turbo v8, with carb - S-10 Forum
post #1 of 20 Old 01-09-2009, 07:20 PM Thread Starter
yourname's Avatar
User is: yourname is offline
turbo v8, with carb
well as the title says, pondering around puttin a turbo on my noma. right now has a 350 4bolt main (1982 i think), stock pistons and rods but new rings and all new bearings, stock heads, mild lunati cam, summit air gap intake, holley 750 double pumper with mechanical secondaries, holley electric fuel pump, and a built turbo 350 tranny. Im pretty new to the whole turbo thing, but have read up and searched. The biggest thing im unsure of is what to do with the carb??
Now i recently got a turbo header that came off a monza with a 305 in it, the boost tubes(non intercooled) and exhaust pipes,and the bonnet thing that bolts to the carb. have access to the turbo that it came with, unsure of what model etc.. now i got all this stuff for helping do a head gasket on a 305.
I can post up some pics of the header and the other stuff i got later. im not lookin for any crazy numbers or rediculous boost or anything, just some more power and make people look when i pop the hood.
So is it feasable to do boost a carbed setup without crazy amounts of time and mainly money? im willing to spend time and money but i still need to finish other projects on the truck. Or am i just better off sellin the stuff i got since it was basically free? thanks for looking
94 sonoma aka pinky- 5.3 swap. Fully bagged Winter plans bag on bar 4 link and fully shaved/new paint
08 silverado CC 4x4 murdered out daily
yourname is offline
post #2 of 20 Old 01-10-2009, 02:58 PM
I turn.
rentedmule's Avatar
User is: rentedmule is offline
Re: turbo v8, with carb
I think you'll need a turbo specific carb so that it meters fuel properly without the normal vacuum signals. I'm not sure if you can modify a standard carb for boost. You'll also need a carb enclosure. For a given engine, carb setups can usually handle more boost than EFI.
Auto-X mule: EC 2wd 4.3 auto, XTREME80 tune, bolt ons, UBM UCAs, Spohn LCAs, tall BJs, QA1 coilovers and shocks, Torsen LSD, C5 brakes, race seats, Toyo R888's.
Daily driver: '95 Firebird Formula Ram Air, LT1/T56
post #3 of 20 Old 01-10-2009, 03:04 PM
The Blown Blazer's Avatar
User is: The Blown Blazer is offline
Theres 2 ways to do it, blow through or carb enclosure.
Blow through involves modifying the carb to work with the bonnet you have. Basically, you modify a carb or buy a modified one then add a rising rate fuel pressure regulator that connects to the boost/vac signal on the intake. As the boost comes on, the regulator ups the fuel pressure 1psi per 1psi of boost. Fairly easy setup, harder to tune though.
A carb enclosure is a very easy and simple way to do it. Basically, you just make or buy (Vortech makes one!) a enclosure that completely seals off the carb, linkage, and fuel lines. Then the boost is fed into the box, so the whole carb inside and out is pressurized. You still need the rising rate fuel regulator, but many times no changing in jetting is needed. It is easy to tune, and works well with low (less than 12psi) of boost.
Both with require alot of money, and the carb enclosure is a pretty expensive piece. Personally, I'd stick with the enclosure because it's easier to tune and safer. A friend of mine boosted his RX1 snowmobile by doing a 4 carb enclosure and adding a rising rate regulator. It boosts 15 lbs and makes over 300hp, and he didnt even have to change the jetting!!
2000 black S10 Xreme auto v6 - stock on 20's "SLO S10"
2000 white S10 Xtreme auto v8 - unstock "FST S10"
post #4 of 20 Old 01-10-2009, 03:46 PM
Hmm.. well now..
Gearstix's Avatar
User is: Gearstix is offline
Send a message via AIM to Gearstix Send a message via MSN to Gearstix Send a message via Yahoo to Gearstix
Wow! I was toying with turbocharging my Rotax 600 2 stroke, not sure how to lubricate the turbo, separate oil tank?
I think if I turbo a V8 or whatever in my truck, I'll be using the carb enclosure thingy.
Theres another way to do it..
http://jobyteknik.homeip.net/fredrik...turbo_systems/
That company went belly up in the 80s... was meant to fit under stock hoods as it doesn't raise the carb.
1996 Chevrolet S10 LS 2.2/Auto... Soon to have a 305/700R4
'94 Sonoma. < Project Thread... Now with tree damage... Now a parts truck.
'05 Blazer 2DR 4x4 < The 'new' daily
(j-body.org)
Originally Posted by OHV notec
Might as well point out that you could spend $10k modifying a Briggs & Stratton-powered lawn mower, or a dining room table.
Gearstix is offline
post #5 of 20 Old 01-10-2009, 10:17 PM Thread Starter
yourname's Avatar
ok thanks for the info.. ill check out that regulator and the carb enclosure.
yourname is offline
post #6 of 20 Old 01-11-2009, 11:17 PM Thread Starter
yourname's Avatar
might be a dumb question, but why are the carb enclosures so rediculously expensive? i can see a couple hundred bucks but 600-850??? for that price i might attempt to make my own. i have access to a tig welder so i might just fab up something out of aluminum or stainless when the time rolls around.
yourname is offline
post #7 of 20 Old 01-12-2009, 12:29 AM
Probably because its a niche piece and they don't make a WHOLE lot of them. Alot of dudes make a simple aluminum box, with a detachable screwed on top.
post #8 of 20 Old 01-12-2009, 06:56 PM Thread Starter
yourname's Avatar
thats what im thinking about, just everything has to be sealed of and pressurized correct? seems simple enough to make something
yourname is offline
post #9 of 20 Old 01-12-2009, 08:26 PM
Hmm.. well now..
Gearstix's Avatar
Yeah the Vortech carb boxes are like $600-$800...
I think if all else fails, I will just use a Barry Grant blowthrough carb, the 650 is around $550-$600? I'd be fine with paying that.. unless I can figure out the carb box.. It'd be simple enough, just make a box to fit the carb around the carb, and make it bolt to the inbetween the intake and the carb.. but then you have the problem of fuel lines and throttle cables...
We'll see if I get a V8 first.
(j-body.org)
Gearstix is offline
post #10 of 20 Old 01-12-2009, 08:41 PM
Hmm.. well now..
Gearstix's Avatar
You can also mod a Holley into a blowthrough carb... theres a guide on the internet.. uhh lemme find it
here
http://www.hangar18fabrication.com/blowthru.html
(j-body.org)
Gearstix is offline
post #11 of 20 Old 01-12-2009, 10:51 PM Thread Starter
yourname's Avatar
thanks for that guide but i would be more interested in the box. couple of fittings for the fuel lines and a little tweaking for the throttle cable seem pretty simple to do.
yourname is offline
post #12 of 20 Old 01-12-2009, 11:57 PM
A guy on www.theturboforums.com modifies and sells blowthrough carbs for ~$300.
post #13 of 20 Old 01-13-2009, 03:08 PM
Hmm.. well now..
Gearstix's Avatar
You can use a marine cable and some O rings I think.
(j-body.org)
Gearstix is offline
post #14 of 20 Old 01-13-2009, 03:11 PM
Hmm.. well now..
Gearstix's Avatar
Paxton carb box. Looks realy simple.
more pics
this is how the linkage connected
(vintage mustang install)
I guess you'd just need fuel and throttle cable, not sure what the other fittings are for.
(pics from Mustang Monthly)
(j-body.org)
Gearstix is offline
post #15 of 20 Old 01-14-2009, 01:26 PM
User is: madmtnmikey is offline
Yeah, there's a couple different ways to skin a cat on this topic. Some of the best people to talk to though are the old VW Bug people, turbo carb settups are a dime a dozen in that community, of course many run the Webber carbs, but tuning is the same concept.
post #16 of 20 Old 01-14-2009, 06:05 PM Thread Starter
yourname's Avatar
thanks for the pics i will pursue this more when i get my income tax return.
yourname is offline
post #17 of 20 Old 01-17-2009, 08:42 PM
User is: CBR_Matt is offline
Check out ProCharger, they make blow through carb systems and may be able to help you with parts. www.procharger.com
Here is an example of their blow through system on a camaro. http://procharger.com/chevy_blue_camaro.shtml
CBR_Matt is offline
post #18 of 20 Old 04-05-2009, 10:23 AM
turbo v8 s10
v8turboblazer's Avatar
User is: v8turboblazer is offline
I have pic's of mine on here. May be help.
post #19 of 20 Old 04-05-2009, 10:30 AM
This season SUCKS.
dngrous_dime's Avatar
User is: dngrous_dime is offline
Send a message via AIM to dngrous_dime Send a message via MSN to dngrous_dime Send a message via Yahoo to dngrous_dime
Now that I know there's a turbo dime in the area, you MUST bring it to the Oaktown show.... Myself and several others demand it. lol
Brian
Originally Posted by 1fast4by View Post
Also, in case you were unaware Ass dynos never work
Originally Posted by MotorNut123 View Post
yea i graduated. My whole family is proud. High school graduation is a huge thing. At least for my family it is.
post #20 of 20 Old 04-05-2009, 10:46 AM
This season SUCKS.
http://www.s10forum.com/forum/f81/5t...2009-a-388808/
Brian
