Turbocharging my 4.3 Camaro - S-10 Forum
post #1 of 25 Old 08-09-2010, 06:22 PM Thread Starter
User is: boostedcamaro is offline
Hello everyone, I'm new to the whole turbo thing and I was wondering if you guys could help me out a little. I have an 89 Camaro that we just dropped an older(89ish) 4.3 motor from a 1500 in. I want to put a turbo on it.
I'm not looking to spend a whole lot so I've been looking on eBay and found this kit: http://cgi.ebay.com/ebaymotors/GMC-S...#ht_5011wt_939
Is that a decent setup? ^ im prolly gonna need to buy more pipes? Lemme know what you used and where you got it
Also, where to start? I know fueling is a big issue with turbocharging. What else will be needed? New intake? I've heard of the marine intakes--whats so great about those? Injectors?...etc. as I said before, I'm new to this.
All the help would be greatly appreciated!
Thanks!
post #2 of 25 Old 08-09-2010, 11:48 PM
User is: Geoff is offline
Re: Turbocharging my 4.3 Camaro
That kit does not include the manifolds you will need. Also with the marine intake manifold you can fix all the fueling issues by converting to a true MPFI set up and allows you to upgrade fuel injectors.
Geoff is offline
post #3 of 25 Old 08-10-2010, 11:31 AM Thread Starter
I was thinking I would turn the stock manifolds around so they come out the font. Wouldn't that work?
post #4 of 25 Old 08-10-2010, 11:47 AM
I think that you can do that, I believe that someone on here did do that, I did a rear mount so I don't have much info on which exhaust manifolds will work, but I think someone in this section did just flip the stock manifolds and made them work.
Geoff is offline
post #5 of 25 Old 08-10-2010, 02:46 PM Thread Starter
Ok I'll look into it, thanks. What exactly is the rear mount? I haven't looked into those
post #6 of 25 Old 08-10-2010, 04:11 PM
Well I just mounted the turbo underneath the truck, mine is mounted right up under the bed in front of the right rear tire. Look at my thread as well as parish's and spestis.
Geoff is offline
post #7 of 25 Old 08-10-2010, 10:09 PM Thread Starter
Alright... So the only difference is where it is mounted?
post #8 of 25 Old 08-10-2010, 10:33 PM
Pretty much, oil system might be a little different since the return won't be gravity return you will need an oil scavenge pump to put the oil back. Do some research on STS kits, they make rear mount turbo kits for corvettes, gto's, fullsize trucks, camaros, etc. Go to ststurbo.com and read up on the rear mount idea. I love my rearmount setup
Geoff is offline
post #9 of 25 Old 08-10-2010, 10:55 PM
Dig Or Die=I Die
12sws27's Avatar
User is: 12sws27 is offline
If you have a non vortec engine then the sy/ty stuff will bolt right up, intake and all. What fuel system is on your 4.3 right now? Do you know if you're running the same PCM as the 92 sy/ty?
Here's a link to a guy selling a Typhoon turbo set up. http://www.s10planet.com/forum/showthread.php?t=24680
1998 GMC Jimmy, 2dr/2wd, 4.3L auto: Wynjammer S/C @8psi, Accel 300+ ign box, Taylor 8mm wires, CFM-Tech tb blade, Trans-Go shift kit w/vette servo, cat delete, Hooker Maxflow muffler, Zexel Torsen LSD, Marine intake, 42lb/hr injectors, aeromotive stealth 340 in-tank pump, racetronix fuel pump wiring harness, AEM UEGO W/B A/F gauge, LS1 E-Fans, self tuned w/HPTuners, best 1/8th mile E.T. so far: 2.26 60' 9.55@73mph <<<6psi.
12sws27 is offline
post #10 of 25 Old 08-11-2010, 02:06 AM Thread Starter
Geoff- Will do. Thanks for your information!
12sws27- Yeah it's the non vortec engine so that might be a good route to take. The stock fuel system is on it now--not sure what that is. and I have no clue about that last part haha but im sure I can look it up. Thanks for the link, I'll think about buying his stuff
post #11 of 25 Old 08-11-2010, 09:16 PM
Dig Or Die=I Die
12sws27's Avatar
Seems there are sy/ty guys selling their exhaust manifolds quite often. So it won't be the last time a set pops up.
You really need to consider how you're going to fuel it. IDK how well TBI (if that's what you have) will provide the fuel needed for boost.
12sws27 is offline
post #12 of 25 Old 08-11-2010, 09:48 PM
WICKED 6 RACING
disturbing V6's Avatar
User is: disturbing V6 is offline
The S-trim when it was out for the 4.3L gave you a small spacer with 2 injectors mounted in it to provide the extra fuel. Or go to a Holley setup were its easier to get bigger injector sizes to compensate.
1988 S-10. Built for all out drag racing. 4.3L based 309 nitrous fed power house. Holley Dominator EFI with large amounts of dry nitrous
1.46 60ft
6.4at 112 1/8mile
10.02 at 136 1/4 mile Best MPH 136
1992 S-10 silver Sunday grocery getter.
2000 Z-R2 DD
Complete custom 309 V6 with truck build
post #13 of 25 Old 08-12-2010, 11:36 PM Thread Starter
I was thinking maybe get a throttle body from a 5.7 or something. Would that provide enough fuel?
post #14 of 25 Old 08-15-2010, 09:00 PM Thread Starter
So I've been doing some research and I haven't seen any TBI turbo setups. Is it even possible?
post #15 of 25 Old 08-16-2010, 12:46 AM
WICKED 6 RACING
You'll have to use parts for a blower. Its gonna be a custom kit.
1.46 60ft
6.4at 112 1/8mile
2000 Z-R2 DD
post #16 of 25 Old 08-16-2010, 04:49 PM
minimum wagn' it to glory
DCsdime16's Avatar
User is: DCsdime16 is offline
the problem with the TBI being boosted if that s is harder t tune, becausse you go from using one injector per cylinder to two injectors for all 6 or all 8. So the injectors hve to be gigantic.
post #17 of 25 Old 08-16-2010, 04:57 PM
*Independent*
leadsled2020's Avatar
User is: leadsled2020 is offline
have a set of syclone exhaust manifolds that I could sell to you
shoot me a pm if you are interested
2008 Chevy Colorado ext cab - Work truck
74 LUV -project
post #18 of 25 Old 08-16-2010, 07:20 PM
Dig Or Die=I Die
12sws27's Avatar
If he don't want those I might know some one who does.
PM this guy, http://www.s10planet.com/forum/member.php?u=4567
I'll pm him a head of time to let him know. I'll link him to your post too. I know he was looking to buy a set. Maybe he is still interested.
12sws27 is offline
post #19 of 25 Old 08-25-2010, 06:10 PM
I didn't build it for you
Dogsofjune's Avatar
User is: Dogsofjune is offline
A turbo on a 4.3 is fuelish.... I has it!!
Doesn't play well with the ignorant.
New project
My 2003 Turbo 4.3l SyTy wannabe Build
post #20 of 25 Old 08-31-2010, 12:32 AM
*Independent*
im not a member over there... give him my email ( leadsled2020@yahoo.com )
and have him drop me a line
74 LUV -project
post #21 of 25 Old 08-31-2010, 07:03 PM
Dogsofjune's Avatar
Actually there are a few members over there lookin for SyTy manifolds.
New project
post #22 of 25 Old 09-07-2010, 10:11 PM
*Independent*
do you know any of them? if so have them drop me a line.... because I want to get rid of these
74 LUV -project
post #23 of 25 Old 09-08-2010, 07:14 AM
2000extemeturbo's Avatar
User is: 2000extemeturbo is offline
I'm not looking to spend a whole lot so I've been looking on eBay and found this kit: http://cgi.ebay.com/ebaymotors/GMC-Syclone-T3T4-TurboCharger-Turbo-Kit-_W0QQcmdZViewItemQQitemZ260516903814QQptZMotorsQ5f CarQ5fTruckQ5fPartsQ5fAccessories#ht_5011wt_939
Thanks!
Being new to turbos, I'd suggest buying a kit specifically designed for the 4.3
That first link posted for the syclone stuff might be your best bet. It may not be completely bolt on, but it wont need to be completly fabbed and pieced together.
I'd say with that kit all you'd need is a fuel pump,intercooler and piping, computer and wire harness, and you'd be pretty much good to go.
post #24 of 25 Old 09-08-2010, 10:35 PM
Dogsofjune's Avatar
I do actually, I mentioned it, if they want to come here maybe they will contact you.
New project
post #25 of 25 Old 09-21-2010, 10:57 PM
beatinPearls's Avatar
User is: beatinPearls is offline
I do know that the 454 TBI has larger injectors, I cant remember how big but they are larger naturally.
