s10ls's new turbo/mpfi/bowtie head project
LinkBack (1) Thread Tools
Old 10-19-2007, 11:02 AM   #101
s10ls's Avatar
s10ls is on a distinguished road
Re: s10ls's new turbo/mpfi/bowtie head project
BTW big thanks to Rat who is helping me to machine these heads myself
Old 10-19-2007, 12:14 PM   #102
rat
Got Fuel Rails?
rat's Avatar
rat is on a distinguished road
You should be getting a package early next week.
Old 10-19-2007, 12:54 PM   #103
cycle252's Avatar
cycle252 is on a distinguished road
I'd feel real sick if i was fixing to cut that nice expensive manifold in two. By the way does that leave any hood clearance? Thats pretty tall, anyway good luck on the cut and keep us updated.
Old 10-19-2007, 02:10 PM   #104
rat
Got Fuel Rails?
rat's Avatar
I bet it isn't much taller than the stock intake manifold/tb/intake hat. The tb/intake hat are probably a good 8" tall.
Old 10-19-2007, 02:24 PM   #105
Zygoat is on a distinguished road
that beautiful virgin aluminum
Old 10-19-2007, 02:53 PM   #106
s10ls's Avatar
its where the TB would be right when the hood curves downwards to the grill that has me worried. i am really hoping to keep the stock hood
BTW mike (boosted thrills) says its shorter than his 2114/spacer/TB/carb hat, which is identical to mine other than the carb hat, i think mine is a little taller
Old 10-19-2007, 03:47 PM   #107
cycle252's Avatar
If you get caught between a rock and a piece of nice sheet metal you can always do this http://www.thirdgen.org/techboard/po...gle-turbo.html
Old 10-20-2007, 09:53 AM   #108
s10ls's Avatar
cool thread. i wouldnt want to weld the upper plenum to the lower manifold though. i would have the top of the lower manifold milled down as far is it could go
Old 10-20-2007, 10:13 AM   #109
Blown Mod
Jess's Avatar
Jess is on a distinguished road
my hat is real close to the hood (at least it was with the stock hood. but not with my cowl hood). the maf would have hit the hood. but i angled it down a little, so it cleared fine.
Old 10-22-2007, 03:59 PM   #110
s10ls's Avatar
someone suggested a wedge to point the TB down a little, thought that was a good idea if it came to that
on a side note i just cut 4 inches out of the middle of the manifold
pics coming shortly
Old 10-22-2007, 04:04 PM   #111
classic
Old 10-22-2007, 04:15 PM   #112
s10ls's Avatar
the first rough cuts i made with a sawzall. as you can see its still about 3/4 of an inch to long. the rest will be milled off
Old 10-22-2007, 05:37 PM   #113
cycle252's Avatar
You know what... I wouldn't have the balls to do it
Old 10-23-2007, 09:07 AM   #114
s10ls's Avatar
Rat, got your package today. i'll be working on the heads later today
Old 10-23-2007, 01:08 PM   #115
I call her: NIGHTMARE
98 SS's Avatar
98 SS is on a distinguished road
i woulda been shaking if i was gonna make that cut with a sawzall
Old 10-23-2007, 02:18 PM   #116
s10ls's Avatar
luckily i have plenty of experience with a sawzall being in the home building/remodelling business
Old 10-24-2007, 05:30 PM   #117
s10ls's Avatar
thoughts on teflon valve seals? seems like viton is the better choice, but teflon is the only thing i can get locally that fits what i machined my guides too (.530). what seals are the rest of you guys running?
also, got the HSR shortened to the proper length, looks like i'll be able to use 5 bolts on each side of the intake
Old 10-24-2007, 05:35 PM   #118
rat
Got Fuel Rails?
rat's Avatar
My teflon seals leak. Viton is the oem material now days.
Old 10-24-2007, 05:42 PM   #119
98 SS's Avatar
thats just friggin cool
Old 10-24-2007, 06:36 PM   #120
meyers2211's Avatar
meyers2211 is on a distinguished road
what are u going to do with the pair of dead intake runners? fill em in?
Old 10-24-2007, 06:51 PM   #121
s10ls's Avatar
the tops will be welded shut. i have to get a manifold gasket to see if the bottom will need to be welded also, prolly just put a plug in the injector bung
Old 10-24-2007, 07:15 PM   #122
Will work for turbo parts
King_Ice_Flash2 is on a distinguished road
That does look awsome, but wow, after seeing all of the work, I am glad I didn't buy those set of bowtie heads when I had the chance. It would have never gotten finished.
Keep up the good work! That thing sick!
Do the bolt holes now line up, or do you have to machine a Z-shape between the 2 un-used intake runs?
Old 10-24-2007, 07:21 PM   #123
that is just sexy. no way around it.
Old 10-24-2007, 07:37 PM   #124
No kidding, it just looks fast.
Old 10-24-2007, 08:08 PM   #125
Static> Bags
Bad94's Avatar
Bad94
Should look like this.
Note: intake isnt fully done in that pic.
Old 10-24-2007, 08:27 PM   #126
Blown Mod
Jess's Avatar
i think i have teflon seal, i'll check. no problems with them. but not many miles on em.
that intake is pretty cool. i should have done that, instead of the 2114. sometimes i don't think ahead enough..... 1 thing for sure. if you take it to a car show, there are going to be a LOT of people scratching their heads. 4 in, 3 out
Old 10-24-2007, 09:48 PM   #127
s10ls's Avatar
yeah jess if you could check when ever you have a valve cover of that would be great.
no Z cuts, its getting welded up soon then i can cut up the upper plenum
Old 10-24-2007, 10:11 PM   #128
98 SS's Avatar
What would be even better is if you put in and ran wires into the harness for a dummy injector instead of plugging the bungs........WTF!?!
Old 10-24-2007, 10:30 PM   #129
Blown Mod
Jess's Avatar
no need to pull a cover, i have extras = bought the V8 set. they are the kind that ya install with a socket, 7/16 iirc.
the extra injector would be funny. maybe even run an extra plug wire.
Old 10-24-2007, 10:44 PM   #130
Blown Mod
Jess's Avatar
i just went to the garage and got one. they are a white plastic with a metal band(onto the head) and metal ring (on the valve). i don't remember the brand. i will look further to see if i can find the package(friday night)
Old 10-24-2007, 10:49 PM   #131
Blown Mod
Jess's Avatar
ok, i just looked in my speed parts catalog. they are crane cams teflon seals.
Old 10-25-2007, 07:00 AM   #132
s10ls's Avatar
the crane teflon seals are what i can get locally. thanks for the info
you know my harness is wired for 8 injectors, i just never used two of them. if i can get two broke injectors or something i may do that lol
Old 10-25-2007, 06:46 PM   #133
98 SS's Avatar
"Yeah, its a v-8....the middle cylinders are smaller and siamesed, thats why there are only 6 header tubes."
wonder how many people you could get to fall for it.
