took it to the track
Old 05-04-2008, 03:47 PM   #1
I call her: NIGHTMARE
98 SS's Avatar
98 SS is on a distinguished road
nothing spectacular, heres my best time......worst 60ft though.
RT .464
60' 2.386
330 5.823
1/8 8.669
MPH 85.86
1000 11.134
1/4 13.199
MPH 109.32
pretty sure the side carrier bearings in my new rearend are on the way out. I threw a belt and grenaded an idler pulley on that run
Old 05-04-2008, 06:23 PM   #2
s10ls's Avatar
s10ls is on a distinguished road
Re: took it to the track
good job, i would be real happy with the 109 mph trap speed. your truck is alot faster than 13.1 thats for sure
that 60ft is what i was pulling with an open rear last time i went to the track
Old 05-04-2008, 07:12 PM   #3
98 SS's Avatar
thats with the new rearend, the slicks get here this week. But i gotta check the bearings out first, or find out if its something else making the noise
109 is nice, i was trying to get 12.9 @ 110, but i started hot lapping it and getting slower. and i only had 1 belt and pulley left.
With good traction, should be mid twelves i suppose.
Old 05-04-2008, 10:12 PM   #4
S10 TIRE/WHEEL MASTER
NORCAL SS's Avatar
NORCAL SS is on a distinguished road
i was going thru some shit in my head last night and with 3.73 gears and that 275 40 17 (which i run on my tbss great tire) with the 1.0 gear ratio of 3rd on the 4l60e at 5600 rpms will be 115 mph. You will be set to go on those wheels. keep it at 1200 than just stab it 3rd yellow and you will cut 1.6s easy. Hell wiht my 2600 stall and 275 40 17 with 4.10 gears on my truck i cut 1.7s and thing is a brick.
so you know every 1/10 off 60 foot is almost 2/10s at the 1/4. 2.38 60 foot to 1.7 will be at least 1 second off your 1/4 mile time
Old 05-04-2008, 11:13 PM   #5
98 SS's Avatar
I like your math. lol
I had a blast saturday, after being in the backseat of a tbss doing donuts, i want one so bad now!
Im gonna pull the diff cover tomorrow i think and check it out.....minor setbacks!
Its be nice if i could leave off my stall and stick it
Old 05-04-2008, 11:33 PM   #6
NORCAL SS's Avatar
You have the hop shock right. My truck ran consistant 1.7s-1.8s with the mt et street and new owner cut a 1.73 wtih the 255 50 16 mt drag rads.
Trust me the 275 40 17 will work out fine. Line up do a burn out and just carry it out till you hear it hook and you will be fine.
Old 05-05-2008, 12:58 AM   #7
meyers2211's Avatar
meyers2211 is on a distinguished road
are u encouraging the hop shock or not? hey 98 ss ur running a manual?? and if so what rpms do u slip the clutch out at?
Old 05-05-2008, 01:14 AM   #8
NORCAL SS's Avatar
HOP shock yes but belltech 3 inch drop springs make the transfer of weight much better. he has a auto with a stall.
if you put belltech springs in and have the hop shock and the 275 40 17 drag rads you will cut 1.7s no prob.
Old 05-05-2008, 08:45 AM   #9
98 SS's Avatar
I dont have the hop shock anymore, not with the 8.8
Ive been thinking about getting the belltech springs and a shorter block. Right now ive got the zq8 springs and 3" blocks and caltracs
Old 05-05-2008, 09:49 AM   #10
NORCAL SS's Avatar
id ditch the caltracs get the bracket for the axle for the hop shock and weld it in. Then 3 inch belltech leafs with some summit nitro slammer shocks in rear and you will be set with the 275 40 17 dra grads.
Old 05-05-2008, 01:50 PM   #11
t6378tp's Avatar
t6378tp is on a distinguished road
that 60ft is killing you, your truck is much fast than a 13.1. I was trapping 107 when I was mid to high 12's. get that 60ft to around a 1.9 which should not be that hard and I can see you running mid 12's easy
Old 05-05-2008, 03:15 PM   #12
Gear Banger
sixspeeddemon's Avatar
sixspeeddemon is on a distinguished road
dibs on the caltracs if you get rid of them
Old 05-05-2008, 06:36 PM   #13
Will work for turbo parts
King_Ice_Flash2 is on a distinguished road
Other than ground clearance, why would you pick the hop shock over the caltracs? They keep the pinion angle much straighter.
I am definitely happy with the ride of the Belltech rear leaf springs, but I thought they were too soft for cornering. Still haven't run them at the 1/4 mile, but I don't think I have enough power yet to notice the difference.
Old 05-06-2008, 08:54 PM   #14
meyers2211's Avatar
hmm i wonder...... stock leafs with a leaf pulled out or belltech 3's
Old 05-06-2008, 10:48 PM   #15
The Blown Blazer's Avatar
The Blown Blazer is on a distinguished road
Real nice trap!
Old 05-06-2008, 11:06 PM   #16
98 SS's Avatar
rims came in today, the MT's come in tommorrow, and gonna use 275/40's up front with firestones fuzions. Still need to get spacers. once those kinks are worked out, the rearend is coming back apart along with putting a driveshaft loop in, then back to the track before the underhood teardown
Old 05-07-2008, 04:56 PM   #17
meyers2211's Avatar
hey 98ss where is ur whole setup listed
Old 05-07-2008, 05:58 PM   #18
98 SS's Avatar
i dont think i have the whole setup listed anywhere, at least not updated.
balance shaft block, .030 over, center mains are splayed 4 bolt, eagle h beam rods, speedpro coated forged 21.1cc dished pistons, 2.02/1.6 ported/gasket matched heads, 270AHR, billet timing set, 1.6 comp pro mags, hooker ceramic coated long tubes, 2114/gasket matched, msd digital 6 w/hvc2 coil, vortech y-trim, meth injection, streetfighter 2800-3200 stall converter, rebuilt trans with all the goodies and extensive valve body work, TCI's Standalone TCU transmission controller, ford 8.8 with prostreet 3.73's, truetrac and moser axles. Plus little extras, tci flexplate, tci rattler harmonic balancer, dynomax h-pipe and mufflers, nitrous and intercooler which i havnt finished, tiptronic shifting, wideband & hptuner.....etc
Old 05-07-2008, 08:50 PM   #19
98 SS's Avatar
waiting on spacers
Old 05-07-2008, 09:20 PM   #20
s10ls's Avatar
i like those rims
i wonder if they make et streets for 18's...
Old 05-07-2008, 09:29 PM   #21
I didn't build it for you
Dogsofjune's Avatar
Dogsofjune is on a distinguished road
Those look sweet. Bout time you got some new rubbers.
Hey, does Shaun work with you?
Old 05-07-2008, 09:54 PM   #22
98 SS's Avatar
yup, i gots him a job
Old 05-07-2008, 11:00 PM   #23
NORCAL SS's Avatar
Quote: Originally Posted by s10ls
i like those rims
yes 285 35 18 on 18x10s
Old 05-08-2008, 01:06 PM   #24
s10ls's Avatar
mine are only 18x8 though. i dont think those would have enough sidewall to fit on an 8 inch rim
Old 05-08-2008, 06:10 PM   #25
Wannabe Dragger
ExtCab96S_Dime's Avatar
ExtCab96S_Dime is an unknown quantity at this point
What kind of rims are these?
Old 05-08-2008, 09:55 PM   #26
98 SS's Avatar
zo6 wheels.
I found a guy in california that will make me a set of hubcentric and wheelcentric spacers for 100 bucks each.
Old 05-09-2008, 03:23 PM   #27
meyers2211's Avatar
oh wow i did a double take on those rims, hmmmmmmm well i'm not one for copying but man those look tite. hey 98ss how much boost
Old 05-09-2008, 04:50 PM   #28
shortfreerider is on a distinguished road
sexy rims and tires...
Old 05-09-2008, 06:41 PM   #29
98 SS's Avatar
18lbs when i can get the belt to stick it. Only think i was hitting 15-16lbs on that run though.
Old 05-09-2008, 06:53 PM   #30
Going to run larger brakes too?
Old 05-09-2008, 07:01 PM   #31
98 SS's Avatar
its on the list eventually. ive got 4wheels discs at least now. And the overall tire size is the same.......those rims just make everything look soooo small.
Old 05-10-2008, 09:38 AM   #32
Dogsofjune's Avatar
When you start looking for brake upgrades, let me know what you come up with. Mine needs something better than the stock crap. Especially if I intend to follow through with the next upgrade.
Old 05-10-2008, 11:41 AM   #33
I was looking at the SSBC larger front brakes. I have seen people do the Corvette front brakes on S10s, but a lot of parts need to be custom made.
Old 05-14-2008, 09:20 PM   #34
98 SS's Avatar
new u joint, re balanced the driveshaft and a new tail bushing for the trans and it seems like my problems are solved.
The new wheels go on tomorrow, hope to hit the track next thursday!
