#51 |
I call her: NIGHTMARE
Re: parallel fuel rails with nitrous
as much as I would like some aluminum heads....I have my TBSS to play with too I'll have to see if I can wrangle up one of those pushrod tools. Or just buy one. |
#52 |
Got boost?
03zq8, do you run an aftermarket pan or an auxillary trans cooler? always good insurance with the stall. If you run a standalone cooler instead of running it through the radiator, you will notice a nice drop in trans temps.[/quote]
No man I'm not. I will definitely look into it though. Thanks for the input. I'm gonna order a Walbro 255 pretty soon. I hope it'll make an improvement. BTW...I keep looking in this thread and the more I look at the pics the more I want that darn Edelbrock 2114! |
#53 |
It might not necessarily make an improvement or noticable difference, But its a more solid base to work with and off of.
#54 |
Traction not found here!
98SS, I know exactly what you're saying. I have thought several times about selling all the stuff I have for the zexel and 3.73 swap and just going with a 8.8 rear.
#55 |
THE Registered User
98SS do you know how much power your truck is putting down?
#56 |
its been a while and a lot has changed. But it put down 313 and 404 at the wheels. 15-18psi with belt slip. The knock sensor doesnt work on my setup so the tune is mild to keep it safe.
All that is changing though ![]() |
#57 |
THE Registered User
Thats badass!
