06 AM Thread Starter
So it'd be pretty impossible to break 300whp and a 12.9 without nitrous?
98s104wd is offline
post #18 of 53 Old 10-10-2012, 12:13 AM
i need a paint job
s106banger's Avatar
with the wynjammer, yea.. pretty much.
10.93@122
post #19 of 53 Old 10-10-2012, 12:46 AM
HopnDude's Avatar
98s104wd....do what I did, save your money, then do our build....best way to do it....or park it, & work on it slowly while you get a daily beater!....
HopnDude is offline
post #20 of 53 Old 10-10-2012, 03:06 PM Thread Starter
I have a daily Civic for good mpg, but was hoping to get a little more out of the 4.3 with a Wynjammer.
Maybe Ill have to start a custom turbo build, unless you guys know of a "kit" that Im unaware of....
98s104wd is offline
post #21 of 53 Old 10-10-2012, 03:27 PM
Reiners Rigs
Only "kit" around is from DTS2.net but he's still developing it. Hopndude's is apparently the first one. So it'll be a while till you can get one. That's why I'm spraying mine and doing some internal work till I can afford his kit.
post #22 of 53 Old 10-10-2012, 06:56 PM
HopnDude's Avatar
"My Precious!" lol
HopnDude is offline
post #23 of 53 Old 10-10-2012, 09:31 PM
Reiners Rigs
LMao hahahaha
post #24 of 53 Old 10-11-2012, 05:22 PM Thread Starter
Originally Posted by HopnDude View Post
"My Precious!" lol
Any dyno/track numbers from your TT 4.3?
98s104wd is offline
post #25 of 53 Old 10-11-2012, 06:10 PM
Reiners Rigs
It's not together yet.....s106banger ran 12.7 on low boost just recently.
post #26 of 53 Old 10-11-2012, 06:49 PM
User is: baggedzq8 is offline
this is what Al sent me today when i asked about doing a vortec 4.3 under my tbi and he is referring to swapping the entire harness and stuff into my 1st gen
The Smartest thing to do is get a 2000 S10 4.3 with the
sequential fuel injection, The wiring harness is not a big thing
and the Wynjammer comes with a programmed PCM .
The later engines gives you 140-145 rear wheel hp The wynjammer
will take the stock engine to 220-230 Rear wheel Horsepower
by adding my 36lb fuel system which will take you to 275-285 rear -
wheel horsepower by adding cam etc. your over 300 hp.
post #27 of 53 Old 10-11-2012, 07:01 PM
i need a paint job
s106banger's Avatar
ive tried it, you wont hit 300 rwhp... close, but not 300.
it just wont push enough air...
10.93@122
post #28 of 53 Old 10-11-2012, 07:27 PM
yeah i thought that was kinda hi...i figured real world it could reach his figures at the crank, not the wheels...but still 300 at the crank isn't bad for a 4.3, thats comparable to 400 at the crank on vortec 350 from a 96-00 silverado ...which is pretty stout (i know its not apples to apples comparison, but I'm not gonna discuss what figures you can get with the millions of combinations of heads/cams, etc you can do to a 350)
post #29 of 53 Old 10-11-2012, 07:33 PM
i need a paint job
s106banger's Avatar
put best, it was fun and reliable.
a 400 horse 4.3 is way more fun though, it pisses people off. lol.
10.93@122
post #30 of 53 Old 10-11-2012, 08:47 PM
Reiners Rigs
Haha I agree! They'll swear its a V8 lol
post #31 of 53 Old 10-12-2012, 04:40 PM Thread Starter
I guess Ill just try to get the most power from the Wynjammer as I possibly can for beating all these intake/exhaust mustangs around, and add a little nitrous for the ls1's around town.
98s104wd is offline
post #32 of 53 Old 10-18-2012, 05:59 PM Thread Starter
If I decided to ditch the sc in favor of a turbo setup, could I use the stock intake manifold and Al's 36lb injectors, or would I need a marine intake setup?
98s104wd is offline
post #33 of 53 Old 10-18-2012, 06:34 PM
HopnDude's Avatar
Not 100% on this, but if you flip your manifolds around, facing forward/flip flop sides, you can have a cross pipe made w/ T3/T4 flange setup. Simple enough, but if I get a bit further involved with my setup is why the aftermarket shortly headers/turbo setup.
You can use that one. But remember, the intake is plastic! You'll max the injectors and the intakes abuse point at roughly the same level.
Might wanna double check on the flip flop of the manifolds, ask around and see if anyone else has done this.
HopnDude is offline
post #34 of 53 Old 10-18-2012, 11:32 PM
Reiners Rigs
The intake will be fine. There are guys running the plastic plenums on the Ls series at 15+ lbs. Only limiting factor is the injectors. If you wanted to go cheap you could do meth injection and AL's 36lb injectors. As for the exhaust you can try and find a set of syty manifolds and crossover, or even go remote mount.
post #35 of 53 Old 10-20-2012, 02:00 AM
i need a paint job
s106banger's Avatar
meyers blew up his plastic intake once on his truck. he was running 2 extra injectors in the cold side pipes leading up to the tb.
10.93@122
post #36 of 53 Old 10-20-2012, 04:26 AM
HopnDude's Avatar
The LSX intakes are different than the 4.3 intakes.
Either way, a sticky valve, on a boosted application. I don't care how nice of an intake, that mug's gonna explode like a virgin on his wedding night! Somethings gotta give!
HopnDude is offline
post #37 of 53 Old 10-22-2012, 06:42 AM
Reiners Rigs
I'm not saying push the intake to high pressure levels. 10lbs would be about max. Since jammers go to 8lbs and I've yet to see or hear of anyone grenading the plastic plenum. That's just my .02
post #38 of 53 Old 10-22-2012, 11:04 AM
HopnDude's Avatar
True. But the stock plenum. Your stuck with 36# hr injectors at best. Either the plastic intake or the injectors would thus be the limiting factor. Time to move on! Bigger/better isn't far away!
HopnDude is offline
post #39 of 53 Old 10-22-2012, 01:45 PM
Reiners Rigs
Dont get me wrong now. I'm not saying the factory intake is good. Bc it definately is not. I'm only saying you make it work to a point. But at that time you might as well go marine or 2114 swap.
post #40 of 53 Old 10-22-2012, 01:53 PM
Proud Canadian
Lutz's Avatar
User is: Lutz is offline
I dont understand why yall are spending so much cash on getting your 4.3 to 300hp and shit. Do an engine swap for less than these TT setups and your at ~300hp right out of the gate before you even begin building it up.
'03 S10 Xtreme Build
4.3L Automatic; Bagged on 2500's; Turbo 5.3/4L60e in the works..
Lutz is offline
post #41 of 53 Old 10-22-2012, 02:09 PM
i need a paint job
s106banger's Avatar
engine swaps still arent cheap man...
hell lsx log tube swap headers run $700.
10.93@122
post #42 of 53 Old 10-22-2012, 02:38 PM
Proud Canadian
Lutz's Avatar
theyre cheap in comparison to some of the money these guys are spending on heir 4.3's that will never beat one with a swapped engine..
Lutz is offline
post #43 of 53 Old 10-22-2012, 02:40 PM
Reiners Rigs
Overall Cost is relatively the same either way. It cost to go fast, no matter if you build a 4.3, 350, or a LSX.
post #44 of 53 Old 10-22-2012, 03:11 PM
HopnDude's Avatar
LuLz! A low rider guy trying to school us.
Let me grab a chair Yoda, preach away!
HopnDude is offline
post #45 of 53 Old 10-22-2012, 03:12 PM
HopnDude's Avatar
Marine intake isn't bad. If it didn't weigh damn near 70#'s, it'd be better!
HopnDude is offline
post #46 of 53 Old 10-22-2012, 07:51 PM
Reiners Rigs
Ya I hear ya on that. I would've got one a long time ago if it wasn't so heavy.
post #47 of 53 Old 10-22-2012, 08:23 PM
i need a paint job
s106banger's Avatar
yea..
my truck hasnt ran anywhere near what lsx trucks run.
10.93@122
post #48 of 53 Old 10-22-2012, 09:55 PM
HopnDude's Avatar
Save your $ and order a custom aluminum one, probably best imo.
HopnDude is offline
post #49 of 53 Old 10-22-2012, 10:51 PM
Reiners Rigs
Yea if I do turbo with the 4.3 ill go with the 2114 at least. Or even save up for one of David's ram jet intakes cut down for the 4.3
post #50 of 53 Old 10-23-2012, 12:20 AM
Proud Canadian
Lutz's Avatar
shit, didnt realize that if i know a fair amount about one thing it meant i know nothing about anything else. but whatever, not my money being tossed.
Lutz is offline
