I finally got blown
Vortech supercharger pulley change
I am going from a 3.12" pulley to a 2.62" pulley does anyone know how much i need to shorten the belt? I contacted vortech and they never got back to me. I guess i have to go to a parts store and use trial and error till i get the correct one. Thanks for any help
blown snowplow
Re: Vortech supercharger pulley change
based on the diameters of each you're going from a pulley circumference of 9.82" to 8.25" so you're dropping 1.57" - I'd guess if your belt wraps about 1/2 of the pulley you'll need to get one that's just over 3/4" shorter.
I think that make sense but it did take me about 5 belts before I found the right size for mine so take it for what it's worth! |
I call her: NIGHTMARE
when i do a pulley change, i just go to the parts store and try belts, then write the number under the hood
I finally got blown
I finally got blown
how much boost will you gain going from the stock 3.12 to the 2.62 I am wanting to do the same thing
I finally got blown
i found some where stating that a stock vortech unit is putting out about 3psi at 2500 rpm and about 8-9psi around 5500rpm, so it all depends on truck and rpms etc there is no answer set in stone on how much you will gain but since your overdriving the supercharger it will be a gain regardless. |
make sure you dont overspin it, vortech has a calculator on their site.
I finally got blown
it tells you how fast each trim can spin
I finally got blown
i had to go with a 1" shorter belt i went from 6k1020 to a 6k1010
get a gator back, it helps with smaller pulleys
I finally got blown
oh they stretch alright
I finally got blown
yeah but not as bad as the cheap ones
how much boost were you making with the stock pulley I just got my gauges all installed and I am hitting 11psi at 5500rpm far as I know all stock vortech kit little more than I was thinking it would have
i don't like the gator back belts.
I finally got blown
actually i never checked but it was supposed to be a 8-9psi kit when i get my gauge i'll check i kept the belt and pulley of corse.--but it may be awhile before i report anything
I just installed a 2.62 pulley on mine and its a big difference in power but it is to much I think for the stock fuel supply at about 11 to 12psi it falls on its face big time acts like no fuel so I put the stock pulley back on till I can up grade the fuel system
blown snowplow
blacksharpie, are you running an S/C or turbo yet? there's no way you can be maxing out your fuel system with just the mods in your sig - you're probably pushing less than 180 rwhp. Even without an FMU you can pull 220 rwhp from a S/C'd truck
Also even my W4M tune didnt command 12.8 more like 13.2 so I am asking for more than any stock tune, also AFR was meashured via WB. And yea im aware that you cant really go over 100% as they go static but one log even has a few frames @ 103%...so yea.....like i said I was SHOCKED. |
#24 |
Link to a pic of the log showing a WOT run:
http://s198.photobucket.com/albums/a...ent=102inj.jpg Tune type = Open Loop Speed Densety AFR commanded = 12.72 AFR Actual = 13.39 INJ Duty cycle = 102% If you look at all the parameters im logging you can see that the injectors go static and still cant attain the commanded afr. Hope im not coming off like a jack ass but I couldn't really believe it myself. |
#25 |
blown snowplow
Sorry, I didn't mean to come off like an ass either, I just found it hard to believe given the power that can be pushed out of the stock injectors. It makes it hard to believe that some guys can put down 250+ rwhp on just an FMU and a fuel pump!
#26 |
