s10ls's new turbo/mpfi/bowtie head project
LinkBack (1) Thread Tools
Old 05-29-2008, 08:33 PM   #301
s10ls's Avatar
s10ls is on a distinguished road
Re: s10ls's new turbo/mpfi/bowtie head project
i will be selling the turbo as soon is a start the rebuild.
i havent made much progress lately, work has been busy. i start building my house in july, once i get the garage up and the truck in it, i'll start the tear down regardless of the motor not blowing up
i'm sorry man i know i promised my 2114 to you and its taking forever. i never expected this stock motor to last this long (neither did anyone else i'm sure) with 20+ psi. each day i get more eager to make a change ragardless of what shape the motor is in lol
Old 05-30-2008, 09:16 AM   #302
TurboV6
Synoma's Avatar
Synoma is on a distinguished road
Quote: Originally Posted by s10ls
i already have the perfect turbo picked out for you. quick spooling and will handle 800hp efficiently. affordable too
its the turbo i'll be running on my new setup
Sounds good. Sorry I didnt call you back last night. Got bize with the wifey . Call you later today.
Old 06-05-2008, 01:25 PM   #303
BOOSTandDESTROY is on a distinguished road
Thats awesome man. 20psi on the stock block is nuts. Just need tuning.
Old 06-15-2008, 10:54 PM   #304
s10ls's Avatar
http://memimage.cardomain.com/member...7_146_full.jpg
just testing. it seems all the pics i posted got changed to .net instead of .com so now they wont show up. do i need a mod to change this?
Old 06-16-2008, 01:03 AM   #305
Will work for turbo parts
King_Ice_Flash2 is on a distinguished road
Odd, even the ones in the sig got renamed.
No rush. I'm sure once I start tearing into the truck, it will start raining so I can't drive the bike.
Old 06-18-2008, 08:59 PM   #306
s10ls's Avatar
Quote: Originally Posted by rob8284
I try . Quick question, header bolts are 5/16" right?
hey rob, think you could cut me two T3 flanges sometime in the next couple of months?
Old 06-18-2008, 10:11 PM   #307
Blown Mod
Jess's Avatar
Jess is on a distinguished road
i fixed the one. i don't think i can fix your sig, if i could, i don't know how. why can't you ?
Old 06-18-2008, 11:14 PM   #308
s10ls's Avatar
oh i wasnt to concerned with the ones in my sig. i can change them just havent done it yet
Old 06-19-2008, 09:04 AM   #309
rob8284's Avatar
rob8284 is on a distinguished road
Give me a sketch like you did last time and I'll get 'em cut. 3/8" steel like last time?
Old 06-19-2008, 09:44 AM   #310
Two flanges? Uh oh.
Old 06-19-2008, 08:42 PM   #311
Renegade_Z's Avatar
Renegade_Z is on a distinguished road
That stealth ram looks kick a$$. You got any more pics? Im trying to figure out a way to cut a TPI intake up for my 4.3.
Old 06-22-2008, 04:04 PM   #312
s10ls's Avatar
i'll find you a sketch just like that T4 flange you cut for me. it will be a while before i need them. i've got the pass side header built and finished but havent started the driver side yet so it may be a few weeks
i have plenty of pics but they arent working right now. keep an eye on the thread they should be working soon
Old 06-23-2008, 09:15 PM   #313
s10ls's Avatar
posting this for future reference
Old 06-25-2008, 08:00 PM   #314
s10ls's Avatar
rob, another request lol
i need a spacer made to go between the upper and lower intakes on my stealth ram. the spacer will be cut to block off the two unused runners. 3/8ths material is fine but i suppose it could be 1/4. steel should work to although aluminum would be nice
think you can do it if i send you a template?
Old 06-25-2008, 11:01 PM   #315
rob8284's Avatar
I could always try. 1/4" thick is the max. I can cut on my laser out of aluminum due to it's power level. I could cut two pieced and you could possibly stack them if you need thicker then 1/4".
Make a template like you did with your headers and I'll do my best.
Old 06-26-2008, 03:21 PM   #316
s10ls's Avatar
the type of material and thickness doesnt really matter. as long as its not 2 inches thick lol. i dont need it as a spacer, just to block of the two unused ports
you can make it out of whatever you have laying around. if 3/8 steel is all you got than that will work just fine, or if you have alot of scrap 1/4 steel you can cut it out of then that will work just as well. i'll work on making a good template and i'll send it over to you.
do you happen to have a fax number?
Old 06-26-2008, 06:04 PM   #317
rob8284's Avatar
I'll probably do it out of 1/4" aluminum, we have quite a bit of scrap.
I don't, but you can fax me at my work fax if needed 410-833-0623. Just make it out to my attention.
Old 06-26-2008, 06:54 PM   #318
s10ls's Avatar
i'm pretty sure the dimensions should stay the same when i fax it. i'll include some measurements between bolt holes so you can check to make sure. i'll make the template as simple as possible, eliminating alot of curves around the edges etc. to minimize the time spent on your end, you can do the same for the outer edge of the t3 flanges, just make them straight cuts instead of curves (the exhaust hole still needs the curves lol). i can grind any excess of on my end. the spacer will be rectangular, about 10 inches long and maybe 5 inches wide
Old 06-26-2008, 11:00 PM   #319
rob8284's Avatar
It may lose some scaling over faxing, but if you include a dimension, I can "scale" it back. Do you have a scanner that will scan into PDF? That may be a better route.
Curves are no problem (the beauty of AutoCAD) and besides, I need to put a radius on corners anyways the help the laser cut. Lasers do not like stopping to make a square corner. It's takes more time and is a more complicated cutting process (sorry for the brief "laser 101" course).
Old 06-30-2008, 05:09 PM   #320
s10ls's Avatar
good to know, that will save me some grinding
you can go ahead with the t3 flanges whenever you want. i wont be able to fax the spacer template until wednesday
Old 06-30-2008, 06:30 PM   #321
rob8284's Avatar
...you can go ahead with the t3 flanges whenever you want...
What size bolt holes in the T3 flange?
Old 06-30-2008, 08:16 PM   #322
s10ls's Avatar
make them 1/4 inch holes, i'll drill them out as needed
Old 06-30-2008, 08:47 PM   #323
s10ls's Avatar
rob, can you make the exhaust hole 2.25 inches round?
Old 07-08-2008, 07:36 PM   #324
s10ls's Avatar
going with twins, new headers almost done
driver side tacked up
pass side finished
i'll wait to weld on the elbows and t3 flanges until i get the turbos and can mock them up and level them across from one another, then the headers will get wrapped
rob, i have been busy lately and havent had time to fax the template. i'll do it tomorrow morning
Old 07-08-2008, 08:34 PM   #325
Now that is looking good!
Old 07-21-2008, 10:19 AM   #326
rob8284's Avatar
Just to make sure I'm on the same page, instead of the rectangular hole you want a 2.25 dia hole in the flange?
Old 07-21-2008, 07:25 PM   #327
s10ls's Avatar
correct, but make it a 2.125 inch circular hole instead. i'll send you that fax tonight
Old 07-22-2008, 08:58 PM   #328
keith- can only hope to improve
Quote: Originally Posted by Bad94
Should look like this.
Note: intake isnt fully done in that pic.
in there any reason for welding all the way up the intake, couldnt you just run a bead across the bottom and up onto the sides?
Old 10-22-2008, 06:55 PM   #329
s10ls's Avatar
motor is most likely toast. theres a steady stream of white smoke coming out of the valve covers, smoke out of the tail pipe at idle, # 6 plug is oily, so much crank case pressure it pushed out a valve cover, and thats with a pcv setup
i'm gonna yank the motor and sell off the go fast parts. they include
fully modded mpfi 2114 w/ fuel rails and hold downs
billet 1000 cfm 4 barrel TB with progressive linkage, uses GM TPS sensor and IAC motor
the cam, which is a smaller crane cam with lots of duration that will work with stock heads, for a BS motor
stock vortec heads
syty exhaust manifolds and X over with a flange for an external wastegate welded on the x over
pt6152e turbo, awesome turbo for 450-500 hp. uses a garret gt35 comp wheel and a t350 or 52 exhaust wheel, syty specific .85 a/r t3 hot side
plastic carb hat that i have used from the beginning
i havent begun to pull the motor yet so be aware that it will be a few weeks before this stuff can be shipped
theres other stuff also, i know a few people called dibs on some of this stuff long ago. PM me with interest
Old 10-22-2008, 08:41 PM   #330
PM sent
Old 10-27-2008, 11:13 PM   #331
s10ls's Avatar
the parts will be pulled starting monday next week. i've had people tell me they are interested, but no ones has stepped up and claimed something definitely
those who have expressed interest get the first dibs. if nothing is claimed by the time the part is pulled by those people then all the parts are going to the classifieds on multiple boards/ebay.
