sprayin
Old 09-12-2009, 12:37 AM   #1
sprayin
i just hooked up a zex nitrous system 125 shot. When i floor it and hit the spray the motor just kinda like bogs down for about 2 sec. and then BAM!!! here we go!!! lol i should probly get a purge line so it wont bog down huh?
Old 09-12-2009, 02:20 AM   #2
you think of something
thatoneguy29's Avatar
Re: sprayin
yes you should that could cause damnaging pressure
Old 09-13-2009, 12:21 AM   #3
Re: sprayin
what you mean?
Old 09-13-2009, 12:58 AM   #4
Re: sprayin
if you dont purge your system then then there could be air in the lines and when you spray it shoots the air in your engine (not nitrous) and it could **** your engine up
Old 09-13-2009, 01:10 AM   #5
WICKED 6 RACING
disturbing V6's Avatar
Re: sprayin
Purge would be a good suggestion. Generally a bog is caused by the motor going lean and waiting for the fuel to catch up. Are you running enough fuel pressure to suffice for the amount of nitrous and can your fuel pump keep up these would be things I'd also check. Not sure what system your running so not sure what the flow should be. I need 7psi and have the reg set up at 8.5 so the fuel speed stays were it needs to be once the pressure drop from fuel free flow happens. Also does the motor bog without the nitrous and how much timing are you taking out?
Old 09-13-2009, 12:46 PM   #6
Re: sprayin
well its a dry fogger system. And to be honest i just put the nozzle in front of the mass sensor. i didn do anything to the fuel regulator or anything in that area. its just something to play around with till i get done buildin the 406.
Old 09-13-2009, 02:24 PM   #7
WICKED 6 RACING
Re: sprayin
Then more then likely you will never fix the bog. The computer just is not compensating fast enough for the nitrous. The only other thing I could suggest is see if you can turn up the fuel pressure a little bit and shot the nitrous after you are already moving and not strait off the line.
Old 09-13-2009, 10:45 PM   #8
Re: sprayin
well how would i go about adding more fuel pressure?
Old 09-14-2009, 12:44 AM   #9
WICKED 6 RACING
Re: sprayin
what year is truck
Old 09-14-2009, 01:31 AM   #10
The Blown Blazer's Avatar
Re: sprayin
Uhh I'd definitely suggest NOT running a dry setup on ANY 4.3. The fuel systems are so weak as it comes stock, you're definitely exceeding it's capabilities with the 125 dry shot.
Seriously, get a wet kit or take it off. That is, if you already haven't leaned the motor out and scattered it.
Old 09-14-2009, 01:56 PM   #11
Re: sprayin
I like it wet....
I think most will also agree
Old 09-14-2009, 02:05 PM   #12
not low, not gonna be...
Crew Cab Sonoma's Avatar
Re: sprayin
i agree that a 125 dry shot is WAY too much.
and that engine is gonna be a "short-timer" if it keeps
getting sprayed dry with that much.
but i think most stock to mildly modded 4.3"s could
safely compensate for a 40-50 dry shot through the MAF.
Old 09-14-2009, 05:02 PM   #13
Re: sprayin
its a 96. will i have to do anything to the fuel pressure on a 50-75 shot?
and if thier weak, how would u go about steppin em up?
and if i put a wet kit on her, could i come of the shradder valve/test port for the fuel/
Old 09-14-2009, 08:03 PM   #14
WICKED 6 RACING
Re: sprayin
Yes a wet kit for your year comes off the test valve. As far as bumping up stock stuff for your year not exactly sure how to help the fuel injection with out a lot of work like changing to a TPI setup through a Edelbrock intake with welded on bungs for good fuel injectors.
Old 09-14-2009, 10:36 PM   #15
Re: sprayin
alight well yall got me persuaded for a wet kit.
Old 09-19-2009, 05:10 AM   #16
What Now!!!
94s10cpi's Avatar
Re: sprayin
Quote: Originally Posted by Danny_SS
I like it wet....
I know I do..
