Volvo turbo on s10
was jus wondering if anybody had an idea of what turbo off a turbo car would fit a 95 sonoma 4.3l vortec becuse i heard if you make all your own piping and everything a turbo off a volvo 240 would work and dosnt need a intercooler? any suggestions on what would work would be great becuse cash is low
Megabyte
Re: Volvo turbo on s10
A low pressure turbo?
is gettin there...
me and my fried are toying around with the idea for his beater ranger- his teacher was talking to him about it (tech school) and said hes done it and its nice because you dont have to do much internally besides heavier springs because you aren't running that much pressure
Two tones of terror
Im big into building high performance volvo's actually. If you want a good turbo from a volvo I would reccomend the mitsu td04 15g from the 850 turbos or the more common .42/63 or .42/48 t3 garrett. The t3's are efficient up to about 15 psi with an intercooler until you swap the compressor out for a t4. the 15g's have fast spool and are efficient to about 20 psi with an intercooler. they have a raised lip on the turbine flange that you will need to get milled flat and they both share a t3 style flange. Take your pick
Negative 10
i put a volvo turbo on my 65 bug. got it from the junkyard for 30 bucks
paint color? ... Mud =D
the only reason the 240 turbo didn't need an intercooler is it only ran about 4 pounds of boost at maximum, pretty much anything more than that will need at least a small intercooler or your intake temperatures will skyrocket
Two tones of terror
IOWNOMA95... Your turbo doesn't need to come from any specific car... you just need the right size. I wouldn't go bigger than a .60 a/r turbine side becuase these engines don't rev enough to spool it. I'd go with a .48a/r or .53a/r for your turbine. And if you want low boost, big power, look for a t3/t4 style turbo. small .48a/r T3 turbine will spool quick, and a larger t4 sized (.63-.70a/r) compressor will net you the most power per psi. |
then that's most likely a 6 lb wastegate spring.
all gate springs are slightly off. |
