pcv system on a remote mounted turbo?
Old 05-28-2008, 04:50 PM   #1
kiss my SS
bridawg8's Avatar
bridawg8 is on a distinguished road
its a 1994 s10 4.3 cpi the pc valve is on the passenger side valve cover. the turbo is goin to be under the bed on the pasanger side. i have a couple ideas but would like to hear yours. thanks for the help
Old 05-28-2008, 05:23 PM   #2
Project: "Bottle Rocket"
97_S-10SS's Avatar
97_S-10SS is on a distinguished road
Re: pcv system on a remote mounted turbo?
Here's what this guy did...
http://02vortec.tripod.com/id14.html
He used to be here on the forum, but he got the boot a couple of times for various issues.
It's a later-style injection setup, but the basics are the same.
Old 05-28-2008, 07:48 PM   #3
kiss my SS
bridawg8's Avatar
so in this case i would need to run a vacume line to the back of my truck to the turbos filter. this is what i want to avoid but if its needed then i will
Old 05-28-2008, 09:09 PM   #4
meyers2211's Avatar
meyers2211 is on a distinguished road
I did that and i eventually jus run a catch can. you need to keep the crankcase from boosting, or else u will blow seals like its your job. I did all of of them, oil pan, intake manifold twice and valve covers
Old 05-28-2008, 10:01 PM   #5
s10ls's Avatar
s10ls is on a distinguished road
a breather on each valve cover here. no troubles with oil seapage
Old 05-31-2008, 10:55 PM   #6
I call her: NIGHTMARE
98 SS's Avatar
98 SS is on a distinguished road
the girls complained about the smell when i ran open.
Old 06-01-2008, 09:35 AM   #7
s10ls's Avatar
i dont get any smells with my truck. maybe i'm not getting much blow-by with this old stock motor
Old 06-01-2008, 10:05 AM   #8
SSBlazerV8 is on a distinguished road
Put a one way valve in the vacume hose going to the pcv. What about a pcv valve for a Buick Grand National.
Old 06-01-2008, 12:18 PM   #9
meyers2211's Avatar
yea i believe that
at a stop after a boosted run the valve breather would blow out smoke for awile
turbo ur car and ur going to get increased blowby
Old 06-01-2008, 12:59 PM   #10
s10ls's Avatar
Quote: Originally Posted by meyers2211
yea i believe that
damn blowing smoke would make me nervous. do you built motor guys have loose tolerances or something? i've never had any issues with any of this
Old 06-01-2008, 10:42 PM   #11
98 SS's Avatar
just the name of the game. all engines build crankcase pressure. If you dont smell oil if your running open......you cant smell!! lol
Im getting ready to change to an exhaust scavenging system. No more catch can and less under hood clutter.
Old 06-01-2008, 11:15 PM   #12
meyers2211's Avatar
the motor was professionally built for boost and built with loose tolerances. I still have over 100psi in all cylinders
Old 06-02-2008, 07:01 PM   #13
s10ls's Avatar
i've smelt it on other cars, and my truck was doing in the very early stages of the turbo build. it dissapeared after some tuning and a few hours of idle time. if its blowing out the breathers its not doing much of it. my firewall is sealed up very well also
i've seen the exhaust setups on various cars, cool setup if you need it
Old 06-02-2008, 10:08 PM   #14
meyers2211's Avatar
i'm guessing it just venturis out?
Old 06-03-2008, 08:37 AM   #15
98 SS's Avatar
yea, bernoulli principle.
Old 06-03-2008, 07:25 PM   #16
Will work for turbo parts
King_Ice_Flash2 is on a distinguished road
Does that work with a turbo/catalytic converter?
I've usually just seen them run into the intake before the turbo.
Old 06-04-2008, 08:43 AM   #17
98 SS's Avatar
wouldnt want to do it with a cat. it sucks the oil and fuel vapors into the exhaust and burns them off. It would shorten the life of your cat.
Old 06-04-2008, 02:20 PM   #18
meyers2211's Avatar
i have mine vent to to a catch can, and the intake side of the PCv valve is on the intake of the turbo but it dumps oil all in pipes
Old 06-05-2008, 05:04 PM   #19
97 Jimmy S/C's Avatar
97 Jimmy S/C is on a distinguished road
I extended the existing hose with clear braided tubing (to view any possible oil) to the blower ducting inlet. It connects with a 90 deg. barbed fitting, the inside diameter is a little smaller. I have never had any issues to date, cold cranking pressure when last tested was 165 psi. This is also compliant with emmisions standards, they might get me though for not being 14.7 AFR above 2,500 RPM!
Page generated in 0.16927 seconds with 11 queries
