Rear mount turbo sizing - S-10 Forum
post #1 of 10 Old 06-05-2010, 12:24 AM Thread Starter
Heavy Metal Body Man
Maverick2664's Avatar
User is: Maverick2664 is offline
Send a message via AIM to Maverick2664
been playing with the idea of forced induction since i started building the truck, for a while i decided on supercharging, but its turning out to be more money than i want to spend at the moment, but not just that, i want a clean minimalist engine bay with no clutter, so supercharging is out.
so i started reading about you guys that are running rear mounted turbo(s) with success and started looking into what it would take, and i was surprised to see how affordable turbos are... and the whoosh sound is just too badass to pass up. i ran the idea by my boss and he said that it sorta defeats the purpose of a turbo, too far from the engine and the turbo doesnt work as well, thermal expansion blah blah... but i see a few of you guys with them and you seem to be really happy with them
the engine is a 383 and its a street driven truck, so i want minimal lag
so what size do i need, and should i run single or twin?
-Under Construction-
98 S-10 extended cab: stock floor body drop, TPI 383 w/ 0411 pcm conversion, T56 manual
post #2 of 10 Old 06-05-2010, 02:11 AM
User is: 1s152nv is offline
Re: Rear mount turbo sizing
Call up these guys for advise. I wouldn't buy the turbo's from STS because their turbo prices are seriously inflated.
http://www.blouchturbo.com/ and http://www.ststurbo.com/home
1s152nv is offline
post #3 of 10 Old 06-05-2010, 11:45 AM
LS1DIME's Avatar
User is: LS1DIME is offline
I can speak from experiance, My 6.0L S10 uses twin rear mount To4b's, they spool very quickly, and the engine bay space is amazing! Look at the thread in this section called "My 6.0L Twin Turbo Project" Lots of pics and info on there!!
1985 Chevy S10, GM 6.0l Block Diamond -13.77cc pistons, Eagle ESP Rods, Eagle 4340 Crank, Custom Comp Camshaft, 317 heads with ARP Studs and LS9 Head Gaskets. A 700r4 with 3200 Yank Stall, Tci Reverse Manual Valvebody, Custom Twin Rear Mount Turbo System, and Speartech Fuel Management System!!! Come On Guys LOOKING FOR TOTM!!
LS1DIME is offline
post #4 of 10 Old 06-05-2010, 02:38 PM Thread Starter
i seen your thread, its one of the trucks that makes me want to run a rear mount setup
post #5 of 10 Old 06-05-2010, 05:07 PM
LS1DIME's Avatar
Well thanks you, but try not to copy it to much!!! j/k, if ya have any questions just hit me up and I will help however i can!!! Just dont rush things, you will be glad you waited and took your time when your all finished and driving the beast!!
LS1DIME is offline
post #6 of 10 Old 06-05-2010, 06:03 PM Thread Starter
as clean as your setup is, i wouldnt copy it, i still want the option to use the bed if i have to, so ill mount it under the bed and keep it hidden... and i plan to take my time with it, my truck has been a "project" for 4 years, meticulous planning is all i seem to do lol
those sites have a lot of good info on it, ill have to email them and see what they have to say
post #7 of 10 Old 06-06-2010, 07:08 PM
User is: Geoff is offline
As for sizing I can't help you on that, but there will be lag with the rearmount but any turbo is going to have lag, nice thing about rearmount is it keeps the underhood temps way down and you pull in colder air. Only thing to look out for is where you have your air filter mounted if you plan on driving this everyday. Mine is a daily and I made the mistake of leaving it under the truck and that cost me a motor. I sucked in too much water during a bad rain storm I was driving in and it hydrolocked it and bent a rod. Then a week later it threw it.
Geoff is offline
post #8 of 10 Old 06-06-2010, 08:24 PM Thread Starter
its definitely not going to be a daily, by the time im done ill have too much time and money to be anything but a weekend warrior... and ive thought up a way to have it up away from the ground
post #9 of 10 Old 06-06-2010, 10:34 PM
LS1DIME's Avatar
Yea my setup has rendered my bed a eye candy storage unit!! But thats what I built the truck for! I took it to a large local show last weekend and boy I couldnt get to the back of it to get a water out of my cooler! The Best Mini Truck Award was nice too!!
LS1DIME is offline
post #10 of 10 Old 06-06-2010, 10:51 PM Thread Starter
so a number of sites seem to tell me that i need a pair of gt25/28 or gt30's or comparable sized turbo, they say they should be fully spooled by 2000-2500 and should easily give me the 10-12 psi i want through the entire rpm range
my only issue... is that those turbos dont use a v band style downpipe clamp, its a bolted flange of some sort, so i would have to fab a flanged pipe... but on the bright side, theyre internally wastegated, so itll save me some plumbing and space
