Project "TURBONOMA" begins
LinkBack (7) Thread Tools
Old 10-07-2004, 05:53 PM   #101
TURBOS SUCK
sy-clone's Avatar
"The eagle has landed"
Well I finally got the engine in place. I had to undo the steering shaft and remove the cross-over
pipe to get it in. Take a look and let me know what you's think. PEACE>Tony
Old 10-07-2004, 07:26 PM   #102
Akerfeldt
MINTSICK's Avatar
Re: Project "TURBONOMA" begins
Looks really nice all painted up in there, can't wait to paint everything under my hood this winter. Awesome work, get some more pics up.
Old 10-07-2004, 07:34 PM   #103
PPG Sprayin Minitrucker
PaintinDeezNuts's Avatar
Re: "The eagle has landed"
I think that it looks awsome.
I also think I have a boner!!!
J/K
Old 10-07-2004, 10:48 PM   #104
Blown Mod
Jess's Avatar
good for you man. can't wait to hear how it runs.
Old 10-07-2004, 10:57 PM   #105
Un-Blown Fake ZQ8
s10rz350's Avatar
getting down to the nitty gritty!
Looks great tony. Excited for ya!
Old 10-08-2004, 01:09 AM   #106
Black SS
97S10SS's Avatar
Looks awesome. Turbo
Old 01-18-2005, 03:03 PM   1 links from elsewhere to this Post. Click to view. #107
TURBOS SUCK
sy-clone's Avatar
Post Re: Project "TURBONOMA" update
Well guys it's been awhile since I did anything to the truck. I had to take care of some of my properties and I've had to do some traveling to the states recently. Today I got around to putting in my 3" ss cat-back exhaust system. Boy, sure looks good! Here are some pics. Tell me what you think. PEACE>Tony
Old 01-21-2005, 01:36 AM   #108
TrailBlazin'
SuperSS27's Avatar
Very Clean, that thing is a beastly s-series...
Old 01-21-2005, 11:58 AM   #109
Got spray? Got boost? (y)
hellbents10's Avatar
Gonna be nice, keep up the great work!
Old 03-09-2005, 09:43 AM   #110
TURBOS SUCK
sy-clone's Avatar
Update on the Turbonoma! The manifold is comin along too. Getting closer by the day.
PEACE>Tony
Old 03-09-2005, 10:23 AM   #111
Turbos and Naws
cyipher's Avatar
wow...thats a nice adapter plate...you make it??? Got any plans, or drawings?
Old 03-09-2005, 10:51 AM   #112
Thats a differnet approach to a adapter plate. I like it though it will sit like the stock tb. What kind of plenum volume number are we looking at there. I like to run the big 90 with boost and a higher rpm setup just for the added volume. Keep up the good work its commin along nicely.
Old 03-09-2005, 03:07 PM   #113
I'll work up some plenum numbers. I was thinking it would need as much volume as I could get.
With that adaptor the TB sits a few inches aft, and right at 1/8" lower than stock. I can make these adaptors for sale if anyone is interested. I have a complete setup like Tony's pictured that is only waiting on rail to arrive and be machined... $750 Stick on another $100 for polished and another $100 for powdercoating.
We've also found that making an LS1 TB work shouldn't be very hard. The only real advantage is a better lip to attach to with tubing. The main shaft gets swapped with the stocker, as well as the IAC, both are clocked differently. The TPS needs getto'd up a bit. One taps the locating pin hole and uses it for a screw hole. That means the TPS is held by 2 screws 90° from each other, the seal may not be able to work as good as it should. Also you'll have to be able to "set " the TPS position, the locating pin will be out in the middle of nowhere. There is a tube coming off the back (upper on an F-body) that need rotated and capped. The adaptor plate or whatever your bolting it to will need matched to the slightly larger LS1 TB.
Sam
Old 03-09-2005, 04:44 PM   #114
the ls-1 tb works great on my intake becuase of the vertical mounting on the wilson manifolds elbow.
Old 03-09-2005, 09:18 PM   #115
With the manifold plenum measuring 3.125 deep using the square bore pattern and adding the adaptor interior I got around 55 cubic inches. Still not much...
Sam
Old 03-09-2005, 11:38 PM   #116
Blown Mod
Jess's Avatar
looks real good Tony !
Old 03-12-2005, 04:17 AM   #117
Turbos and Naws
cyipher's Avatar
Sam
How Much for the adapter??? how far appart are your rails...any issue with the linkage hitting the rail??
Old 04-05-2005, 09:28 PM   #118
TURBOS SUCK
sy-clone's Avatar
Here's another pic of the Edelbrock #2114 intake. PEACE>Tony
Old 04-06-2005, 02:19 AM   #119
Quote: Originally Posted by cyipher
How Much for the adapter??? how far apart are your rails...any issue with the linkage hitting the rail??
Hey man, I'm really sorry I didn't see this. If you'd like I can e-mail a pic straight on with the manifold showing just where the linkage ends up. I tapped the extra tab, or spud(cruise) coming off the TB arm into to where it touched the main(throttle cable) part. This leaves almost 1/4" between the spud and the rail. I didn't have cruise or whatever this is used for on my truck. I can't see anything needing much more than an 1/8"... I did have to offset the TB to the driver side of the manifold to get this clearance though. The spacer is CNC'd to match the TB hole to the 4 barrel flange with a simple straight surface transition (ruled if your into CAD/CAM). I can send a pic of this also.
7.4" between the inside surfaces of the rails. At the smallest measurement that is.
I'd like $200 for the adapter and rails.
No standoffs unless you can supply info as to exactly what you want. I've been using .75" long, .4375" Dia, with a .25" thru hole. I don't want to make parts that don't do anyone any good.
$650 for the manifold (with bungs welded), rails, adapter, standoffs, bolts and gaskets to attach the TB to spacer and spacer to manifold, and fittings to adapt the stock fuel lines to -06AN.
No other fittings, injectors, regulator, etc. for this price.
The TB to spacer gasket is back ordered. It was to ship on the 1st it has been pushed back to the 16th.
Again sorry I missed this post.
.com
Sam Steeb
edited to remove email addy. Jess
Old 04-06-2005, 02:22 AM   #120
I see you got the pics... Do you like the Y-block?
Sam
Old 04-06-2005, 02:53 AM   #121
Un-Blown Fake ZQ8
s10rz350's Avatar
wow nice work sam. Looks like it could be stock.
looks great. Good luck with it Tony.
Old 04-06-2005, 10:21 AM   #122
Turbos and Naws
cyipher's Avatar
E-mail Sent
Old 04-06-2005, 04:17 PM   #123
TURBOS SUCK
sy-clone's Avatar
I see you got the pics... Do you like the Y-block?Sam
Sam all I can say is that "you da man!" People he knows his chit. I think his prices
are more than fare for the workmanship he delivers. PEACE>Tony
Old 04-10-2005, 05:37 PM   5 links from elsewhere to this Post. Click to view. #124
TURBOS SUCK
sy-clone's Avatar
Edelbrock#2114 intake
It's comin along nicely.PEACE>Tony
Old 04-14-2005, 06:57 PM   #125
TURBOS SUCK
sy-clone's Avatar
Here's some more progress on the "Turbonoma". I installed the intercooler. PEACE>Tony
Old 04-14-2005, 09:37 PM   #126
so whats left to the project till it is completed and also how much boost will ur new setup handle
Old 04-15-2005, 12:49 AM   #127
TURBOS SUCK
sy-clone's Avatar
I have a few things I have to wire up and it should be ready to fire up. I plan on running 8lbs.
of boost. Not much sense running anymore on the street. The major issue is getting it tuned
right. I'm gonna use the TunerCat program. PEACE>Tony
Old 04-15-2005, 11:16 AM   #128
TrailBlazin'
SuperSS27's Avatar
Nice Crotch Shot in the liscnse plate...
Old 04-15-2005, 09:13 PM   #129
TURBOS SUCK
sy-clone's Avatar
You are one eagle eyed mo fo bro...ha ha ha. PEACE>Tony
Old 05-20-2005, 10:35 PM   #130
TURBOS SUCK
sy-clone's Avatar
Here's what the install of the intercooler tubing looks like. Had to buy a 3 1/2" hole saw to
butcher my inner fender wells to fit the pipes thru. One less thing on my "to do" list.
PEACE>Tony
Old 05-21-2005, 11:21 AM   #131
Blown Mod
Jess's Avatar
Tony
that manifold looks pretty slick. makes me want one. well, i do want one, but don't have the money for it right now. your going to have a good looking engine bay.
Old 05-21-2005, 12:43 PM   #132
I LOVE S10FORUM!!!!!!
Revolution's Avatar
Hey Tony before you fire that monster up spend a little extra and get a blow off valve for it. We found out with that " choke valve " that the mach kit uses it leaks well over 2 psi and that really helps out . A very significant diffrence.
Old 05-21-2005, 06:40 PM   #133
TURBOS SUCK
sy-clone's Avatar
Quote: Originally Posted by Revolution
Hey Tony before you fire that monster up spend a little extra and get a blow off valve for it. We found out with that " choke valve " that the mach kit uses it leaks well over 2 psi and that really helps out . A very significant difference.
Just so happens that I do have a tial bov sitting around and a turbonetics evolution wastegate
that I'm planning to use with my other turbo(62-1 T4) and of course the intake Sam built for me.PEACE>Tony
Old 05-21-2005, 08:29 PM   #134
TURBOS SUCK
sy-clone's Avatar
This is what the engine compartment looks like now . Won't be too long now before I put" fire in the hole". PEACE>Tony
Old 05-22-2005, 05:07 AM   #135
Turbos and Naws
cyipher's Avatar
Damn looks stock...Good Job
Old 05-22-2005, 08:34 PM   #136
TURBOS SUCK
sy-clone's Avatar
That's exactly what I'm looking for. I want it to look as stock as possible. I want to take people by surprise and blow their doors off. PEACE>Tony
Old 05-23-2005, 01:21 AM   #137
looks good tony, that plastic bonnet will pop off though so keep that in mind, i had to use tie wire to time mine down. till i made something for now that holds a little bit better.
Old 05-23-2005, 07:27 PM   #138
TURBOS SUCK
sy-clone's Avatar
Well I put the stock wheels on today to get a look at how much ground clearance the scoop
on the intercooler has. I measured it and it's only 4 3/4" off the ground. Guess that leaves out
doing wheelies for now...he he he. PEACE>Tony
Old 05-23-2005, 08:13 PM   #139
Lookin good buddy keep up the good work.
TJ
Old 05-24-2005, 01:12 AM   #140
One Bad Dude
badnoma's Avatar
did you make that scoop? Do you have any more close up pics?
Old 05-24-2005, 01:47 AM   #141
TURBOS SUCK
sy-clone's Avatar
The scoop came with the turbo kit. It's powder coated silver. There is another pic of it in an
earlier post in this thread. PEACE>Tony
Old 05-24-2005, 11:39 AM   #142
TrailBlazin'
SuperSS27's Avatar
WOW, how much have you dropped into this all together?
Old 05-25-2005, 08:16 AM   #143
Poor-ass college student
Biggun's Avatar
Where did you get that piece for the turbo intake side??
Old 05-25-2005, 02:44 PM   #144
One Bad Dude
badnoma's Avatar
Also what did you use on the edges of the holes in your inner fenders? My intercooler tubing sometimes hits the edge and rattles. REALLY annoying.
Old 05-25-2005, 03:06 PM   #145
bdydrpt92's Avatar
looks like he used some 1/4" wire loom, works great for big holes. Truck looks sick man keep up the good work.
Old 05-25-2005, 05:04 PM   #146
I Am Canadian!
j_gor78's Avatar
Looks like door molding...i used some of that on my cold air intake...it's got glue on the inside it works really well you can get it at any local parts store.
Old 05-27-2005, 07:27 PM   #147
TURBOS SUCK
sy-clone's Avatar
It's my hobby so I don't keep track of the expenses. PEACE>Tony
Old 05-27-2005, 07:29 PM   #148
TURBOS SUCK
sy-clone's Avatar
It came with the turbo kit. PEACE>Tony
Old 05-27-2005, 07:32 PM   #149
TURBOS SUCK
sy-clone's Avatar
That's exactly right. I think I may exchange it for a silicone hose though. PEACE>Tony
Old 06-15-2005, 09:38 AM   1 links from elsewhere to this Post. Click to view. #150
TURBOS SUCK
sy-clone's Avatar
Got these yesterday to give the engine a facelift.PEACE>Tony
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f11/project-turbonoma-begins-110311/
Posted By For Type Date
S-Series.Org :: View topic - Project Post #124 Refback 10-07-2007 05:15 PM
S-Series.Org :: View topic - Project Post #124 Refback 09-08-2007 04:53 PM
S-Series.Org :: View topic - Project Post #124 Refback 08-31-2007 10:45 PM
S-Series.Org :: View topic - Project Post #124 Refback 08-24-2007 08:33 PM
SyTy/SGT - Forums - Project Post #150 Refback 08-01-2007 04:28 PM
S-Series.Org :: View topic - Project Post #107 Refback 07-08-2007 03:21 PM
S-Series.Org :: View topic - Project Post #124 Refback 06-24-2007 09:39 AM
Page generated in 0.67189 seconds with 32 queries
[Output: 230.46 Kb. compressed to 210.49 Kb. by saving 19.98 Kb. (8.67%)]
